Direkteinspritzung selbermachen?
.. direkteinspritzung arbeitet mit hohem druck, ob das so ein vespa kolben auf dauer mitmachen würde???????
MFG MIKE :-D
ähm, der druck liegt an der einspritzdüse an und nicht auf dem kolben.
  • Antworten 348
  • views 90,5Tsd
  • findet ihr es richtig ein neues mitglied so runterzuputzen? :plemplem:
  • Für die die es nicht ganz wissen. Eine Zündung ist in erster Linie ein Drehzahlmesser. Schliesslich muss ja die Verstellbare Zündung wissen bei welcher Drehzahl wieviel Vorzündung der Controller errec
Bajaj hat einen Chetak-4-Takter im futuristischem :-D-Design rausgebracht. Angeblich soll der Motor P'n'P in eine PX passen.
Meinst du dieses ekelhafte Teil?
The first shipment of new 2006 Chetaks will arrive in the U.S. mid-December. Supply will initially be limited. Talk to your Bajaj dealer to reserve one if you want to be one of the first with this new classic.
Due to an increasing world-wide demand for small-engine motorcycles and a decrease in demand for scooters, Bajaj Auto Ltd. has consolidated their offering of scooters. Fortunately for us in the U.S. this means an improved Chetak utilizing the improvements that were designed for, tested and proven in the Legend scooter.
With the spare tire moved to the space under the left cowl with the battery, it serves to counterbalance the weight of the engine on the right side of the chassis and lowers the center of gravity for improved stability.
The sturdier Legend front suspension is now standard in the new 2006 Chetak. And if the suspension ever needs repair, it's easier and less costly.
Tail lights and turn signals are larger and higher off the ground for added visibility and safety.
Moving the spare tire allows a longer seat, giving the passenger more room and comfort.
Available colors will be Metallic Black, Silver and a metallic green similar to our previously offered Misty Jade. As additional photos are forthcoming from Bajaj Auto they will be posted here.
2006 Chetak Features
bullet
Rigid monocoque chassis made of high-strength alloy steel
bullet Very low emission 4-stroke engine, 145cc, air cooled, 9 HP, overhead camshaft, oil pump circulation, oil filter, automatic variable advance electronic spark ignition
bullet Electric and kick start
bullet 4 speed manual transmission, low friction all geared drive train for 100+ mpg
bullet 12 volt electrical system
bullet Variable rate coil spring suspension with anti-dive front suspension, adjustable front/rear suspension to suit weight and road conditions
bullet 3.50 X 10 tires, 4 ply rating
bullet Top speed 55 mph+
bullet Curb wt. 253 lbs.
bullet Max wt. 564 lbs.
bullet Max recommended total weight rider & pass. 311 lbs.
bullet Seat to ground dim.: 31"
bullet Seat to deck dim.: 20.7"
bullet Deck to grips dim.: 28"
bullet Covered by an extended limited 2 year warranty
Hier der Link zur Inder-Net-Seite
Specifications
Engine
Type
Single cylinder, 4Stroke , natural air cooled, Gasoline engine
Displacement
124.6cc
Bore x Stroke
54x54.4 (mm)
Max Power
10.8 Ps (7.92Kw) at 8500 rpm
Max Torque
9.8 Nm at 7000 rpm
Ignition
Digital Ignition
Transmission
5 Speed, constant mesh type
Ignition System
Ignitor
Digital Ignition with Variable Ignition Timing Characteristic (DC-CDI) With Engine Over-speed limiter
Electrical System
Head Light
Multi-focal Reflector type with Halogen Lamp (35/35W)& Pilot Lamp
Tail Light
Multi-focal Reflector type with 5/10 W Lamp
Side Indicator
Multi-focal Reflector type with 10 W Lamp
Reflex Reflector Rear Reflex Reflector
Horn
12V DC
Battery
12V , 2.5 Ah
Instruments & Control
Instruments Cluster
3 Pod Instruments Cluster with
* Speedometer, Odometer & Trip Meter
* Tachometer
* Fuel guage
Control Switches
Handle bar mounted switches with Functions
* Lights ON-OFF
* Horn
* Dipper
* Push Cancel Side Indicator
* Pass
Ignition switch
Combined Steering & Ignition Lock
Stop switches
Front and Rear Brake switches
Dimensions
Wheelbase, mm
1260
Overall length, mm
2025
Overall width, mm
740
Overall height, mm
1115
Saddle Height, mm
800
Ground clearance, mm
155
Kerb weight (kg)
121
Fuel Tank
Full Tank Capacity
4.5 litres
Reserve Capacity
1 litres
Bearbeitet von red-polo
meinst de....
in der regel spritzen die düsen sehr kurz vor ot ein (die neuen systeme spritzen 2-3mal pro takt ein...)
der druck würde sehr hoch werden. darum haut es auch immer gerne an den nissan pajero´s den kolbenboden durch (wobei wir hier wieder beim diesel sind und die mit ein paar 1000 bar mehr einspritzen..)
aber ich denke trotzdem, dass ein vespakolben dafür falsch aufgebaut wäre....
MFG MIKE
Genau das! Wenn ich mir das nicht eingebildet habe, hatte irgendein Shop in .de den Motor mal im Angebot. Ich offe, jemand kann es bestätigen, denn auch ohne Drogenkonsum schlägt mir mein Bregen ab und zu mal ein Schnippchen...Sch**ß Überarbeitung.
LG
Mario
Da steht, das der Chetak 4takter 5Gänge hat. Ich hab den Motor schon mal gesehen und die haben da hauptsächlich Kurbelgehäuse und Zylinder verändert. Vielleicht passt das Geriebe ja in unsere Motoren... :-D
um mal eben auf den diesel zu kommen: fragt mal den everel (daniel dieseltrieb :-D ) der hat schonmal diesel in ne px getankt........ :-D
gruß
Äh, der hohe Druck ist in erster Linie dafür da den Kraftstoff extrem fein zu verstäuben und nicht um ein Loch in den Kolben zu schiessen. Die Drücke während der einzelnen Takte sind zwischen Direkt- und indirekter Einspritzung durchaus vergleichbar.
komm nichtmehr ganz mit, diese indier....
erst schreiben sie "bullet 4 speed manual transmission, low friction all geared drive train for 100+ mpg"
dann weiter unten
"Transmission
5 Speed, constant mesh type"
ja wie jetzt??????
schaut nach 2 verschiedenen Motoren aus, da
1.) verschiedene Hubraeume
2.) verschiedene Leistungsdaten
hab mir gerade überlegt, die Vespa ähnlich dem system common rail mit piezo injektor umzubauen, den einspritzdruck und benzindruchsatz liefert eine ölpumpe von einem größeren mopped, eingestellt wird der motor über die bestromungszeit des aktuators und fertig is die Vespa FSI, muss hald von der sache her noch im detail ausgearbeitet werden
  • 5 Monate später...
  • 3 Monate später...
Hi, bin neu hier und weiß ned, ob das noch einer liest.
Muß aber nach durchlesen des Threads doch mal meinen Senf dazugeben.
(Besitze auch noch keine Vespa, sollte aber bald kommen...)
Zum Thema Einspritzung:
Bin da selber nicht so megafit, aber mein Dad hat auch seinen Motor eine draufgebastelt namens MegaSquirt. Allerdings ist der Motor ein 4T - 3L - V8 von `73, aber MS ist open-source aus Amerika, die Typen da klotzen das Ding auf so ziemlich alles drauf was dreht und funkt. Lässt sich verhältnismäßig einfach mitm Laptop per Kennfeld einstellen, im dazugehörigen Forum findet man meines Wissens nach auch immer Hilfe. Man sollte allerdings der englischen Sprache mächtig sein...
Bei interesse mal googlen oder MegaSquirt.de
Grüße, Greg
P.S.: Ach, hat jemand zufällig ne alten 50er Vespa rumstehen, die er loswerden will?
Gerne auch mit Tuning, sollte aber auf Versicherungskennzeichen zu fahren sein... :-D
Was bitte hat diese Steuerung mit einer 2-Takt-Einspritzung zu tun ? So ziemlich gar nichts.
Einspritzungen für Autos gibt es schon eine Ewigkeit. Für 2-Takter aber nicht.
MegaSquirt kenne ist und ist nicht mehr als ein Steuergerät. So ein Ding braucht man für einen 2T nicht.
Silent Hektik - ICM
Das Interaktive Controlled Management ersetzt die Vergaser und die Zündung von Viertakt und Zweitakt Motoren. Ein-, Zwei- und
Vier-Zylinder Anwendungen bis 19500 U/min sind möglich. Das Herz der ICM ist die ICM-Box. Sämtliche Komponenten werden an
diese Box angeschlossen. Es ist eine Multi-Prozessor-Unit, die in Echtzeit in 16bit gleichzeitig die Benzinmenge, die Zündzeitpunkte und die
Kommunikation zum PC managen kann. Auf der Vorderseite befindet sich der Multistecker für alle elektrischen Anschlüsse und der
CO-Poti für die Gemischeinstellung im Standgas. Auf der Rückseite befindet sich ein 9poliger D-Sub Stecker für die serielle Schnittstelle. Die
ICM-Box verfügt über sechs Hochstromausgänge für bis zu vier Düsen, für zwei Zündspulen, die Pumpe, ein Standgas Regulier-Ventil oder
den Drehzahlmesser. Die Anpassung an den jeweiligen Motor geschieht mit einer PC-Software auf dem Prüfstand oder während der Fahrt
bzw. Flug. Fast alle Daten können im Online-Modus beliebig verändert werden ohne dass die normale Funktion beeinträchtigt wird =
Interactive Controlled Management
Hätt ich mehr Kohle als ich momentan habe würd ichs probieren.
Bearbeitet von Crusher
@Nitromax:
Ich will hier weder eine Off-Topic diskussion noch einen Streit anfangen, aber eine Einspritzung funktioniert meines Wissens nach nicht ohne Einspritzdüse. Und diese muss doch von irgendwoher wissen, wann, wie oft und in welcher Menge diese den Sprit einspritzen soll. ->vom Steuergerät.
Oder denkt ihr hier an ne mechanische Einspritzung?
Korrigiert mich bitte, wenn ich was falsch verstanden habe bez. 2T-Einspritzung.
@Nitromax & DaSnob: Ich glaub es handelt sich da rein um ein Missverstaendniss: DaSnob & der Rest hier sprechen vom Einspritzen, Nitromax aber vom Abspritzen. Fuer Letzeres braucht man kein Steuergeraet - wobei ich aber Einspritzung mit Steuergeraet :love: absolut bevorzuge
:-D M
Bearbeitet von minikin222
Nicht so voreilig! :-D Einspritzung beim 2T gabs bei Borgward oder so ende der 50iger oder in den 60ern schon an nem 3-Zylinder-Automotor, der dann aber leider weil zu früh auf den Markt geworfen/unzuverlässig/zu teuer war und deswegen floppte! Bla, bla...
Ob das ne direkte war, kann ich nich sagen, es war aber ganz sicher ne mechanische! :-D
Was daran bitte soll falsch sein? Dass schon von langer Zeit damit experimantiert wurde ist eine ganz alte Geschichte. Fakt ist dass sich so was nie durchsetze und es somit nicht auf dem Markt erhältlich ist.
Dass es jetzt grössere Bootsmotoren mit solcher Technik gibt ist auch nichts neues.
hat da also noch
jemend experimantiert
damit,ja?
:-D:-D:-D:shit:
Hier ist vielleicht ne interessante Seite:
http://www.provenion.de/ffi.htm
Mfg
Hat sich jemand diese Seite mal kurz angeschaut? Unter dem Punkt FFI Geschichte sieht man doch sowas wie eine Cosa? Also haben sie es geschafft?
Aha siehe da ne `92 Cosa :-D !? Bestimmt nen ganz geheimes Projekt :-D
hat da also noch
damit,ja?
:-D:-D:-D:shit:
der "jemend" war ein versehen. aber die englischen RD seiten da beinhalten eine komplette anleitung um die einspritzanlage der BMW R6 auf die RD zu pflanzen. im deutschen RD forum wird das nun wohl nachgebaut. vom mechanischen aufwand her sieht dass nicht besonders schwer aus. muesste sich jemend in die open-source elektronik reinfuchsen...
edith meint noch, direkteinspritzung ist das aber nicht. ist deswegen sowieso OT :-D
Bearbeitet von atom007
Tjaja ich kann nur sagen das ich auch einen Ditech besitze. Ohne Distanzring mit allem original läuft die Kiste ohne Probleme echte 90 km/h.
Hat laut papieren 4,6kw
Gestern hab ich mir ein Fläschchen Motul 2-Taktöl gekauft.
Da steht hinten drauf: Für Roller mit Benzineinspritzung geeignet. :-D
Wo bitte ist endlich der entsprechende Roller dafür....... :-D
LG,
Ölsau
Tagchen
Gibts da nicht von Piaggio die ET2 injezione oder so?!
Gruss :-D
ja die et2 mit einspritzung wurde tatsächlich mal für kurze zeit produziert...is aber nach relativ kurzer zeit wieder eingestellt worden wegen zu großer unzuverlässigkeit. gab wohl auch mal ne et2 4T...schwachsinn sowas 4T....pah
also für die sache mit dem kompressor könnte man das primärritzel von der ape nehmen .
daist so eine art stift dran mit dem man dann den kompressor antreiben könnte.
oder man nimmt gleich einen 12 v kompressor...
