Hi!
For my vinter project, I’m rebuilding a 1959 Sweedish Vespa Touring (VGLA1T), similar as German T4. So far the floor and struts along with the horn cap has been replaced.
-otherwise it is just surface rust!
I’m building it with a PK fork and a Polini221 engine with SI-carb and PIS Road 2.0.
I’ve kept the autolube function in the engine, so I’ll fit a PX tank with oil tank.
But can someone please direct me on where to cut the hole for the glas for the oil level?
Thanks!
Rgrds
Sent from my iPhone using Tapatalk
Nice project!
I’d remove the glass of the tank though and be generous with refilling the tank based on mileage rather than modifying (destroying) the frame.
Would be a pity for this beautiful and untouched basis.
If need be use a transparent oil tube so you can check under the wing for air in the tube.
My 2 cents...
Thanks Arnelutchki!
It is a fairly ok project, but not as nice as it seems...
I've already welded on new floor and front shield, as I took over a project that was given up...
The sides was also altered, as previous owner had prepared the frame for GS cowls, but given up, so I refitting the proper T4 cowls...
In addition I'm fitting a PK fork and PX221 engine, so it will not be original...
And as it is to be used as my commuting scooter, I would like to have the autolube (I'm commuting 40km every day)
So I'll start on the hole in the frame fairly soon... ;)
Rgrds
Øyvind
Naja prinzipiell hat er nicht unrecht: wozu ein Loch in den Rahmen säbeln
wenn man einfach nur das Schauglas verschließen muss
Fahre ich in 2 Rollern so. Muss man eben immer mal von oben rein gucken wie viel Öl noch drin ist
Bei 1,5L Öl = 1.500km keine große Sache
weil's cool ist, nen Oldie mit sichtbarer Gaytrennt zu haben..
ich liebe es in meiner Ori TS...:inlove:
denke nicht das es beim Te an den handwerkliche Fähigkeiten scheitern würde wenn er / wer auch immer es unsichtbar / ohne Fenster haben wollen würde...
.. sonst wäre die Ursprungsfrage sicher anders gewesen..
Bearbeitet von hacki
So ganz bin ich da nicht von überzeugt
Egal wir haben es ihm gesagt
Wegen mir kann er sich noch ein Autoradio hinschweissen
  • Haha 2
Wann kam eigentlich die Getrenntschmierung für die Vespa auf den Markt? In D war es 1984, aber für andere Märkte war die ja schon viel früher verfügbar. Schon Ende der 60er Jahre?
Am ‎09‎.‎01‎.‎2019 um 08:18 schrieb efendi:
Meine Rally200, Baujahr 1974, gebaut für den amerikanischen Markt hat serienmässig ab Werk eine Getrenntschmierung, die seit dem klaglos funktioniert.
    • Hatte ein ähnliches Problem mal - da passten die Segmente der Primär ( Rad auf Nebenwelle zu Kuluritzel) nicht zusammen
    • Ich war eben nochmal in der Werkstatt.... Die erste nun ausgebaute Kupplung hat von der Kupplungsnarbe zum Ritzel eine gute Höhentolleranz >0,4mm, zudem sitzt auf der Kurbelwelle eine konische Anlaufscheibe und eine Passscheibe in Narbengröße in der Dicke 0,8mm. Also, dass Kuluritzel ist 100%ig von der Kurbelwelle getrennt. Nochmal getestet,    -- Leerlauf und gezogene Kupplung, Kicker ohne Widerstand. -- Gang eingelegt und gezogene Kupplung, beim vorwärts Schieben, ohne Widerstand. -- Gang eingelegt und gezogene Kupplung, beim rückwärts Schieben,  keine Trennung (volle Übertragung). --Gang eingelegt und gezogene Kupplung, ---laufender Motor und gezogene Kupplung,  dann Gang einlegen ... keine Trennung (volle Übertragung).     Ich sehe mich zur Jahres Ausfahrt schon mit dem EBike hinterher fahren...
    • Ok dann war das vorherige Lager bei mir verkehrt rum montiert... Aber eines raff ich nicht, die Anlaufscheibe zuerst dann der käfig mit den Rollen, wie sollen die dann halten wenn ich dann den Lagerring einschlage, die fallen doch gleich wieder raus, weill die Rollen doch auf der Wand des Lagerrings drehen sollten ..
    • ich fahre 1 mal King Kulu und 1 mal Sip Kulu mit der gelagerten Andruckplatte aber mit dem Lager, das wurde da eingepasst  https://www.scooter-center.com/kugellager-ina-85445-2024x557x0mm-verwendet-fuer-kupplungsandruckplatte-vespa-xl2/p-9846.html
