Hi all,
I've got an issue with the clutch in my KingwelleBFA 244 engine.... 45bhp...
The clutch keeps on slipping. (mainly when powerband hits in 4th gear now)
I've tried various springs and oils.
Currently I'm using BGM Superstrong racing red cork plates with 10W-50 Malossi oil... Springs are 5XL and 5L from SIP.
Any suggestions for making the clutch stop slipping?
Any tips highly appreciated! :)
vor 12 Stunden schrieb M245:
Did you try Castrol MTX 75W-140?
smells like puke but it used to help sometimes
Brilliant M245!
I have a few bottles of MTX 75-W140, so I'll test that.
The cork plates has only done about 2km, so I'll try to "flush" the gearbox with 75-140 a few times and see if it works.
-if not, it is yet another set of new cork plates....
As said I'm using BGM Superstrong Racing Red plates at the moment.
-any suggestion for other(better) plates?
Rgrds
Ø
Why don‘t you use all 10 springs in XL spec?
BGM friction plates are fine, no issues here.
Bearbeitet von Evorox
Am 1.6.2025 um 12:56 schrieb Evorox:
Didn't have available, but ordered full set of XL springs now....
And it slips like h#ll again....
-with 75W140 oil....
Could it be the plates "contaminated" with old oil or?
I have new plates and XL springs on the way, but not sure if that is sufficient.
Anyone using GP-one clutch with 45bhp without slipping?
-what setup of springs and oil are you using?
Last attempt before going for another clutch.
vor 11 Minuten schrieb vespazieren:
Why dont you ask manufacturer Gernot from GP One...?
I’ve asked, and his suggestions/tips doesn’t work/help…
-unfortunately.
He’s been helping as good as possible, But seems like the BFA has «too much» power for the clutch…
With stiffest possible springs it works, I‘m using only 4 disc BFA clutches, same BGM friction plates and stiffest springs available and having zero issues even not using MTX oil.
I have a more than 10 year old GP one: mine had the issue that the springs were not compressed enough to supply sufficient force. So i made myself shims to press on the domes.
But if you need a shim or not depends on the start length of your spring.
vor 20 Stunden schrieb Svint1:
Had exactly that issue. The old plates are still filled with the old oil and soaked with that. I bought new ones and had no slipping after that. But with Castrol MTX. MTX did help with non slipping plates. Avoid using Big Ear with MTX, I had sticking plates with that, I needed to pull the clutch and kick slowly to loosen them up. Was anoying so I used other really old NOS plates from MECEUR, or how they were called :laugh:
You could try Egigs 6 plate clutch with the BFA. 45hp are really not that easy for any clutch :laugh: but the 6 plate should be able to do that.
    • Würde ich am Stück verkaufen. Einzeln kann sein, das du nach Monaten/Jahren immer noch Teile rumliegen hast.
    • Die Orangenhaut-Lackierung sieht für mich original aus auch die abgeklebte Nummer. Luigi hat sich da nie Mühe gegeben. Sieht man ja nicht.......
    • Dann würde ich eh ein anderes Fahrzeug nehmen, und nicht so etwas seltenes.   Ne normale 50 R, 50 N  oder 50 L tuts für Tuning auch. Für mich wäre das so, als wenn man in eine 1947er V98 einen Cosamotor einbauen würde. Läuft dann ja auch schneller.   Duck und weg......
    • Your Scooter is not a 50s ((Smallframe). You have a Largeframe.
    • Hello, I'm looking for a hella taillight like this, maybe if anyone wants to sell I am very interested in buying it. certainly good condition and original. Thanks   Ich bin auf der Suche nach einem hella Rücklicht wie dieses, vielleicht, wenn jemand zu verkaufen, ich bin sehr daran interessiert, es zu kaufen. sicherlich guten Zustand und original. Danke     [Bitte Durchlesen und anschließend den diesen Erklärungstext löschen, wenn ihr eure Verkaufsanzeige fertig habt]   Verbindliche Regeln für den GSF-Marktplatz ab September 2024 Wir bitten wir euch um die Einhaltung der GSF-Marktplatzregeln, insbesondere der P.O.R.N.O.-Regeln: Preis angeben! Inserate mit Auktionscharakter werden ausgeblendet. Ort angeben! (für Verkäufe) Selbst wenn ihr im Profil einen Wohnort stehen habt, der genaue Artikelstandort (gemeint ist die Stadt) ist Pflicht.  Richtig und vollständig beschreiben! Idealerweise mit Bildern, eventuelle Mängel müssen deutlich im Text ausgewiesen werden. Keine Links auf andere Verkaufsplattformen. Nur sachliche Diskussionen! Destruktives Runtersprechen von Anzeigen und Preisvorstellungen, Runterputzen und Stammtischgerede ist nicht erwünscht.   Ohne klare Eigentumsverhältnisse kein Verkauf! Der angebotene Gegenstand muss Eigentum des Topiceröffners oder der Topiceröffner muss durch den Eigentümer beauftragt sein, den Artikel im Auftrag zu verkaufen. Bei Verstoß gegen diese Regeln werden Inserate ohne Vorwarnung ausgeblendet, ebenso unseriöse oder grob unvollständige Inserate! Pro Mitglied und Rubrik (Biete/Suche/Tausche) ist nur ein aktives Inserat im GSF-Marktplatz erlaubt! Ausnahme: Für Artikel über €1.000 (z. B. Komplettmotoren) oder Teilesammlungen darf ein weiteres eigenständiges Topic eröffnet werden. Im Fall von Teilesammlungen jedoch nur, wenn diese ausschließlich en bloc zu einem Paketpreis über €1.000 angeboten werden. Hinweise für Inserierende Das pushen/hochschieben von Inseraten ist nur alle sieben Tage gestattet. Wenn ihr Infos nachtragen möchtet, macht das im Startbeitrag. Hinterlasst nach Abwicklung euer (hoffentlich positives) Feedback. Um Topics schließen zu lassen, ändert ihr den Titel im Startbeitrag auf "ERLEDIGT: alter Topictitel". Damit werden die Moderatoren aufgefordert, das Topic zu schließen. Allgemeine Hinweise Fair use! Wiederholungstäter_innen werden verwarnt bzw. temporär gesperrt. Achtsamkeit ist angebracht! Nicht alle Blechrollerfahrer_innen handeln redlich, anständig, und nach Treu und Glauben (gilt bei Kauf und Verkauf). Lasst euch stets eine verifizierbare Telefonnummer und Anschrift eurer Geschäftspartner geben. Schafft Transparenz, kommuniziert per Privatnachricht! Wann wurde überwiesen? Ist das Geld angekommen? Wann wurde versendet (Link zur Sendungsverfolgung)? Ist alles angekommen und im erwarteten Zustand? Der Betreiber des GSF ist nicht verantwortlich für die Richtigkeit der Angaben über die angebotenen Gegenstände. Wer private Geschäfte über das GSF abwickelt, gewinnt daraus kein Recht, die Plattform GSF für seine privaten Probleme, Strafverfolgung, Zeugenschaften und/oder Meinungsmache gegen Mitglieder oder Shops zu missbrauchen. Grundsätzlich sind dem Betreiber des GSF Realnamen, E-Mail- oder Postadressen nicht bekannt. Mit der Nutzung des GSF-Marktplatzplatz gelten diese Nutzungsvereinbarungen als anerkannt.
