I am about to drill some holes in my GS piston for 133cc cylinders.
I do not really know if it is really worth it, I want your opinion...
The goal is to use the idea behind the "Malossi Patent" to help cool down the piston and reduce gaz inertia...
I want to drill 4 holes in green, and also maybe some holes in red in front of the transfers of the 3rd port (or lateral ports ?)
:-D:-D
Bearbeitet von KTy
The green holes won´t work on a Polini, unless you grind the cylinderwall above the boostports about 2cm upwards. Instead of the red holes i would put in one large hole (like the original Polini).
I´ve done it this way on my Polini:
For which cylinder? Malossi or Polini? If Polini: I just copied the original Polini boostport window:
Concernig the CVF holes: I didn´t do that for several reasons, one being just lazy. But I´ve seen several examples where the holes where cut.
i personally believe the cvf thing was more of a marketing measure than a true performance must. i can't remember seing a single other two-stroke piston which has it, and unless i'm mistaken, even malossi has dumped it on anything but their oldest designs, that's their vespa stuff. no idea why one would want to spend time and effort on that. as far as i remember bbg has proven that a polini is good for 24 brake or so (at comparatively low rpm), which, in my book, equals a pretty high bmep, hence i guess that even more power would be possible at slightly higher rpm.
Thanks for the replies.
The base was a Polini 133.
AFAIK, I do not really need a window in my piston to feed the 3rd transfer because of my engine configuration. Right ?
However, I wanted to drill these holes for better cooling, by continously renewing the gaz under the piston head... But it does not seem to be so popular... :-D
My piston already looks like this:
http://ktylife.free.fr/vespa/KTy133/KTy134...Pr%e9par%e9.jpg
Could it be bad (for pre-compression for instance) if I drill the "green" holes (as previously proposed) ?
Or to put it shorter, what else could I do to improve perf. and/or reliability ? A big 3rd transfer window and smalls holes between transfers for lubrification ? Useless/Waste of time ? :-D
Bearbeitet von KTy
Right. No additional bostport windows needed.
Cooling, hmm. I don´t know. I think it´s vain endeavour, because Polinis usually are thermically rather stable anyway.
For Malossi cylinders some people adapted drilled these CVF holes. e.g.: JOB´s piston
go jet that thing until you're sure it's absolutely perfect
sounds good to me.
have you had it on a dyno yet? maybe it is pretty powerfull as it is already. and keep in mind that for esc racing you may not want max power in the first place anyway.
No dyno yet.... :-D
Exactly, if I am wondering about all this, it is mainly for reliability...
Ok, I guess I will let it this way ;)
I hope I can make it to the ESC Class2, I will have to operate my fuffi in my 1,5x2m cellar !! :-D :-D
If not, Class 5 :-D
The 2 holes above the window are aligned under the rings "spigot", rigth ?
The purpose is cooling of the cylinder wall ? :-D
Yes for cooling. But if it is needable on the "intake side", I don´t know.
Normally you drill it on the "outtake side" because it´s the hotter one.
Bearbeitet von absolut
Yes, I have 4 of them on the exhaust side. I´m not sure, how good they work,bBut at least several stock pistons have them, too. So at least it´s for salvation of consciences.
And the lubrication holes are positioned at the studs, being the preffered position of heat seizure.
Bearbeitet von broz666
    • Du liest also irgendwo im Internet  irgendeine Behauptung. Um welche Quelle es sich handelt und ob diese belastbar oder vertrauenswürdig ist, scheint für dich erstmal keine Rolle zu spielen.    Du nennst diese Quellen auch nicht, gibst mir/uns also auch nicht die Möglichkeit, mir/ums zur Vertrauenswürdigkeit eine Meinung zu bilden. Behauptest also einfach palkativ etwas.   Im Internet steht auch, das Reptoloiden die Weitherrschaft an sich reißen. Eine Elite in dunklen Kellern Kinder gefangen halten, um sich über deren Blut zu verjüngen. Ist das jetzt deiner Meinung nach eine realistische Wahrheit, weil es im Internet behauptet wird? Reicht dir das tatsächlich für eine realistische Option? Versuchst du tatsächlich nicht, Dinge zu verifizieren?   Mach und  denke, wie und was du willst. Aber plakatiere diese hirnlose Grütze dann nicht an die Wand.
    • Es gibt Behauptungen, das "Russland den in der Ukraine seit 2014 herrschenden Bürgerkrieg" beenden will. Es gibt auch die Ansicht, das es in der Ukraine keine freien Wahlen gegeben hat obwohl es an der Zeit war und es deswegen eine Diktatur ist.. Mal als Beispiel. Man kann im Netz oder bei unterschiedlichen Nachrichtenportalen die unterschiedlichsten und skurrilsten  "Fakten" nachlesen, aber welche davon stimmen wirklich? Welche "Inhaltslosen plakativen Behauptungen" meinst du? 🤔😘
    • Moin,   ja, das habe ich auch mehrfach gecheckt. Der steht in der richtigen Position
    • Werd da jetzt mal auf 4 oder 6mm² gehen und bessere Stecker verwenden..
