18.000km and 15 countries on a GS; part 1 preparations
Casings are sandblasted and put together again, engine almost done.
I used a special tool to mount the bearing for the crank:
Seal clutchside:
Casings ready to be put back together:
Always a nice view:
Engine back together only the clutch and ignition left to be mounted:
Unfortunately the engine has to be taken apart again because of a production error in the kickstart-thing.... I did finish the build and will split the engine after having driven some miles with it. So, technically it is pretty much finished, now I can run it in and test it and make it 'travel-ready'.
Oh .... gottya. You are pumping around 6000 euro in that bike and you are complaining about 100 bucks for a stylish glovebox
It is a GS4 Series 1!! I thought money is no big thing. You could have saved some good bucks if you had chosen a Sprint or anything of this ordinary models
Anyhow. Keep on keeping on :cheers:
with or without px-glovebox, the idea of taking a 60's scoot instead of a "modern-style"-px ist respectable. you always see scooterists, that have 20 vintage scooters in their private collection and take the px to join a scooterrun or making a long trip to anywhere.
i support your idea because its my style! :cheers:
Exactly my thoughts andreasnagy, I even swapped my original paint GS for a GS that had to be rebuild in order to be able to do this trip with a GS. An all original GS would have even been better, but in my current financial and time circumstances not realistic.
Where is the luggage?? We haven't started yet, just wait and see ;)
Yes I have a navigation system, it is a garmin zumo 220, and it works fine (waterproof and you can use it with your gloves on), I only have to find out whether I can charge it with my ignition or not.
    • es gab auch schon einen Bruch der Kabel direkt an der CDI... würde ich alles mit der Lupe untersuchen... eigentlich sind die Bauteile schon eher ganz weit vorne von der Qualität. Funken immer ohne Kerzenstecker testen. Sind gleich zwei Fehlerquellen weniger an Bord.
    • Ja das Ding lief bereits ca 1000km, eingewintert heute die Kiste aus der Garage geholt, kein Funken mehr... De Kabelbaum hab ich auch schin abgehängt, also nur ZGP und CDI dran.
    • Hi. Ich bin am Ende der Fahnenstange bei meinem SI24 angekommen. Ich bekomme die Kerze unter Volllast nicht in den „rehbraunen“ Bereich. Sie ist einfach blank.(siehe Bild1) Teillastbereich sprich Nebendüse/LLG ist alles tutti, schön rehbraun.   Zum Setup: -177er Malle Sport Alu -SI 24 -Polinibox  - Zündung 18 Grad -Quetschkante 1.1mm -Auer Venturi mit Airbox -8er NGK Langgew.   Maßnahmen am SI: Bohrung zur HD erst 2,5mm dann auf 3mm erweitert   Schwimmerkammerdeckel Superflow  (Deckel von Lemarxon) Sprich: Bohrung im Nadelsitz 3 mm Querbohrung über der Nadel 3 mm 5,2 mm Cosa Nadel mit 4,2 mm Köpfchen.   Fastflowhahn mit 55cm Schlauch.(läuft raus wie Hulle) Tankentlüftung in auch auf 3mm aufgebohrt.   Nun zum Verhalten: Roller läuft mit einer HD von 135 bis 145 top, aber Kerze bleibt blank. Mit einer 165HD merkt man das er zu fett läuft(viertaktet), aber Kerze bleibt blank. 200er HD ist die Kerze dann Ventablack (Bild2) und Roller nicht fahrbar. Also kurz gesagt, der Roller zeigt beim hochdüsen die erwarteten Reaktionen (viertakten), spiegelt das aber nicht im Kerzenbild wieder. Ok, ausser bei der 200er HD, aber das ist auch einfach komplett drüber😁 Hat jemand eine Idee? Würde es Sinn ergeben mal eine Kerze zu nehmen die eine kältere Betriebstemperatur hat? Vll. wird die 8er NGK zu heiss und brennt sich komplett frei/blank?   LG.
    • also das Ding lief bereits? Kein frischer Einbau. Die Bauteile einer VAPE und einer Pinasco lassen sich nicht kombinieren.
    • Hab ich noch einen, gerne PN   Sorry zu spät gelesen, dass der Polinist auch einen hat!
