P80x - DR135 - help please.
Hi,
     I am in Australia and have a P80X that I'm fitting DR135 kit to.
I only have Cylinder & Piston & Rings.
I am missing Gudgeon pin - is this a particular size? Length??
Also which way do rings go?
Bearbeitet von DannySPS
G‘day to the underside of the world!
Don‘t know the size of the gudgeon pin, but the L shaped ring ist the upper one with the opening of the L showing to the top.
If it helps, there is Goetz Neugebauer down there in AUS, search GN Classics on facebook. German origin, he is a very experienced vespa mechanic with his own business.
d.
According to this topic the pin of a Malossi 139 should als do, although it's a few mm shorter.
As you say you don't have a matching head, keep in mind that you can't/shouldn't run the kit with an original 80ccm head! Also be sure to use the DR pin circlips with round cross-section and not the original square type from the Piaggio piston. :blink:
d.
Thanks Everyone for your advise, I am just awaiting a cylinder head from Sip, and then it'll all be done and back to the customer :)
Cheers Danny
FB- DANIEL ROGERS
Scooter Preservation Society
Hi Guys,  So this build is finally complete. Could anyone advise a base  jetting to start please?   Sip 2.0 box, 24/24 carb  standard crank,gearbox,clutch
vor 4 Stunden hat DannySPS folgendes von sich gegeben:
Have a Look here;-):
http://lfs.alexander-hepp.de
