Termine 2024
Cox
Filthy & Sly PLUS Kolbenfresser e.V. --- Superstyle Scooter Dive --- 14.- 16.9.2007 Aachen (Übach-Palenberg)
in kleiner gewohnt gastlicher Atmosphäre ... Zwei feinste Allsound Nighter (Dj´s Shaky, Lazy, Wicked Willy u.G.)
Hallenbad 50m entfernt von der Location... Zeltplatz direkt angrenzend.
Öffnungszeiten Hallenbad:
Fr.
7.00 - 10.00 Uhr
15.00 - 21.00 Uhr
Sa.
10.00 - 18.00 Uhr
So.
10.00 - 18.00 Uhr
weitere Infos unter carssuck.de oder Kolbenfresser e.V.
and watch out for runhuren.de
Bearbeitet von Der FONZ
National Scooter Rallies for 2008 as agreed at the BSRA (British Scooter Riders Association) meeting at Bridlington 27th Oct.
Yarmouth..........Easter Bank Holiday March
Llandudno........May bank holiday 2nd-5th
Kelso.................whitsun Bank Holiday May 23rd-26th
Whitby...............June 13th-15th
Cleethorpes....June 27th-29th
Exmouth...........July 18th-20th
Isle of Wight.....August Bank Holiday 22nd-25th
Woolacombe...Sept 19th -21st
Bridlington.......Oct 24th-26th
Additional dates that are none national status rallies/events available at the time.
Burton Brewers Custom Show...23rd Feb
VMSC Show........................March 30th
YSA Yorkshire Invasion...July 11th-13th
Brewers Droop.................Aug 1st-3rd
Mersea Island..................Sept 5th-7th
Strictly Scooters...............Sept 13th-13th
endlich weiß ich die rallies in der anderen welt :-D) aber gibts da auch websites zu? wäre net schlecht wenn mann mehr infos bekäme. hatten kelso eingaplant, soll aber recht aggro dort abgehen.
..fonz
