Esc racers consumption
well, there's a wide range, depending on the engine. A class 5 engine for example doesn't need much fuel, whereas a fully tuned M1L or Falc engine is seriously thirsty. The only thing I can say for sure is that my engine (M1L, 54mm stroke, 34mm carb, custom exhaust pipe) needs about 3-4cm (height in the original tank) of fuel...
so less than 1.5L ?
I don't know how much that is in litres, but I would guess about 1.5-2l
The faster ESC races are nearly 15 km total - with an estimated total consumption of 2l we would have an average consumption of 13.3 l/100km - seems a little bit low for me in race mode with a powerful (and not so well set up) engine...
When we expect 20 l/100km we would have a total consumption of 3l - this should do it...
Bearbeitet von Johannes
jogging has more effect on the total weight of your racer with you on it... :-D
Plus, i guess, nothing in the world could be more annoying than failing to finish by running out of fuel...
yes it 's true :-D
indeed it not really a pb of weight ...
where I want to mount the tank I have not lot of place so I would like to know if this small volume would be enough ... :wheeeha:
Bearbeitet von Luccio
for endurance racing we usually use around 5 liters per hour. i'd say 2l max should be perfectly ok. i'm running a swedish smallframe-tank in mine, they hold about 2,5 liters or so, and i usually don't have a problem with 15min of racing.
danke for this answer ! :-D
well lets go for a 2L tank :wheeeha:
but what's a swedish tank ? :-D
a swedish tank is a smallframe tank which was fitted as standard to swedish smallframe vespas. apparently they had a weird weight limit which resulted in smaller capacity fuel tanks and, rare as i don't know what, aluminium mudguards and aluminium side covers. never seen any of the latter myself though. of the fuel tanks i have two, which makes me the single most important collector of odd skandinavian shit outside skandinavia, i guess.
I didn't know that :-D
last year with polini gs and mikuni 30 tmx:
5 liter at one race weekend
this year with Falc and mikuni 38 tmx pj:
nearly 10 liter at one race weekend
this year with M1L and Dello 34 VHSB (23,5PS) :-D
Schon mal dran gedacht den Tank nicht voll zu machen? :-D
Ich höre schon die Lautsprecherdurchsagen, dass Luccio mit der neuen 2 Stopp Strategie die ESC Rockt...
da wär' ich zu blöd für. dafür hab' ich mir ja auch so'n kleinen gesucht.
@undi noch mal:
wenn du so ein ding willst musst du mal jemand in schweden ein bißchen auf den sack gehen. das problem iss aber dass gerade in schweden so ein zwergentank noch mehr für'n arsch iss als er dass meinetwegen in münchen innenstadt ist. deshalb wurde der kram da früher direkt weg geschmissen und ist jetzt dementsprechend rar. ich glaube im tausch gegen einen standardtank wird das schwierig.
@undi noch mal:
Sind ja auch Schweden hier im Forum z.B. http://www.germanscooterforum.de/index.php?showuser=3905 spricht sogar deutsch.
AFAIK hatte die Karren auch leichtgebohrte Zahnräder und SS !! Sitzbänke.
Wenn den Tank einer auf die Fähre schmuggelt, kann ichs im Hafen abholen.
Gruß aus Kiel
matze
Achja ich brauch 10l fürs WE also knapp 2,5 pro 10min.
Bearbeitet von matzmann
Gruß aus Kiel
matze
das mit den ss sitzbänken stimmt auch. allerdings waren da einige schon recht aktiv oben im norden, und auch die liegen nicht mehr in jeder garage rum. zahnräder wusste ich nicht. abgefahrener scheiß.
Ich vermute mal, das Luccio eher dahin will, daß er das Verstärkungsrohr zwischen Sitzbank und Beinschild als Tank verwendet und jetzt versucht herauszufinden ob sein altes Dachrinnenrohr wohl OK wäre...
    • Kurve wäre net schlecht von leistung stimm das mal ab schaut aus wie malen nach zahlen
    • Liebe Mitglieder,   bin aktuell auf der Suche nach einem Reibungsdämpfer für meine V11T. Es handelt sich um einen Patinaroller, daher möchte ich ungern ein Neuteil verbauen.    Falls jemand im Besitz eines alten Reibungsdämpfer ist und diesen abgeben könnte, würde ich mich über eine Privatnachricht freuen.   Vielen Dank!!!
    • Eigenbau aus den alten Blechteilen, mit mehr Platz rundum. Bei dem 3-Druck Zeug hätte ich Sorge, dass es irgendwann bricht. Ausserdem sind die mir zu klobig.       Cool, dass Du das ausprobiert hast! Bei dem im Bild mit oben Löcher zu hätte ich das auch so erwartet, was ich nicht ganz nachvollziehen kann, ist warum das BE2 so fett macht, wo doch die oberste Reihe im Prinzip eine Art "Bypass" ist. Die oberste Reihe ist ja vom Niveau her über dem Austrittsrohr....? Aber gemütlich ist meine Vorstellung falsch. Wahrscheinlich "saugt" es einfach generell besser den aufgeschäumten Sprit an.   Ich bin mit meinem Malossi 221 Motor von oben ein Stück weiter gekommen und er läuft jetzt fast ohne Sprotzeln. Beim Mischrohr war mein Eindruck bis jetzt, das es auf die kleinen Schieberstellungen und kleine Drehzahlen nicht sooo den grossen Einfluss hat. Aber ich behalte das im Auge...     Von 140BE3-125inc bin ich zu 140BE2-125 gewechselt (Idee: Das BE2 macht bei höheren Drehzahlen und 100% etwas fetter), weil ich das Gefühl hatte, die 125inc ist schon echt klein, verglichen mit meiner 187er Bedüsung. Aber die inc ist halt auch eher ne 130er SIP ...ich muss endlich die inc Düsen aussortieren und bei einem Hersteller bleiben...! Das läuft jetzt bei 50% wirklich sehr fein und bei Vollgas habe ich kein abmageren bemerkt. Auch nicht bei Höchstdrehzahl Hahn zu und schnell wieder auf.   Da ich gerade auf Tour bin und meist gemütlich hinter nem o-tuning her fahre habe ich jede Menge Zeit den 25% und 50% Bereich zu testen... Der 50% Bereich ist jetzt top mit der Kombi 140BE2-125inc! Komischerweise hat sich der Effekt bei 25% jetzt umgedreht und er läuft bei höheren DZ super, sprotzelt aber bei kleineren DZ. Das ist genau umgekehrt als vorher mit 160BE2 130inc und 55/160. Der Wechsel von HLKD 160 auf 140 und HD 130 auf 125 macht hier offensichtlich nen großen Unterschied. Wobei die etwas andere LLGS Einstellung hatte sicher auch ihren Einfluss.   Bei 25% Schieber hatte ich mit 55-160 außerdem nach einiger Zeit das Gefühl, dass das ist einen Tick zu mager ist bei mittleren bis höheren DZ: Es gab immer wieder kleinere Schubunterbrüche, aber eben kein Sprotzeln. Vor allem, wenn ich lange so gefahren bin und der Motor heiß wurde. 58/160 hat es dann Richtung mittlere bis hohe Drehzahlen besser gemacht dafür bei niedrigen Drehzahlen eher schlechter: mehr nerviges Sprotzeln.   Also dasselbe Spiel wie bei 50%: untenrum muss es magerer sein und obenrum darf es bleiben! Ergo: Luftdüse kleiner und zur fett-Kompensation die Benzingdüse ebenfalls. LLGS noch um 90° magerer gedreht, damit es auch unter 25% noch schön läuft. Dummerweise habe ich nur eine 55/150 dabei, keine 55/140 oder 52/140. Mit der  55/150 ist das Sprotzeln bei niedrigen DZ wenn dann nur minimal weniger...muss ich mal noch mehr testen. Vielleicht geht ja auch noch was mit der LLGS. Die 52/140 geht dann leider erst wieder daheim...
    • 123 Auto Lack hat alle Vespa Töne. 2K Lack aus der Dose. Das klappt super. Die Saison kann er noch lange nutzen, wenn er will... 🍻
