DannySPS Geschrieben 14. November 2022 Teilen Geschrieben 14. November 2022 (bearbeitet) Hi, I am in Australia and have a P80X that I'm fitting DR135 kit to. I only have Cylinder & Piston & Rings. I am missing Gudgeon pin - is this a particular size? Length?? Also which way do rings go? Bearbeitet 14. November 2022 von DannySPS Photo Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
dirchsen Geschrieben 14. November 2022 Teilen Geschrieben 14. November 2022 G‘day to the underside of the world! Don‘t know the size of the gudgeon pin, but the L shaped ring ist the upper one with the opening of the L showing to the top. If it helps, there is Goetz Neugebauer down there in AUS, search GN Classics on facebook. German origin, he is a very experienced vespa mechanic with his own business. d. Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
weissbierjojo Geschrieben 14. November 2022 Teilen Geschrieben 14. November 2022 https://www.sip-scootershop.com/de/product/kolben-dr-135-ccm_12180000?q=dr 135 kolbenbolzen Here you can see the Piston with rings, clips and gudgeon pin. I think SIP can send it to australia too. Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
nop Geschrieben 14. November 2022 Teilen Geschrieben 14. November 2022 According to this topic the pin of a Malossi 139 should als do, although it's a few mm shorter. As you say you don't have a matching head, keep in mind that you can't/shouldn't run the kit with an original 80ccm head! Also be sure to use the DR pin circlips with round cross-section and not the original square type from the Piaggio piston. Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
klugscheißer Geschrieben 14. November 2022 Teilen Geschrieben 14. November 2022 https://www.scooter-center.com/de/kolbenclip-15mm-x-1-25mm-g-typ-verwendet-fuer-z.b.-zylinder-polini-177-polini-133-dr133-dr177-1020022?number=1020022 Fits on a DR 177 thus it should also fit on a DR 135 because the piston is quite similar. But maybe it make sense to write them a short e-mail to be 100 % save. 1 Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
DannySPS Geschrieben 15. November 2022 Autor Teilen Geschrieben 15. November 2022 On 11/14/2022 at 4:16 PM, dirchsen said: G‘day to the underside of the world! Don‘t know the size of the gudgeon pin, but the L shaped ring ist the upper one with the opening of the L showing to the top. If it helps, there is Goetz Neugebauer down there in AUS, search GN Classics on facebook. German origin, he is a very experienced vespa mechanic with his own business. d. Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
DannySPS Geschrieben 2. Dezember 2022 Autor Teilen Geschrieben 2. Dezember 2022 Thanks Everyone for your advise, I am just awaiting a cylinder head from Sip, and then it'll all be done and back to the customer :) Cheers Danny FB- DANIEL ROGERS Scooter Preservation Society Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
DannySPS Geschrieben 24. Januar 2023 Autor Teilen Geschrieben 24. Januar 2023 Hi Guys, So this build is finally complete. Could anyone advise a base jetting to start please? Sip 2.0 box, 24/24 carb standard crank,gearbox,clutch Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
freerider13 Geschrieben 24. Januar 2023 Teilen Geschrieben 24. Januar 2023 vor 4 Stunden hat DannySPS folgendes von sich gegeben: Hi Guys, So this build is finally complete. Could anyone advise a base jetting to start please? Sip 2.0 box, 24/24 carb standard crank,gearbox,clutch Have a Look here: http://lfs.alexander-hepp.de Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
