Was hört ihr gerade?
Harderthanyou
  • Antworten 13,8Tsd
  • Salino
    1933
  • Schrottpresse
    1496
  • Dieta
    1151
  • BFC
    793
kansas - dust in the wind :-D
die trennung hat mich wohl weich gemacht inner birne....
alter falter. noch so'n post und ich komm rüber und hau dir irgend a industrial-zeug zur kompensation um die ohren... fab, müss mer uns sorgen machen?
abgesehen davon hör ich heut ärzte, weil das konzert gestern sicher nicht das beste konzert der welt war, aber trotzdem ausreichend gefetzt hat:
Bearbeitet von sibylvane
OK OK...dann halt so:
"I AM THE HIGHEST POWER...THE LEADER OF THE PACK"
Your god fucked me up the ass
Jesus Christ sucked my fucking ass
Your bible is such a piece of trash
I am the highest power, the leader of the pack
Hail Mary is so full of shit
Virgin Mary I'll rape that fucking clit
Jesus Christ was the son of a bitch
Your church, let's burn it to the ground
Priests and nuns, let's put them in the ground
We don't need those lames to hold us back
PERKELE - HANG EM HIGH
http://youtube.com/watch?v=stKJXxaqYKc
Hang'em high from Perkele!
Album : Voice of Anger!
Songtext:
They're pointing at you behind your back, they're calling you names
But you always know what they do, the aggression that grows
When you're alone they try to attack, one day you explode
It's gone too far, you're full of hate, can't take it anymore
Chorus (4x):
Hang 'em high ...
Hang 'em high - Hang 'em high!
Now it's time for their punishment, you'll get them one by one
So you can see the fear in their eyes, they're praying to be reprieved
Show no mercy, hang 'em high, remember what they've done
Get the cowards, get 'em all, it's their time to run
Chorus (4x)
Hang 'em high, hang 'em high - Let the cowards hang high! (4x)
http://youtube.com/watch?v=3qsl0pqUTaU
Bearbeitet von BFCDynamo
ein juwel der hohen lyrik... ich halt hier mal was traditionelles gegen
und freu mich trotzdem wie ein schnitzel auf's videoschauen :-D
:weeha:
noch ne kleine kostprobe?
1. strophe "anal cunt"
So you're dead and gone, I'll fuck your anal cunt
A lifeless piece of flesh, I'll molest it if I want
You're my feast, your soul has gone away
But your tight anal cunt is what I'll stick it in today
Just another dead fuck, it means nothing to me
Shit on my prick, another bloody treat
    • So Leute, gestern morgen war ich in der Garage, eine Vespa und ein Ciao umgefallen. Die Duplexrampe knickt sich im vorderen Bereich auch noch. Habs jetzt mal mit Gurten und passenden Querhölzern so gelöst:   Gang eingelegt und am hinteren Ende mit Gurten fixiert.    Bilder gibt es natürlich auch 😉
    • dann wären wir schon mal zu viert. Kann jeder von euch Doppelkopf?
    • Die Bezeichnung „BSAU 193A T2“ haben sehr viele verschiedene Auspuffanlagen auf dem Endschalldämpfer stehen, aber ausschlaggebend ist der Resonanz-Teil der Auspuffanlage, also das Stück vom Zylinderauslass bis zum Schalldämpfer-Flansch…   Ich würde mir Zylinderlauffläche und vor allem den Kolben mal genauer anschauen, vllt neue Ringe und Kolbenclips spendieren / evtl einen GS Kolben falls der alte Kolben schon Reibspuren hat. Kurbelwelle würde ich, wenn der Motor einmal offen ist, auf eine 60mm Langhub-Drehschieberkurbelwelle gehen, das hilft dem Malossi alt auf die Sprünge, und man kann schön mit den Steuerzeiten spielen (an Auspuff anpassen durch verschiedene Kopf-und Fussdichtungen bzw. Spacer…)   Dann würde ich auf jeden Fall einen anderen Zylinderkopf montieren, der ori Piaggio Kopf macht gerne mal thermische Probleme auf Malossi alt (…wenn der unbearbeitet ist?)   Zu guter letzt -wenn der Motor einmal offen ist- würde ich nen kurzen 4. Gang einbauen, z.b. von der 125er das kleine Gangrad. Dann hat man (gerade mit Malossi alt Zylinder) einen besseren Gang-Anschluss 3->4 und kann bei Bedarf übers Kulu-Ritzel noch länger übersetzen ohne den Motor aufzumachen…   Ansonsten würde ich bei dem 28 Dellorto Vergaser und DS Ansauger bleiben, und auf keinen Fall auf Membran gehen wenn die Drehschieber Fläche im Gehäuse noch intakt ist.    Kleine Tips noch: - Schaltraste überholen wirkt Wunder - Hauptwellenlager (radseitig) baue ich gerne ein 6204-2RSH ein, das ist geschlossen und hat dadurch den Vorteil, dass man keine Sauerei hat falls man mal die Bremstrommel ziehen muss
