Next year in the beginning of May I will drive to Mongolia on my '62 Vespa GS. Another team will do the same trip by car. The route looks as follows (we won't drive through Iran, google maps doesn't understand ferries):
For this trip I will prepare a Vespa GS160. The scooter will stay as original as possible and will be equiped with some original crash bars and a front and rear luggage rack. I will mount a P200 engine with the carter protection of a T5. Also a glovebox of a PX will be fitted.
Last week I started stripping the GS.
Gs still partly together:
Some time later:
In the upcoming weeks the GS will be powdercoated and I will start working on the engine and front fork.
Also take a look on our blog and facebookpage: http://www.facebook....474179539269276 and http://www.threebravemen.tumblr.com
To be continued!
I tried to safe it but it did not turn out nicely; some bando was used on the front and very large parts of original paint were missing. My last project was a great succes in saving the original colour.
Great "Project"! Respect. How much time do you plan for this little trip? I wish you a safe ride and please don't forget to post your story here. Also make sure to put on a comfortable seat :-)
Cheers!
Who takes a GS4 Series1 (!!) and screws a Bajaj glovebox on? Even a PX glovebox matches not the idea of "arrive in style"
I would also recommend the GS reproduction glovebox! Or I would try to get one of a Rally200: looks like GS and has the better opening system like PX
Nice project anyway!!
What do you mean by this:
How can a P200 engine gets as long-lasting as a T5 engine? :cool:
Cheers!
Thanks for your reply! I will post my story here as well. I am thinking about a comfortable seat, a rally seat will be better...
@crankhank; you are right about the looks, I will have another thought about the glovebox. I meant the plastic thing that is mounted on a T5 engine, I will put that on the P200 engine.
Thanks for the other replies!
Bearbeitet von Laurus
Unfortunately I was not able to do a lot last saturday, this friday I have an appointment with a travel agency, maybe after this appointment I can do some work on the GS... For now, let's think back about last summer...
Yes, I drove to Paris with my girlfriend, after Paris we went to the coast, to Dieppe. It was my second time on a Vespa in Paris, first time on a 50 special, this time on my GS with P200 engine, I think it is just magnificent to drive through a city like Paris on a Vespa! You are fortunate for living there ;)
I think that will be a great trip, the structure of the old vespa seems great , the engine powerful enough to make these long distance next year. :-)
a gs160 with a rear gaybäckfach over the cocklight must be driven :-D
good luck
vespa laurus
:gsf_chips:
Bearbeitet von schlubbi
good luck
vespa laurus
:gsf_chips:
Cocklight? Don´t you mix it up with your cockring? :-D
Btw: Nice project. Good luck :thumbsup:
Thanks for the replies!
Here some updates.
The GS is back from the powdercoater:
Now I can start the rebuild. Today I started with the front fork, I revised the shock absorber and mounted the swingarm to the frontfork.
Why do you skip the Iran?
Don´t! Especially the north part is great, and the capital is close enough for a visit/stop :satisfied:
Bearbeitet von MaRi
Here are better pictures as promissed!
Dismounting front fork
Removing the pin in order to get the axle out which keeps the swing arm and front fork together
Getting the axle out
Front fork dismounted
The frontwheel axle with bearings
Removing small bearing
Steer dismounting
The non painted part has to come off
Heating and the non painted part can be removed
Time for some welding
Welding
Welding and grinding
Before
After
The only rotten spot in the whole frame!! :)
Front axle cleaned, time to put the new bearing on and put it in the front fork
Swing arm back on the front fork with new bushes and axle and bearings
Putted the front wheel axle in and now putting in the bigger bearing
That's it for now! More to follow soon!
    • Download-Link https://we.tl/t-8sTuT6jF0T   Link ist 3 Tage gültig bis zum Läuft am 11 Juni, 2025  20 Uhr ab.     Hier die Bilder aus Zuera 2025 wenn grössere Daten benötigt werden bitte direkte Mail an mich. Namensnennung gerne Bengt Lange und www.bildwerk-lange.de Danke
    • Danke Euch! Das kann ich so unterschreiben. Ich arbeite auch viel in generationenübergreifendem Umfeldern, sowohl im Hauptjob, als auch nebenbei und privat. In jeder Generation findest Du immer alles.   Wenn Generationen gegeneinander dissen, sagt das immer sehr viel mehr über die Akteure selbst aus, als über die "Generationen".   Private Erfahrung: So lange man miteinander offen und direkt kommuniziert läuft es. Manchmal braucht es auch klare Ansagen (damit sind ausdrücklich beide Richtungen gemeint), dafür muss man aber auch selbst kritikfähig sein, sonst ist man unglaubwürdig.  Ganz schlechte Idee ist, überheblich, abwertend aufzutreten.    Einfach mal miteinander reden, statt übereinander.
    • ⸻ 🏁 Zuera 24h – Debütjahr für Team Two Stroke Loft Das Setting:     •    Erstes Jahr mit neuem Team, neuem Motorkonzept und fast komplett neu aufgebautem Roller.     •    Roller wurde am ersten Tag feierlich auf den Namen “Lofti” getauft.     •    Fahrercrew: Sarah, Markus, Matti, Holly, Leo, Matze – aus ganz Deutschland zusammengewürfelt.     •    Motor: Alex Stroh (Scooter Center), Betreuung: Christian, Boxenorga: Stefan und ich Bengt ⸻ 🏎️ Das Rennen:     •    Qualifying: Solides Mittelfeld nach nur zwei kurzen Stints – genau wie geplant.     •    Start um 12 Uhr: Nach 1 Stunde auf Platz 18, der Roller lief wie ein Uhrwerk.     •    Nur kleinere Zwischenfälle wie ein Ausflug ins Grün – problemlos weggesteckt. ⸻ 🌧️ Wetterchaos & Nacht:     •    20 Uhr: Sturm und Regen – Fahrerwechsel auf Slicks trotz nasser Strecke.     •    23 Uhr: Leo spürt instabiles Fahrverhalten → schleichender Plattfuß, Service mit Reifen- und Bremsbelagwechsel.     •    Dank Ausfällen anderer Teams plötzlich auf Platz 4 und P2 in der Klasse. ⸻ ⚠️ Morgendrama & Spannung pur:     •    Früher Morgen: Schwerer Sturz von Sarah – Airbag ausgelöst, Roller stark beschädigt, aber fahrbereit. Sarah blieb unverletzt.     •    Kurz darauf: Wieder Plattfuß bei Leo, diesmal mit Regelverstoß → 2 Strafrunden wegen Abkürzung.     •    Trotzdem starke Aufholjagd: Platz 2 in Klasse, P6 overall! ⸻ 🕛 Finale & bittere Sekunde:     •    Leo fährt eine Top-Zeit von 1:21 und hält mit einem fünften Stint die Konkurrenz in Schach.     •    12 Uhr Zielflagge – Platz 2 sicher geglaubt.     •    Doch: Leo überquerte ein paar Sekunden  nach offizieller Renndauer die Linie → Überschreitung der max. Fahrzeit (65 min).     •    Strafrunde, Platzverlust → Team rutscht auf Platz 3 in Klasse, 7 overall. ⸻ 😤 Nachspiel:     •    Proteste deutscher Teams gegen fragwürdige Entscheidungen (z. B. gegen spanisches Team) wurden ignoriert.     •    Trotzdem: Teamgeist, Performance und Zusammenhalt top – viele Sympathien gewonnen. ⸻ ❤️ Fazit:     •    “Lofti did it!” – Team Two Stroke Loft hat sich bei seinem Debüt stark präsentiert.     •    Trotz Drama ein erfolgreiches Wochenende mit viel Herz und Teamspirit.     •    Nächstes Jahr? Ganz sicher wieder! ⸻ Danke an alle Supporter – wir kommen zurück. Team Two Stroke Loft ⸻
    • Ne, aber ich kann mal morgen in der Garage versuchen zu messen. Ich hab da noch 1-2 XL Tanks liegen. Einer davon wird wohl was ausspucken. Ich hab keine Ahnung ob da was zu messen geht, aber ich versuch das mal. Widerstand muss ja lesbar sein    Wegen der Tachoseele...könnte man eigentlich einfach und doof unterlegen? Bißchen zumindest? Wenn ich jetzt keine Drehbank hätte würd ich mir mit was aus dem Baumarkt behelfen. Unterlagscheiben müßten eigentlich funktionieren. Damit die Seele weiter hochbringen? Das ist Messing oben, meine ich mich zu erinnern. Vielleicht reicht da als Distanz auch was 3D gedrucktes, weil das sowieso ein Plastestecker ist?
