Das GSF wandelt Links in Affiliate Links um, um ggf. eine Provision erhalten zu können. Gerne nutzen bitte, danke! Mehr Infos, wie ihr das GSF unterstĂŒtzen könnt, findet ihr im GSF Support Topic.
imola 186 or gt 186
  • Antworten 84
  • views 7,8Tsd
Starstream is right, I use an Imola 186 kit (which has been re-nicasiled by MAHLE in Germany) in my LiS. Generally speaking, I am very satisfied with the Imola Kit. I use it in conjunction with a Mikuni TMX 35 carb, Vforce reed valve, MB Devtour exhaust, and AF electronic ignition. Peak power is 21 bhp at the rear wheel, while the engine has - for now - been set up to a comparatively rich mixture. The gearbox is of the Pacemaker type, but will be changed since gearing is too short and the engine runs at constantly high revs during motorway use.
The alloy-nicasil Imola appears to be quite resistant. It is suitable for longer motorway journeys and even survived a case of false-air intake without heat seizing. I did not experience any problems with the barrel so far. Therefore, I can not comment on parts availability, customer service, etc.
There is no possibility for me to compare the kit to the GT 186.
Regards
Tom
i think i will put an imola on my racer Li2 with a 30 dellorto phbh and devtour or Krp3 race exhaust . What's the speed performance of your motor in france we arrived with no problem at 130 km per hour with jet 200 spanish gearbox :-D
So far, there's no reliable data on this. A comfortable cruising speed is 100 kph, top speed is still unknown (but definitely far below the 130 kph mentioned by you). A longer gearing definitely is a smart choice for me, provided that the engine produces sufficient torque to pull it.
I know that each engine is different, but on mine a 30 mil carb (Mikuni) was way too small. Peak power was 3 bhp lower than now. I know this may sound strange but it is true.
ok tom73 i don't test imola i write what i read on french forum Thank's for your answer :-D
nee, is klar, 130 mit dem imola..... frag mal einen italiener, da laufen sie 140 und in spanien sogar 150....
ich fahre meinen seit 2003 ( ca 18000 km) bisher ohne probleme. bin heute von der elba-rally zurĂŒck, ca.2500km mit dem neuen sacchi auspuff. berge mit 2 personen und gepĂ€ck ging richtig gut. leider etwas zu langer 4.gang deshalb auf der bahn etwas zĂ€h.
den luftwiederstand einer 2.serie mit gepÀck darf man halt nicht unterschÀtzen...AA9B11F0FA6211DB9074DC7657BD7BDA.jpg
du warst in elba?
habe die reuse nirgens gesehen...
tja, wir sind halt sehr viel gefahren und haben die kisten nicht nur auf dem platz abgestellt :-D
i don't all understand 130 km/h or a way of 130 km
Ă€hrlich, ein kleiner block mit 150 Km/h? weißt du, wieviele PS du brauchst auf ner Lambretta, um 150 zu fahren? ich meine jetzt nicht nach Tacho! Echte 150? DafĂŒr brauchts ca. 40 PS! Den Imola möcht ich mal sehn! Und fĂŒr 140 werden immer noch ca. 30 ps notwendig.
your setup is ok for the imola except the gearing! the aerodynamic of the 2. ser. is very bad!! and the jet gearing is too long for the imola. the imola need some revs to get the full power. the standart jet gearing is 4,80 in the 4th. i think you will need min. 5.00 - 5.20 to pull the 4th. gear.
120-kmh vmax is realistic for the 2.ser.
the aerodynamic of my 2. ser is completely modified by a gp legshield for the best taken with the wind :-D and i think 15x46 or 17x46 with 125 Special gearbox
(same of GP 125 or GP 200 ) and a 58x107 or the tv kit in 58X116 for more couple or another choice the special imola model with 62X107 crank my choice is not made yet .
Bearbeitet von cast66
you didn't tell us that your S2 legshield is completely modified, dear. so 150 mph is possible -absolutly, with the better aerodynamic of your legshield. no doubt: if you also improve the aerodynamic of both wheels of your Lambretta another 10 or 20 mph are possible. this would make 160-170 mph! what do you think about that, clash1? do you agree to me? :-D a little bit wind from behind?
Bearbeitet von Hans_55
you must be comic :-D in france we arrived to 130 km:h and if i come to the german forum is to partage informations and preparation not to read weak answer ok :-D
hans_55 if you reply do a constructive answer :-D
ok. i will do my very best. :-D
@ cast66:
i can offer you an imola 186cc kit.
approximately 1000km, mint condition.
bought it on ebay for mi li3 restauration but as my girlfriend decided to become pregnant :-D
the imola kit and the scooter must go :-D
can send you some pics on request.
cheers
ralle72
Hi cast66.
How did you measure top speed on the Lambretta (as you know, the original speedo is not very reliable). What power did the engine produce on a dyno? How was it modified (porting, exhaust, etc.)? What gearing was used?
Regards
Tom
Hi cast66.
Regards
Tom
the barrel is full modified and it have a home made curly exhaust (IMGP5268.jpg) it give + 6 hp and my friend arrived up to 23 hp with 16X47 and 125 gp gearbox , carbs in 32 . he measure with a car speedo behind scooter on the motorway .
etwas OT, aber was sind das fĂŒr satteltaschen und wie fest gemacht?
die gĂŒnstigen dinger von louis?
genau. das ist das 3 teilige set von louis. die taschen werden an einer stegplatte befestigt. zusĂ€tzlich habe ich noch einen spanngummi um beide taschen gezogen. bombenfest! die dazugehörige große tasche hatte ich auf dem gepĂ€cktrĂ€ger. diese kann auch an der stegplatte befestigt werden dann mĂŒsste diese aber auf dem sattel liegen und das ist zum tanken sehr unpraktisch. schön ist der tiefe schwerpunkt da ich werkzeug und ersatzteile in den seitentaschen hatte und die (leichteren) klamotten in der großen tasche.
da wir mehrere ĂŒbernachtungen auf hin und rĂŒckweg hatten entfiel jedesmal das lĂ€stige verzurren des gepĂ€cks.
hast die backen irgenwie vor kratzer geschĂŒtzt ?
wie sieht die stegplatte aus?
Bearbeitet von gravedigger
Diese Website nutzt Cookies und vergleichbare Funktionen zur Verarbeitung von EndgerĂ€teinformationen und personenbezogenen Daten. Die Verarbeitung dient der Einbindung von Inhalten, externen Diensten und Elementen Dritter. Je nach Funktion werden dabei Daten an Dritte weitergegeben. Einige dieser Verfahren sind technisch unerlĂ€sslich, andere kommen nur mit Ihrer Zustimmung zum Einsatz, eine Anpassung ist in den die Cookie-Einstellungen möglich. FĂŒr Details siehe die DatenschutzerklĂ€rung
