Vergaser Smartcarb (Jetless)
Motorhead
vor 36 Minuten hat pv211 folgendes von sich gegeben:
Kannst mal nen wesentlich weicheren Ansauggummi. Testen?   Das Aufschäumen hat bei meinem Rennroller 4 Zyl geschrottet.
ich teste das am Wochenende. Habe 3 verschiedene Hier
gewebe
3d
und diese standart Gummi Dinger
vor 1 Stunde hat pv211 folgendes von sich gegeben:
Ich hatte nen Turbo Schlauch. Jedoch war der zu hart. Den hat matze mir dann quasi geschält. Danach war er butterweich und das Problem war behoben.
ich werde alles nötige am Wochenende umsetzten!
hier die Antwort:
We stress this to our dealers and has also been outlined in most of our literature. The SmartCarb (as with any float bowl carburetor) must have proper isolation from engine vibration and harsh contact with the frame or engine cases. Understandably there is little room under the cowling of a classic scooter and the fitment of an SC2 smartcarb on classic Vespa's and some other makes requires careful attention to installation. In the video above it can be clearly seen that the carburetor is shaking. This shaking is causing the fuel in the float bowl to aerate and then puke fuel out the vent scoop. Recently we have worked with customers in the US who have experienced the same issue. Several things can cause this. 1. the carburetor does not have adequate rubber isolation from the intake mounting flange and is receiving frequency vibration from the engine. A short piece of a fairly stiff durometer hose, attached with two hose clamps is recommended. (Also, and very important, it cannot touch the meta engine intake flange to the carburetor spigot by being pushing the carburetor too far inside the hose.) A small gap is necessary. 2. It has been discovered that on some older Vespa's the carburetor will indeed touch the frame and rub slightly on the bottom of the float bowl. This touching will also cause the fuel to froth. 3. Inadequate support of the carburetor, in the absence of an airbox to support the inlet end of the carburetor, solution number 1 becomes more important. In reviewing this video it is evident the carburetor is shaking violently and may likely be intermittently touching on the bottom of the float bowl. We have many customers having great success on their classic scooters but we must stress the importance of the installation. We stand ready to serve those customers who may be experiencing these issues and can provide additional customer support if necessary.
[mention]Lameda [/mention] wie sieht’s da bei deiner kiste aus mit vibration?
wäre schon interessant, ob eure kisten eher richtig rüttelplatte gehen, oder ob da bereits gutes material verbaut wurde.
habt ihr das problem auch bei rahmengesaugt?
vor 14 Stunden hat pv211 folgendes von sich gegeben:
Der Kollege @HD221 hat allerdings schon mehrere getestet ohne Erfolg.
 Und es haben nicht alle, nur einige.
dad macht die Sache interessant.
Ich bin von dem Problem nicht betroffen, mein Vergaser hängt an einem 3D gedruckten Verbinder, andere Seite mit Schlauch am Rahmen. Ich habe zwar schon einiges an Anpassung betrieben, um den Klopper gerade und nach allen Seiten frei auf zu hängen, jedoch hat er, wie och jetzt gesehen habe, leicht an der Kühlhaube gerieben. Hab ich beseitigt.
Weiterhin hatte ich ein minimales Nebenluftproblem am Zylinderfuß, auch beseitigt.
Ich fahre jetzt mit einer AQ-07 rod, die aber noch minimal zu mager ist. Leider ist die 5er z. Zt. nicht lieferbar...
Ich musste jedoch fest stellen, dass es zwar total smart ist, sich den AFR wert auf dem SIP Tacho anzeigen zu lassen, aber zum abstimmen ist das Käse. Ist quasi unmöglich, bei +160 die Anzeige abzulesen, viel zu klein... Zur Überwachung unterwegs geht's aber sicher.
Gruß,
Humma
vor 40 Minuten hat Humma Kavula folgendes von sich gegeben:
Gruß,
Humma
Bei +160 hätte ich nicht nur Probleme, die AFR- Anzeige abzulesen... :satisfied:
  • Haha 3
vor 48 Minuten hat Humma Kavula folgendes von sich gegeben:
Gruß,
Humma
 Auch den 36er?
habe heute  auch viel Zeit investiert an der Haube. Morgen kann ich dann endlich die ersten Tests machen
ich hoffe es lohnt sich
vor 56 Minuten hat schindol broer folgendes von sich gegeben:
Hatte echt etwas Furcht, werde wohl ne alte Pussy... Bin aber auch die letzten Tage mit dem T5 Minderleister rum gefahren, da bin ich diesen Zorn nicht gewohnt:-D
@Basti85
Jo , 36er SC II
Gruß,
Humma
Ich hab die 07er rod circa 40 Klicks mager gestellt, da passt das schon gut. Ist halt nur bei Vollgas vermutlich leicht zu mager, das teste ich morgen nochmal. Heute war dann nur Kerzengesicht checken, das war leicht zu hell. Morgen mal Vollgas im dritten und nochmal checken.
Melde mich wieder!
P. S. :
Hab schonmal ne ungenutzte AQ-09 zu verkaufen...
Bearbeitet von Humma Kavula
vor 17 Stunden hat Humma Kavula folgendes von sich gegeben:
Melde mich wieder!
P. S. :
und die 07er ist magerer als die AQ11?
mit den Rod Dinger muss ich mich mal beschäftigen.
Richtig.
Ich hab mich jetzt nochmal mit der AQ-07 beschäftigt und bin, glaube ich, so langsam in einem guten Bereich :
Leerlauf 13,8
Viertel bis dreiviertel Gas 13-13,3
Vollgas 12,7
Bei Einsatz der Resonanz magert er kurz auf 15 ab
Sind jetzt 80 Klicks von Vollfett Richtung mager!
(Insgesamt hat ein rod übrigens, wenn ich mich nicht verzählt habe, 200 Klicks. Eine Umdrehung sind 10 Klicks.)
Läuft echt geil:inlove:
Gruß,
Humma
vor 7 Minuten hat Humma Kavula folgendes von sich gegeben:
Richtig.
Leerlauf 13,8
Vollgas 12,7
Gruß,
Humma
Welchen ansauggummi ? Auf mrp Alu oder bogen? Wieviel Abstand zw gaser und Oberteil ? 36 gell ?
Bei mir hat der Tausch der Kugeln zunächst mal den gewünschten Erfolg gebracht.
Der Motor startet beim ersten Kick und läuft trotz korrekt eingestelltem Schwimmerstand nicht mehr über.
Jetzt klicke ich nach und nach magerer bis ich mit der verbauten A-Q07 hoffentlich da hinkomme, wo ich hin muss.
Meine Damen:
Fazit: eben Das Oberteil bekommen von mrp. Alles kontrolliert kein Kontakt zu irgendwas. Schwimmerstand er erneut kontrolliert mit Schlauch Methode, lag genau zwischen den beiden Markierungen.
Kiste angeworfen viele lange Gasstösse mit plötzlich Hahn ZU.
Kein SIFFEN
standgas deutlich besser, nach Tausch der Kugeln.
MOrgen dann noch ein paar Tests.
werde definitiv auf afr umrüsten um zu sehen wo man genau steht
Bearbeitet von Basti85
So hatte gestern mal zeit die kugeln zu tauschen. die sind ja nu deutlich kleiner als die alten, ich dachte also bringt bestimmt was. aber weit gefehlt. wollte den schwimmerstand einstellen und es ist die selbe scheisse wie vorher. entweder es ist 2mm unterhalb der min markierung oder es läuft zum rod sitz raus wie ein springbrunnen. dazwischen gibt es nix. also entweder stell ich mich wirklich einfach zu blöde an und der vergaser is tatsächlich smarter als ich, oder er is a depp.
nochmal das ich auch nix falsch mache:
vergaser ist ohne deckel, schieber, rod etc im schraubstock (nicht geklemmt nur fixiert), position ist ca so wie er dann auch im roller ist (smallframe kann man nicht eingebaut kontrollieren mit dem schlauch)
choke ist wie in der anleitung beschrieben offen
benzin kommt ausm testtank und ist ca 40cm über dem vergaser
schwimmer bewegen sich frei
hab sogar vor jedem neubefüllen oben in die kanäle gepustet um zu verhindern dass die kugeln ankleben
die reihenfolge der kugeln war bei mir zuerst die plaste, dann die stahl dann den deckel drauf (die mitgelieferten habe ich ums verrecken net verstemmt gekriegt)
mehr testen kann ich ja leider nicht, weil ich den zylinder nach dem klemmer, vermutlich durch den sc, neu beschichten lassen muss. mit dem billigen polini pwk lief die kiste net perfekt, aber besser als jetzt und 1,5 jahre lang ohne klemmer.
    • Hallo Vespa-Gemeinde,    Kurztext: - Verkauft wird eine Vespa GS3 mit EZ 01.06.1960  - Polini CP23 - Pinasco Flytech 12V - neuer Kabelbaum vom Garbor - zu besichtigen in Wuppertal  - Laufleistung ist unbekannt da Austauschtacho - Fahrzeug ist abgemeldet & mein Eigentum - Deutsche Papiere sind vorhanden   - die GS3 läuft  - Preis sind zu besprechende  5.400 €   Langtext: Verkauft wird eine Augsburger GS3 mit EZ 01.06.1960.  Die Vespa wurde vor vielen Jahren in der Farbe Silber lackiert. Es sollte der Silberton der italienischen GS150 getroffen werden. Ob sich der Werkslack unter dem aktuellen Lack befindet kann ich nicht beantworten. Das Lackkleid hat Schönheitsmacken, z. B. am vorderen Kotflügel, und auch das ein oder andere gebohrt Loch von z. B. vorherigen montierten Sturzbügeln, Gepäckträger oder auch Blinker. Das Blech ist gesund, es ist kein Rost zu erkennen.    TÜV hat die Vespa bis 04. 2024, die Reifen sind von 2022. Die GS3 erhielt einen Vergaserumbau auf Polini CP23 -> klasse Start & Ansprechverhalten. Um auch elektrisch auf dem aktuellen Stand der Dinge zu cruisen wurde eine Pinasco Flytech 12V Zündung verbaut -> zuverlässige Zündung, keine lästige Batteriezündung. Im gleichen Zug wurde ein neuer Kabelbaum vom Garbor eingezogen. Der originale Vergaser und die originale Zündung sind nicht mehr vorhanden.    Originale Denfeld Sitzbank, wurde vor paar Jahren neu gepolstert und bezogen. Der originale Scharlach Scheinwerfer ist verbaut und die Schlüssel sind original von Huf. Tacho ist Repro und die Hupe hat eine IGM Prägung. Das Schwanenhalsrücklicht ist aus dem Zubehör und vorhanden. Die Bildern wurden kurz nach der elektrischen Modernisierung vorgenommen, da war das Rücklicht noch nicht montiert.    Aus meiner Sicht gibt es noch ein to do für eine Vespasaison: die Kupplung treibt seit letztem Jahr im gezogenem Zustand und eingelegtem Gang etwas an. Dies müsste durch den neuen Eigentümer behoben werden.   Bei Fragen stehe ich euch gerne zur Verfügung. Viele Grüße
