Vespa T5 172cc but what reed?
Hallo, werde ich versuchen, hier zu posten.
Ich habe eine Vespa Popolino mit T5 mit 172cc.
Aber jetzt ist es getrimmt mehr! Der Plan war, haben
http://www.sip-scootershop.com/EN/Products...t+Vespa+T5.aspx
Dies und eine Mikuni TMX 30, aber der Reed-Ventil sollte ich wählen? http://www.sip-scootershop.com/EN/Products...+PXT5+30mm.aspx this maby?
//Claus Henrik Sc :-D
Bearbeitet von ClausFox
welchen auspuff willst du fahren ?
Hmm, I have a JL 2000plus auspuff
Du wirst wohl mit der linken Pedale gegen den Körper stoßen, vllt. paßt ein anderer Auspuff besser?
Tut mir leid, konnte ich mir nicht verkneifen :-D
Okei, was ambufaler Sie? :-D
okei, was ambufaler Sie? :-D
MMW2 doesn´t fit on T5, because of the short intake! You will need the MMW1.
Basti
Basti
Okay! Danke! Ist die SIP haben? Link? :-D
yes the tassinari fits with some small modifications with the "dremel", but its not much.
Okei, Do you think it is better? with the reed ? :D
i think the tassinari is better, because of more power:)
but the tassinari is more expensive than the normal reed.
Better for sure. But I´m not sure if you´ll gain much benefit with your setup.
Okei :-D Thank you! then I know what to save up to now! :-D
Why? What would you choose? :-D
Don´t get me wrong. Your setup ist OK. And if the per capita income really is twice as big in Norway as in Germany, as recent studies say, the Vforce is a good buy. :-D
Plus if you upgrade to a up-to-date pipe (e.g. Nordspeed) one day, your setup will fit perfectly. At least almost as you might want a bigger carb when going for maximum performance.
Bearbeitet von Brosi
