ZIRRI H2O
post-12087-1124548201_thumb.jpgI HAVE A ZIRRI 135 LIQUID COOLED KIT AND HAVE NO INFORMATION ON IT AT ALL I HAVE THE SCOOTER RUNNING BUT NOT THAT WELL. I'M TRYING TO FIGURE OUT WHAT THE IGNITION TIMING SHOULD BE SET TO. DOES ANY BODY HAVE ANY INFOR MATION ON THIS KIT AND ANY OF THE SETTING. I'M USING A MIKUNI TM32MM CARB. ANY INFO WOULD BE GREATLY APPRECIATED.
SCOTT
Ich LASSE EINE ZIRRI 135 FLÜSSIGKEIT ABKÜHLEN SATZ UND HAT KEINE INFORMATIONEN ÜBER ES ÜBERHAUPT ich DEN MOTORROLLER ABER NICHT DAS GUT HABE LAUFEND. Ich VERSUCHE, ZU LÖSEN, WAS DAS ZÜNDUNG TIMING ZU GESETZT WERDEN SOLLTE. MACHT IRGENDEINEN KÖRPER HAT IRGENDEIN INFOR MATION AUF DIESEM SATZ UND IRGENDEINEM VON DER EINSTELLUNG. Ich BENUTZE EIN MIKUNI TM32MM CARB. IRGENDEINE INFO WÜRDE GROSSARTIG GESCHÄTZT WERDEN.
SCOTT
The translation program you used is not really helpful. :-D
30°/v.OT would be 30° before TDC in English.
Knud, bis bald in Rotenburg! :-D
@ fastzirri: If you get the monster running, we would like to see you at the quarter mile race near Bremen on October 1st!
For further information: www.beschleunigungsrennen.com and www.minusschrauber.com
Bearbeitet von Gammel
@ fastzirri: If you get the monster running, we would like to see you at the quarter mile race near Bremen on October 2nd!
<{POST_SNAPBACK}>
any other info you have on this kit would be greatly appreciated i'm in canada finding info on this kit is next to imposible. the bike runs right now just tuning it. to you know if there is much else you can do with kit? now is this consider the 190 h2o kit? the one they say will do 180km?
Canada?? :-D
So please tell us about the Vespa-Scene in Canada-and how do you get there a Zirri MR 2100-its really,really rare- even in Italy... :-D
This the result from my Zirri-fitted with a 37 VHSA,a Motoplat-Ignition and an exhaust from a Fully-cross-Bike.
There are NO works on the Cylinder and Piston so far-so there is still a little Potenzial for more Horse-Powers... :-D
Regards,
Knud.
Edith ist stets bemüht,das gute alte Schulenglisch grammatikalisch korrekt darzustellen-was nicht so leicht ist...
Bearbeitet von rocket88
The scooter scene is pretty good here some fast scooters. I bought the kit from a guy who has had it in his shop for 8 years never had enough time to build it. plus the fact he has a very fast lambretta with nitrous. my setup is going to be the mr2100 with a mikuni tm32mm flat slide hope that should be enough.post-12087-1124567000_thumb.jpgpost-12087-1124567100_thumb.jpgpost-12087-1124567039_thumb.jpg those are some the the fast bike in our scene here and yes that is nitrous and a turbo on a TS1 240cc Lambretta.
I`d like to say that a 32-Carb.wouldnt be big enough.
The 37 Dello is part of the Zirri-Kit.
The next days i will fit my new 38 Keihin... :-D
Holly Shit-this Turbo-Nitro-Thing is very evil...
Do you have any times about running on the Quartermile?
<{POST_SNAPBACK}>
The turbo doesn't kick in until the close to the end of the quartermile with out hitting the nitrous he's running low 15 sec in 1/4 mile if i remember correctly
the kehin cark is simular to the mikuni correct?
the mikuni flat slide 32 is about eh same as a larger dellorto round slide
my friend who is running a mr2000 told me the mikuni tm 32mm flat is the the best setup he has had and he's hitting 160km/h
is there that much of a difference between the mr2000 and 2100?
Well-maybe the air in canada is cooler so you can choose Cabs that arent so big... :grins: :-D
No,in fact the Zirris i know drive currently >34mm Cabs-but of course it is a question of the rest from setup.
Maybe its better to drive a little Cab when you choose more Power by lower rpms?
15 sec. for the Qm is not soo bad... :-D :wasntme:
I think the MR2100 is the same like the MR2000 air-cooled-but there are three different kinds of it i mean.
<{POST_SNAPBACK}>
What kinda of times are you running for the quarter mile?
aside from carb what setup are you using in term of transmission, crank and upgear?
Scott
Scott
<{POST_SNAPBACK}>
Here you can download an excel-file containing the results of the 2005 Marl Quatermile...
Siehste in der Schule lernste nur Blödsinn...
Crankshaft is a "fullround"( :-D ) with 19mm for taking up the Motoplat-Ignition,
Transmission is a 2,56 with a short 4th-Gear from Zirri.
Best time so far was a 15,8 sec with a badly slippering clutch... :-D
There were only ONE run on a Quartermile without problems so far... :-D
thin-taper full-circle crankshaft. motoplat ignition. 2.56 primary drive, zirri short fourth. ;-):-D
the scooter is VERY loud when run in small buildings, especially living-rooms. ;-) scooterists love it, girlfriends hate it. :-D
r
Sorry...short offtopic!
Hi, Fastzirri!
do you know how I can get in contact with the Turbo-Lambretta owner? An e-mail adress or something?
I´m currently working on a turbocharged Vespa (without NOS...)
Would be cool to talk to someone who has some experience.
Thanks!
Turbo-Vespa-Topic
Bearbeitet von Andre
i got my scooter running it wwas running great i pulled it apart to check everything was ok. the bottom of the cylinder that fitting into the sigot of the case on the intake side was broken. i have taken it to a shop of a friend he can weld and fix it i'd be looking at having to get it re nicasiled at approx 400$ i'm starting to wonder if it is worth it. what do you think of rthe new mr2000 iron or the fabrizi stuff? is there any way or any chance i could find a replacement cylinder and suggestions at all. i loved the way this kit ran even before i got all the jetting right.
i'd appreciate any ideas or suggestion you have.
you can have it re-nikasiled through one of this forum's users - there is a topic under "Dienstleistungs Angebote" - but I don't know if it is still availuable.
This would be way cheaper than the suggested 400$ - posting isn't that expensive.
Otherwise, I guess there's enough power to find within a tuned Malossi or Polini Zylinder.
Check out the web page of forum member Olli Ets - www.grandsport.de
he has new Zirris, and more important: the nice GS piston to get the Polini ( and malossi ) runnning. :-D
Bearbeitet von Paola
    • Bei PX geht die Kotflügel(de)montage mit Staubblech; bei allen Modellen davor muß das Blech weg sein.
    • Meines Wissens ist das auch bei PX nötig... also Staubblech runter.
    • Dann sollte der mindestens rot sein… weil rot bringt ja Leistung
    • Freunde des Motorsports, liebe Wanderprediger, verehrte Blechpiraten: Einen schönen Vatertach euch Von SIP gibt es seit einiger Zeit ein neues Vespa Polrad. SIP hat das Produkt auf den Markt gebracht um sein frei programmierbares VAPE Steuergerät nutzen zu können.   --> Dieses Polrad kann man auch nutzen um ein Overrev Steuergerät auf einer SIP Zündung zu fahren       Einkaufsliste für Vespa PX: - Overrev Steuergerät (erhältlich bei SIP, KR, SCK und bei mir) - VAPE Zündspule "PX200" (erhältlich bei SIP & KR) - SIP VAPE Polrad 51007160 (erhältlich bei SIP)   Hier noch eine Fotolovestory zum Verbau (danke an @berlinwestside für die Fotos): So sieht die Grundplatteneinstellung mit SIP VAPE (out of the Box mit Z102 Zündspule, keine neuen Teile) aus.   Und so nach fertigem Umbau mit oben genannten Teilen.   Dafür muss hier noch etwas gedremelt werden:   Ansonsten muss nur ein guter Platz für das Steuergerät gefunden werden...   ...die Zündspule getauscht werden... ...das Kill Kabel deines Rollers an das grüne oder graue Kabel des Overrev Steuergeräts angeschlossen werden, die Zündung auf Zündkurve #1 bei 18° abgeblitzt werden. Und dann fährt das auch schon   Aber bevor ihr jetzt losfahrt: UNBEDINGT die Anleitung lesen. Da steht SEHR wichtiges Zeug drin. Ich kriege viele Fragen die in der Anleitung schon beantwortet sind. Die häufigsten siehe unten in der FAQ.     Hier die Universal-Anleitung. 2024_Overrev_Steuergerät.pdf   Besonderen Dank an: SIP fürs bereitstellen des 51007160 Polrads. @berlinwestside fürs Fotos machen.      FAQ:  Mit Zündkurve 1# (0000) muss bei >3500 1/min abgeblitzt werden. Bitte nicht darunter versuchen, da ist die Standgasstabilisierung aktiv.      Zu 95% liegt hier ein Masse-Problem vor. Kontrolliere mit einem Ohmmeter den Durchgang von - Motorblock zu Zündspule - Motorblock zu Steuergerät - Zündspule zu Steuergerät Wenn da irgendwo mehr als 0.8 Ohm zu messen sind, verlege ein Massekabel.      Check die Spulendurchgänge am Stator: Lichtspule (Schwarzes Kabel - Schwarzes Kabel) soll 0.5-0.6 Ohm haben Zündsignal (Weißes Kabel auf Masse) soll 70-72 Ohm haben Zündenergie (Rotes Kabel auf Masse) soll 560-570 Ohm haben Weiterhin miss nach, ob du eventuell einen Kurzschluss vom "Kill" im Kabelbaum deines Rollers auf Masse hast.     Weil die Positionierung von Rotor zu Stator anders sein muss. Genaue Werte siehe Anleitung.  Generell gibt für die Sparfüchse drei Optionen: 1. Polrad ohne Keilnut verbauen und verdreht montieren (doof weil nicht gut reproduzierbar) 2. Stator verdrehen (Stator um ein Loch versetzen und die Grundplatte arg dremeln (dazu schreibt @berlinwestside evtl was)) 3. Stator um ein Loch versetzen und Polrad nur leicht verdrehen (ist genau das gleiche wie nur Polrad verdrehen, aber mit Stator-Tetris)   Option1 ist super um das an einem Schrauberabend einfach mal auszuprobieren und den eigenen Roller zum Nulltarif mit Verstellzündung zu fahren. Für das finale Montieren würde ich das Polrad von SIP kaufen. Ihr kriegt das schon hin. Und wenn nicht: Anleitung lesen, Teile kaufen, mich in Ruhe lassen   Nein, nicht wirklich.  Im Resoloch schiebt dein Auspuff zu früh zurück. Dadurch hast du sehr viel Restgas im Zylinder. Restgas verlangsamt die Verbrennung -> es braucht einen früheren Zündzeitpunkt damit das Gemisch verbrennen kann. Sonst kommt es zum viertakten.   Nein. Auch das nicht. Im Teillastbereich fährst du mit geschlossenem Schieber und gibst dem Motor dadurch wenig Frischgas. Dadurch, dass die Überströmkanäle aber immer offen sind wenn der Auslasskanal offen ist, holt sich dein Motor Abgas aus dem Auspuff zurück. Dadurch hast du sehr viel Restgas im Zylinder. Restgas verlangsamt die Verbrennung -> es braucht einen früheren Zündzeitpunkt.    Ich habe keine Argumente gegen Gefühle. Probiere es aus, mach dein eigenes Bild. Man kann es natürlich übertreiben und kaputt machen. Aber ich fahre alle meine Motoren mit Verstellzündung
