T5 Tuning, but what parts? :rotwerd:
Hello, I'm going to buy the tuning to my T5 engine. But is not sure exactly what parts I should buy another. Therefore, I need some help! :-D
Here is a list of what I have tengt! but is there anything I should replace? making suggestions!
Anlagen: Ns-R T 5 Drehmoment (NordSpeed)
Carburetor: MIKUNI TMX 30, flat
Cylinderhead: MMW
Cylynder: 172 malossi
Manifold: EM 1 (NNW1)
Clutch: Cosa FL II, 21
crankshaft: Longstroke Vespa T5 WORB5 special lip, 56,5mm stroke, con rod 104mm excentric pin Link: http://www.sip-scootershop.com/EN/Products/46050000/Longstroke+crankshaft+Vespa+T5.aspx
Reed: Membrane "Vforce 3" TASSINARI
What are you think? is it somthin I should buy? :-D
//Claus Henrik
I think your list of tuning parts, seems to be use tu build a powerfull race engine and not a " everdaytoworkdriver". I am with maniac. The first step is to answer the question:
For what kind of use, I want to build this machine.
Best regards,
Phill
Bearbeitet von Phill_Walker
The question is, what sort of engine do you want? Depending on that different tuning equipment is needed.
I guess you want a fast street engine, which is good for touring as well?
Yes, a fast street engine!! And it should be able to wheelie :-D :-D :-D
Bearbeitet von ClausFox
Tom: Do you have to modify the engine casing for your crankshaft?
Sure, especially the LIMA half
I'd buy a CNC clutch, MMW, S&S or K&G
But have they 21 cogs? Does not hold the reinforced cosa clutch'n? :-D
But beware of the replika cosa clutches, which are sold everywhere.
I'd rather buy a CNC one. You'll never have a clutch problem again. They are available as 21, sure thing.
Okay, then I will do it! but do you know where I can buy this? link? :-D
Okei, da skal jeg gjøre det! men vet du hvor jeg får kjøpt denne? link? :-D
wrong language?
MMW clutch
S&S clutch
K&G clutch
The first two are only outer baskets. The third one is a complete reconstruction.
If you buy a CNC outer basket, be sure to use only original PIAGGIO parts like clutch baseplate, clutch cog ...
I have the MMW clutch baskets in two ESC Race engines, never had a problem...
Okay, Thank you Thank you! :-D
@Uncle: cool, as expected! How many have you made?
@Claus Fox: you cannot compare these cranks, apart from the stroke, the crank of uncle is made from scratch and not just a modified original one!
Grüße
Hannes
Bearbeitet von Phantomias
Grüße
Hannes
Okay i see. But crank is not just a modified original one? http://www.sip-scootershop.com/EN/Products/46050000/Longstroke+crankshaft+Vespa+T5.aspx
Okay, thank you! But is it just bolt on the crank? or do I need to do some updates get it to fit?
and "Uncle" what is the cost? but I must move Cylynder up with gaskets? And I must have Reed-Valve In order to get it to work?? :-D
you can´t drive 62mm stroke with a standard 172 malossi!
57mm is maximum for good road-timings (depends on the exhaust of corse)
Basti
Basti
Okay, but then I move up cylynder? but should I use Packing cylinder base (aluminum) to build it up?
you will not get good timings! you have to weld the cylinder up at the top!
Okay :-D There are a lot of work and difficult
56,5 stroke with rotary intake is good enough for more than 30 HP. should be enough, i think!
if you want to usw reed valves, it´s cheaper to modifie a 57mm PX200 crank.
Basti
my cranks cost 390?... i dont think that it is cheaper to take a PX200 crank oder T5 modified "Glump"..... :-D
