Motovespa 160 + GT - Modellkunde, Motoren & Tuning
Can't wait for it...:-D
You run it with a Dellorto VHST right?
I would like to try the VHST and a Polini CP type 19 to 23..
Has anyone convert the MV160 engine to reed valve intake with a "normal" two port barrel? This could be also an easy solution.
In my case I don't looking for high numbers on the dyno. I'm probably okay with 10 to 12 at the rear wheel though.
Any suggestions for an exhaust for the original barrel that will support the low transfer timings with good torque at low revs?
I was wondering if the P125 piaggio exhaust would be an option. Instead of all the box type exhaust...
I’m back on the original setup, 19er, to see first how the 170cc and the Sip road work. The sip road has a volume close to a px125 I guess.
I have increased a little bit the inlet timing by increasing the piston squirt cut from 126 to 140 according to Bollag’s advices.
And timings are 120/150. And I have grinded a little bit the original manifold to make it match perfectly with the cylinder and the yellow spacer.
On the original setup I had a 84 main jet. I tried 92 100 110,  but in each case the full throttle is weird, bowwww and it’s a pain to  reach the maximun rev of the engine. Like if it was too lean. The rest of the power band is great .
I would like to solve this before struggling to find the good atomiser/needle matching on the Vhst.
Could it be the inlet timing or the exaust port too low ? Maybe the ignition ?
Intake duration should be fine but don't go crazy at this area. A small step could be a step too far. 140° is okay.
The exhaust duration is too small.
There is no blow down duration.
I would recommend 160 to 165 as a first step. Maybe, if possible, in combination with something below 120 transfer duration. Because the area of the transfers is not too small, the windows are huge compared to the barrel.
Am 8.6.2019 um 21:57 schrieb wheelspin:
About the reed valve I had this in mind too, but I didn't go further than a PLA prototype.
vor 41 Minuten schrieb keuk:
Nice idea but I'm talking about the position of the p-range SI carb.
U know the small reed valve system to use with the SI carb. As long as the engine is not completed I would like to fit a reed valve for SI crabs to the engine to run it with a normal barrel.
vor 8 Stunden schrieb keuk:
It's a pity to modify the original casings, furthermore you will have to change or modify the crankshaft. What about a M1X ?
A few days ago I did a reed valve conversion to a SS50 engine but that's another story...;-)
In the end of the day it is what it is, an old and busted engine case... :-D
No, I don't want to spend too much money for a new barrel and I definitely not looking for a bunch of horses.
I will try your intake pipe first with a VHST or CP carb.
Btw I'm looking for an air mixture screw for the original UA carb. Are there the dimensions around? The one of my carb was totally destroyed...
This guy has probably the part:
https://www.milanuncios.com/motos-clasicas/ducati-dellorto-207314789.htm
Or this guy:
https://www.milanuncios.com/motos-clasicas/dellorto-ub-ua-ma-me-263328703.htm
By my side I think I will test another new piston, I have 142 inlet and 0,5 gasket and already at 120 for transfert port. I would like to figure put how it works first with near original diagrams before I try to improve something :-)
Bearbeitet von keuk
    • Stehbolzenabstand soll ja gleich sein beim 251 wie sieht es den mit den Überströmern aus, muss da aufgeschweißt werden?
    • ...ich hab' das Ding vor Jahren mal als PX-Gepäckträger gekauft. Aber ich vermute mal, das ist einer für T5 (oder PK oder sogar Cosa)...?   Hab' mir jetzt erstmal ein Adapterblech geschnitzt. Oder gibt es andere Lösungsansätze? Verbiegen wollte ich erst - aber ich glaube, da knickt das Blech oben weg. Und das unten halbwegs gerade zu biegen wird wohl auch schwierig...
    • Hi,   ich habe jetzt sicher vier verschiedene Buchsen für die Durchführung des Verschlusshebels hier liegen:   Keine passt richtig und meist sind sie schnell wieder kaputt: - Entweder nicht wie original Hartplastik, sondern weicher Gummi den es schon nach kurzer Zeit zerdrückt oder https://www.sip-scootershop.com/de/product/befestigungskit-seitenhaube-motorseite-ersatzradseite_62048100?usrc=verschlusshebel px   - die "Nut" in der Buchse ist nicht breit genug für die Dicke des Blechs (Blech ist an der Stelle gedoppelt) oder - der Innendurchmesser der Buchse ist zu gross, dadurch ist weniger "Wandstärke" vorhanden, weshalb es sich punktuell schnell durchschleift, https://www.scooter-center.com/de/buchse-rahmen/seitenhaubenverriegelung-made-in-vietnam-vespa-px-modelle-mit-aussenverschluss-rally180-vsd1t-rally200-vse1t-sprint150-vlb1t-gtr125-vnl2t-gt-7671628 https://www.sip-scootershop.com/de/product/buchse-verschlusshebel-seitenhaube-aussenverschluss_2293564?usrc=verschlusshebel px#reviews   Kennt jemand ein gutes Repro das aus Hartplastik ist und vom Durchmesser her passt? Gerne wie original schwarz. Evtl. hat ja sowas ja jemand als 3D Druck Teil parat?
    • Nein, ich biete ganz bestimmt keine Dienstleistungen an!!!   90% der Unterlagen die ich (seit 1994 beruflich) in die Finger bekomme sind dahingehend falsch.
