px150
Hi,
interesting project you have going on, awaiting pictures.
My german is "nicht so gut", can you explain what is missing for this to be a complete engine? Will an ordinary (or treated) gearbox do the trick, or will this have to machined?
...turbojeger
  • 5 Monate später...
  • 9 Monate später...
  • 1 Jahr später...
  • 4 Monate später...
