So here are the curves first is made at noon with a hot weather and the last one at the end of the day...
Both with 24/14°
Timings are 126/191
Bearbeitet von keuk
Noooooo. :wacko: that just 1hp more than my old iron polini which was a 51 stroke and Koso 28. I need 2hp more to be satisfied for the work done...
The soft engine is more strict and give 1,5 hp less than the P4.
I will try dicreasing the main jet a little bit more, the spark is still more black than brown.
I didn't touch the needle yet but it won't modify the max hp, isn't it?
Yes I'm gonna increase a little bit the ignition timing, right now I have 15° at 8700rpm (at the best hp)
For the carb setup the nicest curve is with the 135 jet, the blue one, I have two curve with the 135, blue and orange, but the orange one is not realistic because that's the second shot on the 135 test, so the temperature is not good.
So I have 10 points less than the "standards", amybe the flowing inside the casing / intake has an impact, everything is really smooth.
Bearbeitet von keuk
:wacko: where had all the horses gone ? *sing along*
that is the engine we're talking about a few times?
so I think I had to get my dremel and we hook up at mirecourt :wacko:
nope, needle and main, they'll go together and change a little bit. But I think that's not your problem, there is something else wrong.
it looks like a intake or exhaust duct problem - I don't know...
I'm serious, let's check the engine at mirecourt...
Yes, that's the same, that's weird, like if it didn't fill in correcly ( it doesn't need more that 135/138)..
Here is a photoshop with your SCK curve with almost the same setup (EDIT: except that I'm with a 53 stroke......)
In french we said "il marche comme une patate"....
Bearbeitet von keuk
:wacko: ouch! now I get you. please try a bigger main. 138 must be way too lean!
try a 150 at first and after that, try it together with the 1st or 2nd needle (CGL?) position from top.
my evo with 27cv like to have a 158 / CGL pos.2
any modification to the reed? 2 petal conversion? 0,35 or 0.33mm?
Two petal conversion for the reeds with the green polini sheet. I kept the metalic U parts that maintain the reeds. (?)
For the test I didn't modify the clip which was always at the 3rd position (middle) on the CGL.... damned I should have tried :wacko: this, I don't have access to the bench now until the race.
So first try was 153 / CGL 3rd and I get 18,5..... then I put 148 that's gave 20 then 145 20,7 then 140 and 135 to finish at 21,5hp...
ok, the green is .35mm
keep the stoppers! otherwise the petals will die instandly.
uh... sounds like the needle thing..
so gestern erste Ausfahrt mit dem Polini gemacht. Ging schon ziemlich gut!
Jedoch nicht lange! :wacko:
Beschichtung ist in einem großen Bereich von der Zylinderoberkante ausgehend nach unten abgeplatzt :wacko: Keine Reibspuren im gesamten Zylinder zu sehen!!!
Ist das ein bekanntes Polini Problem?
Bearbeitet von bodybuildinggym
abgedreht ja, aber von innen nach außen und dann noch mit Schleifpapieraufsatz entgratet. Danach kontrolliert.
Ich habe aktuell auch in anderen Karren keinen Aluzylinder, der nicht von mir abgedreht wurde. Keiner hatte bisher das Problem. Nur zweimal ein neu beschichteter Zylinder (1xhonda RS 250 und 1xAprilia RS 250). Beide waren schlecht beschichtet und auf Kulanz repariert worden.
Ich würde mich einfach mal an den Händler wenden, wo ich den gekauft habe. Klingt ja nicht so, als sei das ein bekanntes Problem und somit liegt die Vermutung nah, dass du einfach einen schlecht verarbeiteten erwischt hast.
So rein rechtlich gesehen, müsste der dir ja im ersten halben Jahr der gesetzlichen Gewährleistung sogar beweisen, dass dein Schaden nicht an einem Produktionsmangel sondern an deiner Bearbeitung liegt. Oft ist aber ein Pochen auf sein Recht garnicht nötig, weil einem eh genug Kulanz entgegengebracht wird. :wacko:
Hallo
Ich baue in den nächsten Tagen für eine Freund ein Drehschieber-Motor auf!
kurz das Setup
Evo 130
Mazzu-Welle 51/97 leicht geschnitten
Keihin PWK 33 + Parmakit ASS
Vespatronic
Big Bertha
XL2 Kulu mit Xyger Deckscheibe (hier die Frage welche Federn?)
Übersetzung 2.56 mit kurzen 4. von DRT
Motor wird bei den Überströmern und am Einlass geschweißt
Auf welche Steuerzeiten soll ich mit dem Auspuff gehen? Sollte ja ein Straßenmotor werden und nicht ganz so auf Spitzenleistung ausgelegt sein.
Und ich hab das Problem mit der Beschichtung beim fräsen gelesen! Hatten das schon viele hier oder waren es Einzelfällen wegen schlechter Beschichtung?
Muß man sonst noch auf irgendwelche Dinge aufpassen?
Tja, da ich in der Nähe von Köln bin, betslle ich immer dort.
Der Zylinder ist oben, unten abgedreht. Der Auslass gefräst und die Überströmer im Zylinder vergrößert. Ob da Polini/SCK Bock drauf haben :wacko:
Vielleicht kann der wheelspin mal etwas dazu schreiben... :wacko:
Hallo
kurz das Setup
Evo 130
Vespatronic
Big Bertha
der auspuff muss da angepasst werden !
warum kein franz oder feuerzauber .
die bertha wurde mal für nen sp09 mit 128/192 gebaut +/-
dachte mir nur, dass die Bertha gut passen könnte! ok Franz wäre auch ne Lösung! Steuerzeiten 126/186-188?
    • Ohne oder auch mit Puffn (...aber /und wenns der Herr Mangold sehen mag, dann werde ich meine Glock 17 ´s legal  führen.)    Das wird hoffentlich das beste internationale "außeritalinienienisches" Treffen im 2024er Jahr. Und natürlich außer Konkurrenz zum  Meltdown Treffen und zu Elba, wo ich ewige lange Jahre teilnehmen durfte/konnte.   Mehr tschechern, mehr Liebe, mehr da kum ma her do gher ma hin!!!  Für die Germanen über Bayern die uns nicht mehr so leicht verstehen: Mehr trinken, mehr Liebe und mehr Heimantgefühl!   Next stop Austria - east Austria!    Mehr Infos: www.tcsc35.at in German and Englisch...   ..oder auf: FERIEN MIT PIROSCHKA - 35 YEARS THIRSTY CATTLE SCOOTER CLUB ANNIVERSARY | Facebook oder    ...und es wird schoarf und geil.....Scooterist69's Workshop Diary (@teninchdeluxe) • Instagram-Fotos und -Videos   ...googelts  mal wiesen festival !!!    oder: www.tcsc.at   http://www.tcsc35.at   ...und wir sind immer noch nach Sponsoren auf der Suche, außerhalb der üblichen Firmen, weil auch wir niemals normal waren!!!!
    • ...hat dafür keinen Schlüssel.
    • Ist praktisch schon klar, ich fahr nur gerne alleine und hätte gerne die Optik ala Bilder...da sind ja alle recht kurz.
    • GSF post created to get some pictures and feedback about this event which went so wellll... !!  @keuk
    • Registration on https://www.eurochallenge.de/   Scootentole presents the 30th Challenge Scootentole -  https://scootentole.org/phpbb3/download/file.php?id=19536   As usual, track will be accessible for training on Thursday, Friday and Sunday! xx€ half-day and xx€ full day (payment on site). For these 3 days, you must have your own insurance or you get one on the spot (from the track). Practice on track will be available (15min sessions) alternatively with go-karts and/or with motorbikes        Categories and podiums (to be confirmed)   Planning (To be confirmed)       Followed by: Podium Lucky-draw Apero !!!       Food and drinks There will be possibility to eat on the spot, usual BBQ, french fries, etc * Lunch (main dish, drink, coffee): TBD * Diner coupon (Salad, meat, fries, drink, coffee): TBD   Location of the track :  As a reminder, the track is in Mirecourt (France, 88) and it is not so far from the German border; get direction: http://maps.google.fr/maps?f=d&hl=fr&geocode=4052204080919766249,48.319569,6.077357&time=&date=&ttype=&saddr=&daddr=Circuit+de+mirecourt%4048.319569,+6.077357&mra=pe&mrcr=0&sll=48.274054,6.019135&sspn=0.18783,0.398254&ie=UTF8&ll=47.931066,6.679688&spn=6.050603,12.744141&t=h&z=6&om=1 http://www.freekart88.fr/images/circuit.jpg A twisty, technical yet fast track in perfect condition, 1250m x 8m, fully equipped !
