Motovespa 160 + GT - Modellkunde, Motoren & Tuning
Searching for UA spareparts is a pain.
I hope i get one of keuks manifolds.
Did anyone try the cp manifold? Will it fit on the GT160 without problems?
I struggle because i won‘t spend the money for it and a cp carb, only to find out its not that good. I heard its tricky to tweak the cp carp.
Thank you guys in advance.
vor 22 Stunden schrieb freddykrger:
a friend of mine uses a manifold made out of the lc-cooling hose from whatever scooter or motorcycle for his cp carb. It works. Only the carb needs a little support.
Yes they sale parts like that on the spanish websites:
540817705_Capturedecran2019-03-09a09_12_05.thumb.png.921a137fdb4c277ba719fba842ff7bd3.png2143866187_Capturedecran2019-03-09a08_24_35.thumb.png.03b501921676df7d5ca06cba45c65be6.png
I made printed parts too to fit on the original manifold. But we are still struggling with the overhangs on the printing process resulting in bad surfaces
image-2.thumb.png.e3ce5ffb759cb60f56f249adb39ea3d5.pngimage-1.thumb.png.d44cf80c18271325e7da6bf7bcbe4d5d.png
thumb_IMG_4625_1024.thumb.jpg.6a66ff5d5f0985a8c70923f6af41b7d4.jpgthumb_IMG_4619_1024.thumb.jpg.7bb53ca221d92c4add4de8266a68da98.jpg
That‘s a good idea. Maybe i‘ll find something in one of my „spareparts-maybe-i-need-it-one-time“ boxes. Thank you!
@keuk:
Thank you. Maybe i find what i need in spain.
First i wait for your manifold. This looked the best yet and the VHST is my favourite carb.
I know the problems that the printer can have. At work our testfield got a really expensive one. But often the surface is crap... hours of hours for nothing...
vor 45 Minuten schrieb keuk:
What is the recommended squich on the 160GT ?
What is the 0,8mm Rüstand Alex was talking about ?
I think 1,1mm to 1,2mm will be good.
The  Rüstand is short for Kolbenrückstand that means how many mm from the upper edge of the cylinder are left if the piston is in upper dead point.
I hope my english is correct.
New 62mm piston received, back to the 128° for intake
About the timings. Do you have this machining mark in the transfert port ? If I use the line of the red arrow, I have 120/150 with a 0,5mm gasket. As the machining mark is not that deep I wonder if the 120 are really accurate.
240796123_Capturedecran2019-06-21a11_43_03.thumb.png.b44849a45654df8f90a8d8522589f4fb.png
As Alex suggest, I will increase the exhaust height to reach 160° to increase the blowdown, do I enlarge the flange to 62% instead of 50% too?
1131726013_Capturedecran2019-06-21a11_40_05.thumb.jpg.30b1f584d1de617d67012224bd52b8fa.jpg
vor 23 Minuten schrieb keuk:
imageproxy.php?img=&key=ba1323ba10a7ed48
The 120° are accurate yes and no - because there is no volume behind the small slot. If you grind the transfer port to have there an evan surface...
regarding the exhaust port:
I know that's a pain, but to minimize the risk of  to go too far, go wider first, do some testing, go higher, do some testing.
vor 6 Stunden schrieb Andreas-DU:
kann mir jemand sagen, welche italienische Schaltraste - die man heute auch noch kaufen könnte - auf die MV160 passt?
Vielen Dank!
Andreas
Vermutlich Rally/Sprint oder hier:
http://www.recambiomoto.com/epages/1132358.mobile/es_ES/?ObjectPath=/Shops/1132358/Products/X379&ViewAction=ViewProduct
Hallo Wheelspin,
vielen Dank für die Antwort. Dem spanischen Bild nach sieht die Schaltraste dann der 160GS/180SS am nächsten
https://www.sip-scootershop.com/DE/Products/87031000/Schaltraste+FA+fur+Vespa+160.aspx?_country=DE4B2F82-D7AF-4AFD-BDE2-C726EF770AEF&gpc_origin=shopping&gpc_feed_alias=de&gpc_pid=87031000&dfw_tracker=40504-87031000&gclid=CjwKCAjwsIbpBRBNEiwAZF8-z2xw2N_MVC3YHU6NQXLYEOQ5-Ejrp6MdWgihnh8YTsJA4X9UiR2vARoCFVIQAvD_BwE
Dann fahre ich mal zu Scooter Center mit meiner alten Raste und mache einen Vergleich...
Hallo Wheelspin,
Lass mich bzw uns aber bitte wissen wenn eine von nem anderen Modell passt. Danke!
Am 18.5.2019 um 21:05 schrieb ChrisW.:
Hallo, hätte eine Frage zur Kupplung der 160GT. Ich weiß dass sie einen eigenen Korb haben und die Beläge der PX 200 passen sollten. Leider habe ich dass Problem, dass die Kupplung nicht ganz trennt, daher sobald der Gang eingelegt ist, hat sie Vorwärtsdrang. Ich habe nur die Beläge getauscht, auch schon versucht neuer PIlz, anderer Deckel usw. Nachspannen bringt nichts...Im ausgebauten Zustand trennt sie ganz normal.
Gibts da verschiedene Zwischenscheiben, oder könnte ein Spacer helfen.
Vielen
Dank für die Hilfe
Ich fahre nach langem Probieren die Beläge der GS3 mit den Original Trennscheiben, die auch dünner sind, als bei PX und co.  und das funktiert endlich.
Am 25.5.2019 um 13:41 schrieb salvatorescilaci:
Hola in die Runde,
welchen Auspuff fahrt ihr am liebsten auf der 160GT? Repro und ausgebrannter Original sind mir zu laut. Weiß nicht ob’s am Ausbrennen liegt, aber der originale Klang ist auch mit dem originalen nun nicht mehr gegeben. Nervt innerhalb geschlossener Ortschaften tierisch.
Hätte gerne etwas dezenteres. Gibt’s Alternativen? Ist der angepasste SIP Road leiser?
Danke für Euer Feedback!
Salva
Ich hatte erst ein Repro aus Spanien von scooterclasico.es), der einfach nur laut war, vermutlich wegen des dünnen Blechs. Dann habe ich mir so einen von Megadella umbauen lassen. Leider genauso laut und keinerlei Leistungsverbesserung.  Durch Glück habe ich einen originalen (nicht ausgebranten) auftreiben können. Und der ist jetzt schön vom Klang her und nicht zuuu laut. ;-) Allerdings ist der schon etwas geschweisst und ich habe nur ein paar mm Platz zum Hinterreifen. Weiss jemand, ob die vom Scootercenter die gleichen sind, die auch scooterclasico vertreibt?
Am ‎07‎.‎07‎.‎2019 um 14:10 schrieb freddykrger:
wie ich vermutet habe passte die Schaltraste für die GS160/180SS auf meine MV160.
Gekauft bei SC https://www.scooter-center.com/de/schaltraste-oem-qualitaet-4-gang-vespa-gs160/gs4-vsb1t-ss180-vsc1t-4350161?sPartner=google-shopping-de&gclid=CjwKCAjwvJvpBRAtEiwAjLuRPcx1oyPjxu1fZE4fK6nwsJEEWI-64prDrfHKijCnOoCoD_OGOap9yxoCeWkQAvD_BwE
Die ist von FA-Italia. Heute eingebaut und funktioniert einwandfrei.
Andreas
Bearbeitet von Andreas-DU
  • Like 3
    • Hallo Vespa-Gemeinde,    Kurztext: - Verkauft wird eine Vespa GS3 mit EZ 01.06.1960  - Polini CP23 - Pinasco Flytech 12V - neuer Kabelbaum vom Garbor - zu besichtigen in Wuppertal  - Laufleistung ist unbekannt da Austauschtacho - Fahrzeug ist abgemeldet & mein Eigentum - Deutsche Papiere sind vorhanden   - die GS3 läuft  - Preis sind zu besprechende  5.400 €   Langtext: Verkauft wird eine Augsburger GS3 mit EZ 01.06.1960.  Die Vespa wurde vor vielen Jahren in der Farbe Silber lackiert. Es sollte der Silberton der italienischen GS150 getroffen werden. Ob sich der Werkslack unter dem aktuellen Lack befindet kann ich nicht beantworten. Das Lackkleid hat Schönheitsmacken, z. B. am vorderen Kotflügel, und auch das ein oder andere gebohrt Loch von z. B. vorherigen montierten Sturzbügeln, Gepäckträger oder auch Blinker. Das Blech ist gesund, es ist kein Rost zu erkennen.    TÜV hat die Vespa bis 04. 2024, die Reifen sind von 2022. Die GS3 erhielt einen Vergaserumbau auf Polini CP23 -> klasse Start & Ansprechverhalten. Um auch elektrisch auf dem aktuellen Stand der Dinge zu cruisen wurde eine Pinasco Flytech 12V Zündung verbaut -> zuverlässige Zündung, keine lästige Batteriezündung. Im gleichen Zug wurde ein neuer Kabelbaum vom Garbor eingezogen. Der originale Vergaser und die originale Zündung sind nicht mehr vorhanden.    Originale Denfeld Sitzbank, wurde vor paar Jahren neu gepolstert und bezogen. Der originale Scharlach Scheinwerfer ist verbaut und die Schlüssel sind original von Huf. Tacho ist Repro und die Hupe hat eine IGM Prägung. Das Schwanenhalsrücklicht ist aus dem Zubehör und vorhanden. Die Bildern wurden kurz nach der elektrischen Modernisierung vorgenommen, da war das Rücklicht noch nicht montiert.    Aus meiner Sicht gibt es noch ein to do für eine Vespasaison: die Kupplung treibt seit letztem Jahr im gezogenem Zustand und eingelegtem Gang etwas an. Dies müsste durch den neuen Eigentümer behoben werden.   Bei Fragen stehe ich euch gerne zur Verfügung. Viele Grüße
