Hello, I'm french, so speaking english !
About the engine:
-Malossi 210 cylinder & piston
-Pinasco 215 cylinder head
-Mazzucchelli cranckshaft anticiped
-Dellorto PHBH 28
-Malossi manifold 28x36
-J.L. exaust inox
About the body and parts:
Before:
Pictures talk better than words !!!
Wilduck
Bearbeitet von wilduck
  • Antworten 65
...where do you have this nice seat from?
...it would look good on my lambretta :-D
Warum baut man beim Lacken etc. den Motor nicht aus ?
Sieht aus wie verdammt gute Lackarbeit, über den Rest kann man sicherlich streiten.
Verschieben zu Karren wäre angesagt, oder ?
<{POST_SNAPBACK}>
hello,
I am very sorry but I can not read german, but if i am right your first question was about the engine, and especially why i did not remove it for painting.
For the rest can you translate please.
Shuss
wilduck
Wow
what a nice clean work, fantastic color.
2 questions
1. How was the front made??
2. The airintake on the right side it almost invisible from the side like on pic 16 or is there a different "backe" on the vespa??? (pic 16 refers to you opening post)
I have some work to do this winter :love: :wasntme:
mfg El Cattivo :-D
Hello !
Thanks a lot for your generous reply :love:
I'm going to answer of questions:
-The "nose" has been made in fiber glass & polyhuréthane
-The colour is a blue from Alpha Romeo (Glasurit 414 & B414)
-On pict.16 it is an optical effect !
-About the seat, it was from Ancilotti, italian made but the production is over... But I will sell it 'cause I want to buy a Corsa or a S.I.P. Evo, don't know yet !
I have a question, what does "Warze" mean ?
Thanks a lot again for your congratulations !!!
Wilduck :-D
You got that right.
But what's the answer to that question?
What type of seat do you use, and where did you get it?
Looks pretty mutch like those Giuliari sport seats especially for Rally/Sprint . Rollerzentrale used 2 sell them .Last time in Stock was somehow End of 2001.Very slick .Used ones very hard 2 come by. Your Ancillotti was made for vespa or do you modify the Lambretta one.
<{POST_SNAPBACK}>
"wart" (engl.) or "verrue" (franc.) - a common term used for PX-range Vespas, since they are - wisely and widely ( :-D ) - considered "aesthetically inferior" :-D
hey wildduck! which dimension has your rear tyre. it looks extremly fat  :love:
<{POST_SNAPBACK}>
It's a Metzeler ME-7teen 130/70-10 with a home made large wheel .
Thanks for asking.
Regards
Wilduck
very nice,<span style='font-size:21pt;line-height:100%'>i´m improved</span> :-D   :-D
<{POST_SNAPBACK}>
na das hoffen wir bei dem kotflügel aber auch ;-)
b
ps: spass :-D;-)
Bearbeitet von Bluenote
    • @Hellsi - wenn Du mit 62mm Hub fährst würde ich neben der QK auch mal das Thema Verdichtung berücksichtigen. Ich würde - wie auch @weissbierjojo oben schreibt - den BGM mit 57 oder 60mm Hub aufbauen.
    • Ich glaube wenn alles takko laufen würde, hätten wahrscheinlich alle müde gelächelt. Momentan ist die Stimmung im Land wahrscheinlich eher etwas angespannt, das Sommerloch schaut um die Ecke und es gibt Protagonisten die sowas zum Selbstzweck gerne an‘s Licht zerren. Eine Vielzahl der Bürger hat das Gefühl die Entscheidungsträger beschäftigen sich lieber mit „Gedöns“ anstatt wirklich mal was zu ändern. Demnächst benennt man das Arbeitsamt um weil der Begriff Menschen die nicht arbeiten ausschließt. Kann man machen, löst aber nicht ein wirklich gravierendes Problem…….
    • Ich denke, das wird nicht gehen, ohne zu googeln 😉 und selbst das könnte schwierig werden. Marken, die nichts selbst machen, sind ja nicht allzu gerne dazu bereit, offen zu legen, wie ihre Produkte entstehen.  Die Hersteller werden ganz normale Fabriken sein. Da wird sicher keiner hocken müssen. Eine staubarme Umgebung, in der die Leute an Tischen sitzen, dürfte eher realistisch sein. Und das eine Team stellt dann Armani her, das andere Adidas, und das nächste Hugo Boss. Die Werke werden zugekauft. Bei Automatikuhren zum Beispiel von Seagull, die bauen alte ETA-/Unitas-Werke nach und sind gar nicht mal schlecht. Quartzwerke starten vermutlich schon bei Preisen, für die man kaum einen Döner bekommt.  Wenn die das jetzt Appetit gemacht hat, eine Lapflop-Uhr auf den Markt zu bringen  dann melde dich mal bei OPS, 3Wells oder irgendeinem anderen China-Hersteller. Da geht sicher was
    • @Hellsi grundsätzlich musst du ja einen Mehrhub von 5 mm ausgleichen. Die Hälfte davon nach oben, also durch Spacer…Ideal unterm Kopf. Soweit wäre der 2,5er ok. Deine Steuerzeiten sollten idealerweise irgendwo bei 120-176(178/180) liegen.  Und klar solltest du mal den Unterstand der Kolbenringe unter der Oberkante der Lauffläche des Zylinders messen. Mehr als 1mm würde ich hier nicht machen. Entsprechend musst du natürlich ne Fudi wählen. QK würde ich 1,1 bis 1,3 anstreben.  Und wenn ich ehrlich bin würde ich keine 62er Hub Welle mit dem 105er Pleul nehmen. je größer der Hub und je kürzer das Pleul desto größer die Gefahr dass das nachher vibriert. Ich würde da ganz klar auf 57 oder 60 gehen. Der BGM ist ein herrlicher Zylinder der auch mit kürzerem Hub schön Druck hat und dann auch drehfreudig bleibt
