Jump to content
Primavera Quatrini M200 Top speed only
Recommended Posts
Looking or help with two engine builds. Working on building a Small frame and Large frame engine for top speed only in a straight line. The top speed should be reached within 3 miles. So i am trying to find the Tallest gearing possible and if the chosen kits will have enough Torque to pull the gearing
- Smallframe will have the Quatrini m200 cases and cylinder. Does any one have any Dyno info or where I could find more info? Also best exhaust for torque? And lastly does anyone know of a higher Primary gear than the 29t crimza?
I know these types of projects are costly but I want to also be as reasonable as possible price wise.
Thanks to anyone who can help point me in the right direction!
Link to post
Share on other sites
There you can find everything about the Quattrini M200:
https://www.germanscooterforum.de/topic/363166-quattrini-200-cc-smallframe/?page=432&tab=comments#comment-1069243518
I think for top-speed, you should not look for best torque. You should look for best power with a wide powerband.
Longest primary I know ist the DRT "PRIMARIA DRT/TOB z56-26 (2.15)":
http://www.drtdenis.com/catalogo/sottocat.htm DBE?idcat=215&catee=01
At which events do you want to ride it?
Edited by jolle
Link to post
Thank you for the links!
In september the scooter hopefully will be at Bonneville salt flats ;)
Link to post
20 hours ago, gertax said:
How fast du you want to go? And where can one do 3 mile top speed runs? :-)
As fast as possible. A real life run of over 100mph would be amazing.
You can do 3mile runs at the Bonneville Salt flats ;)
Link to post
vor 14 Minuten hat cvjosh folgendes von sich gegeben:
That should be a feasible task.
You should aim for about 45 rwhp (or more) at sea level, I'd guess. And depending on the rev range and gearing (the total final gear ratio is important, not so much die primary reduction), this can be achieved without a super long primary reduction, too. I've done it with a 2,65 ratio, for example (not an M200 engine).
Hopefully, one day I'll be riding at the bonneville salt flats, too!
Link to post
Thanks for the insight!
what did you hit 100mph with if you don't mind me asking?
Link to post
Just a calculation example:
primary ratio = 2,15
ratio 4th gear = 2,3-2,4
3.50-10" wheel circumference = 1,3m
max rpm. ~10500rpm
--> 99-104 mph
PS: For 100mph you don't need 45hp and more. Would be helpful, but isnt' needed.
There are several racing teams which hit the 95-100mph in Magny-Cours (France) with about 35hp and M200 engine. :cheers:
Edited by FalkR
Link to post
Gerade eben hat cvjosh folgendes von sich gegeben:
You're welcome! If you have not done it already, it will be probably useful to make an excel sheet with all the gearing and tire options.
There are several of my scooters with different setups capable of 100 mph. Although, I had to hurry, as most of the time I had only a quarter of a mile to accelerate.
Some pictures and further technical information can be found in my advent calendar
  • Haha 1
Link to post
vor 7 Minuten hat FalkR folgendes von sich gegeben:
You are right, 35 does the trick. But keep in mind that Bonneville is at an elevation of ~1300m, so I would target 45 in order to have ~38 available at the salt anytime (and 3hp as a backup, as being stuck at 99,7mph would suck).
Link to post
Yea this is what I have stuck in my mind. I know bikes will go over 100mph on a drag strip or on perfect tarmac. The rolling resistance of the salt is something myself and my buddy which i am working on the project with are heavily keeping in mind.
Also paring the cylinder with the correct pipe to keep the Power band as wide as possible as to not have loss of speed if we fall out of it in too short of time.
Link to post
vor einer Stunde hat FalkR folgendes von sich gegeben:
.... aaand: Those engines are NOT built for top speed!
They are built for fast turns on short racetracks.
Link to post
You are losing power because of the reduced air density.
BUT: You lose drag through the reduced air density as well.
I made a rough calculation a while ago for a certain engine and scooter. On paper it had the same maximum speed like in sea level conditions.
But the biggest uncertainty is the salt, Josh, do you have any reliable sources regarding slip and friction?
My goal would be to reach as much HP as possible. With a broad powerband and overrev capability
Link to post
3 hours ago, gertax said:
Seems like something in between 2 and 5 HP for rolling resistance @ 100 mph on salt can be estimated
https://www.hayabusa.org/forum/threads/formula-for-calculating-rolling-resistance.8937/
Thank you for the LINK! I was looking for some fixed details about the calculations needed for the salt.
Now I am thinking that trying to achieve 45-50hp would put us in a safe place regardless of the salt conditions.
moving on from this though I will have to work out the gearing and figure out which clutch will hold the 50hp with out exploding.
Link to post
Maybe interesting for your project:
M200 - exhaustport 195deg, transferports 127deg
Stock Quattrini crankshaft 56.5mm stroke
35mm PWK Airstriker Carburetor
Vespatronic ignition
M200-Race exhaust
The dip @6000rpm was the wrong carb needle Setting.
Edited by FalkR
Link to post
vor 11 Stunden hat cvjosh folgendes von sich gegeben:
In case you would like to take the shortcut, engine wise, an @egig 250 engine would be just perfect for your demands. They are ready to run and come with about 50 rwhp and all components strong enough to keep everything together. And there is potential for more hp (Erich managed to reach 70), whereas on the M200 I do not recall having seen anything above mid 50ies, hp wise.
Link to post
M200-Race exhaust
@FalkR thank you for sharing the  info! It is extremely helpful :)
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
By using the GSF you accept our Privacy Policy and our Guidelines.
