Hi all,
I've got an issue with the clutch in my KingwelleBFA 244 engine.... 45bhp...
The clutch keeps on slipping. (mainly when powerband hits in 4th gear now)
I've tried various springs and oils.
Currently I'm using BGM Superstrong racing red cork plates with 10W-50 Malossi oil... Springs are 5XL and 5L from SIP.
Any suggestions for making the clutch stop slipping?
Any tips highly appreciated! :)
vor 12 Stunden schrieb M245:
Did you try Castrol MTX 75W-140?
smells like puke but it used to help sometimes
Brilliant M245!
I have a few bottles of MTX 75-W140, so I'll test that.
The cork plates has only done about 2km, so I'll try to "flush" the gearbox with 75-140 a few times and see if it works.
-if not, it is yet another set of new cork plates....
As said I'm using BGM Superstrong Racing Red plates at the moment.
-any suggestion for other(better) plates?
Rgrds
Ø
Why don‘t you use all 10 springs in XL spec?
BGM friction plates are fine, no issues here.
Bearbeitet von Evorox
Am 1.6.2025 um 12:56 schrieb Evorox:
Didn't have available, but ordered full set of XL springs now....
And it slips like h#ll again....
-with 75W140 oil....
Could it be the plates "contaminated" with old oil or?
I have new plates and XL springs on the way, but not sure if that is sufficient.
Anyone using GP-one clutch with 45bhp without slipping?
-what setup of springs and oil are you using?
Last attempt before going for another clutch.
vor 11 Minuten schrieb vespazieren:
Why dont you ask manufacturer Gernot from GP One...?
I’ve asked, and his suggestions/tips doesn’t work/help…
-unfortunately.
He’s been helping as good as possible, But seems like the BFA has «too much» power for the clutch…
With stiffest possible springs it works, I‘m using only 4 disc BFA clutches, same BGM friction plates and stiffest springs available and having zero issues even not using MTX oil.
I have a more than 10 year old GP one: mine had the issue that the springs were not compressed enough to supply sufficient force. So i made myself shims to press on the domes.
But if you need a shim or not depends on the start length of your spring.
vor 20 Stunden schrieb Svint1:
Had exactly that issue. The old plates are still filled with the old oil and soaked with that. I bought new ones and had no slipping after that. But with Castrol MTX. MTX did help with non slipping plates. Avoid using Big Ear with MTX, I had sticking plates with that, I needed to pull the clutch and kick slowly to loosen them up. Was anoying so I used other really old NOS plates from MECEUR, or how they were called :laugh:
You could try Egigs 6 plate clutch with the BFA. 45hp are really not that easy for any clutch :laugh: but the 6 plate should be able to do that.
Am 3.6.2025 um 07:22 schrieb Tim Ey:
Probably the same challange with my clutch, as it appers that the springs is a bit short...
Anyhow, 6 disk clutch from Egig is on the way and hopefully readily installed for the rally next weekend....
    • Also die Dame hat sich auch gewundert, aber dort wird wohl dann doch nur geschaut ob die Nummer gesperrt ist oder danach gefahndet wird. Wohl auch auf europäischer Ebene.
    • Beschreibung: Verkaufe eine neue und unbenutzte Pinasco Kurbelwelle für die T5. Link vom Scooter Center: Kurbelwelle PINASCO Racing HPC für Vespa T5 125cc - Drehschieber, 52mm Hub, 105mm Pleuel Preis:  200€ Standort: Regensburg [Bitte Durchlesen und anschließend den diesen Erklärungstext löschen, wenn ihr eure Verkaufsanzeige fertig habt]   Verbindliche Regeln für den GSF-Marktplatz ab September 2024 Wir bitten wir euch um die Einhaltung der GSF-Marktplatzregeln, insbesondere der P.O.R.N.O.-Regeln: Preis angeben! Inserate mit Auktionscharakter werden ausgeblendet. Ort angeben! Selbst wenn ihr im Profil einen Wohnort stehen habt, der genaue Artikelstandort (gemeint ist die Stadt) ist Pflicht.  Richtig und vollständig beschreiben! Idealerweise mit Bildern, eventuelle Mängel müssen deutlich im Text ausgewiesen werden. Keine Links auf andere Verkaufsplattformen. Nur sachliche Diskussionen! Destruktives Runtersprechen von Anzeigen und Preisvorstellungen, Runterputzen und Stammtischgerede ist nicht erwünscht.   Ohne klare Eigentumsverhältnisse kein Verkauf! Der angebotene Gegenstand muss Eigentum des Topiceröffners oder der Topiceröffner muss durch den Eigentümer beauftragt sein, den Artikel im Auftrag zu verkaufen. Bei Verstoß gegen diese Regeln werden Inserate ohne Vorwarnung ausgeblendet, ebenso unseriöse oder grob unvollständige Inserate! Pro Mitglied und Rubrik (Biete/Suche/Tausche) ist nur ein aktives Inserat im GSF-Marktplatz erlaubt! Ausnahme: Für Artikel über €1.000 (z. B. Komplettmotoren) oder Teilesammlungen darf ein weiteres eigenständiges Topic eröffnet werden. Im Fall von Teilesammlungen jedoch nur, wenn diese ausschließlich en bloc zu einem Paketpreis über €1.000 angeboten werden. Hinweise für Inserierende Das pushen/hochschieben von Inseraten ist nur alle sieben Tage gestattet. Wenn ihr Infos nachtragen möchtet, macht das im Startbeitrag. Hinterlasst nach Abwicklung euer (hoffentlich positives) Feedback. Um Topics schließen zu lassen, ändert ihr den Titel im Startbeitrag auf "ERLEDIGT: alter Topictitel". Damit werden die Moderatoren aufgefordert, das Topic zu schließen. Allgemeine Hinweise Fair use! Wiederholungstäter_innen werden verwarnt bzw. temporär gesperrt. Achtsamkeit ist angebracht! Nicht alle Blechrollerfahrer_innen handeln redlich, anständig, und nach Treu und Glauben (gilt bei Kauf und Verkauf). Lasst euch stets eine verifizierbare Telefonnummer und Anschrift eurer Geschäftspartner geben. Schafft Transparenz, kommuniziert per Privatnachricht! Wann wurde überwiesen? Ist das Geld angekommen? Wann wurde versendet (Link zur Sendungsverfolgung)? Ist alles angekommen und im erwarteten Zustand? Der Betreiber des GSF ist nicht verantwortlich für die Richtigkeit der Angaben über die angebotenen Gegenstände. Wer private Geschäfte über das GSF abwickelt, gewinnt daraus kein Recht, die Plattform GSF für seine privaten Probleme, Strafverfolgung, Zeugenschaften und/oder Meinungsmache gegen Mitglieder oder Shops zu missbrauchen. Grundsätzlich sind dem Betreiber des GSF Realnamen, E-Mail- oder Postadressen nicht bekannt. Mit der Nutzung des GSF-Marktplatzplatz gelten diese Nutzungsvereinbarungen als anerkannt.
    • https://ape-fans.de/viewtopic.php?t=23231   Hier, Ape mit Egig... Einfach anmelden...
    • Die Frage wird dir so auch keiner beantworten können, da es immer subjektiv ist. Je nachdem wie mal das Teil dann tritt oder eben nicht, kann das ewig halten oder nach paar tkm die Grätsche machen.    Als Schwachstelle haben sich die Ausgänge der Halbachsen gezeigt. Da kanns schon vorkommen das die bei richtig Leistung einlaufen. Dort Buchsen zu setzten ist aber nicht so schwierig, wenn man den nötigen Maschinenpark hat.   Kenne selber eine APE mit Egig170 die schon ein paar tkm hält ohne das was modifiziert wurde am Gehäuse oder Getriebe.  Die wird aber auch nicht auf ultimo getreten, sondern normal gefahren im mittleren Drehzahlbereich.
