PK backfire
Hello...i was wondering if someone can give me some advice...my PK is equipped with 133DR,Keihin PE24 (main jet 95, idle 48), original PK 12V ignition and flywheel, giannelli right hand exhaust and casings are just ported to match the cylinder and intake manifold(nothing too much)...i noticed in last few weeks that my PK backfires in low rpm(when i add a little bit of gas just so it revs up a bit for few times it backfiers strongly) i changed the other ignition also original from PK, bought new spark plug and it backfires again...at high revs it runs ok but sometimes at this low rpms it backfires and when i check the spark plug it is completly black...so i tried with idle jet 45 and did a little ride around town it still backfired but now the spark was a bit on the lighter side(leaner mixture)...now i ordered a brand new BGM pro CDI unit and will see how it runs with new CDI unit...but i just cant figure out what is going on???
Hi,
normally when I hear from backfire I think of defect pickups (that little black thing that generates the signal for your CDI). You can easily check for a broken pickup with a timing light just by activating it and looking on the motor.
the second thing could be extreme rich air/fuel. I am not firm with your carb, slow jet 42-45 should be good depending on the needle, main jet 95 sounds reasonable
best regards
Pickups are in great condition on both of my ignitions...i measured the resistance on them the way one of more experienced member of my club told me and they seem to be like new...PE is older version of PWK carbs i think...so i tried with smaller idle jets but turned out the mixture was leaner and the backfire was still present...so should i try and put a thicker needle or what?....now i am running on a pretty slim needle.
Do you know kyajet? http://www.kyajet.de/
Should help you with jetting.
The resistance of the pickup does not tell you the Full truth, because there more elements in it you can not measure with a simple ohm-meter. But as said, pickup can be checked quite easily with a timing light.
You can also disconnect the cable tree for testing purposes. Sometimes the green wire goes bad over the years and can make some weird shortcuts
Another remark:
Normally while checking the ignigition timing it should look like shown in the video (beginning 12:00) so the rotor should appear standing still or just lightly moving with the standard ignition. A broken pickup results in a more unpredictable and unstable appearance.
Back fire is when it bangs into your inlet and carb. If the gas bangs into your exhaust it´s after fire and your explaination sounds like after fire.
With a lot of smoke it looks like you have a very rich ratio when you close the throttle. If you have a leakage at your exhause system (flanges?) and you close the throttle oxygen comes into your exhaust gas and the hot exhaust will fire up the mixture of unburned gas and oxygen. That may also happen when there´s a leakage at the cylinder head.
    • Ist zwar schon ein alter Beitrag, da er mich aber fast davon abgehalten hätte die Box zu kaufen, muss ich eine Lanze für die Polini Box brechen: meine originale PX125 Bj 2011 läuft mit der Polini Box 10 km/h schneller als mit dem original Piaggio PX Lusso Auspuff, und hat gefühlt über das gesamte Drehzahlband mehr Druck (Bedüsung natürlich angepasst, auf 102-160-BE5). Bedeutet in Zahlen: Piaggio KAT: 90 km/h, wenn überhaupt Piaggio Lusso: 95 km/h Polini Box: 105 km/h Dass die 105 km/h laut Tacho in Wirklichkeit nur GPS gemessene 95 km/h sind, ist wieder ein anderes Thema Jedenfalls war ich positiv überrascht, wie viel die Polini Box bei einer ansonsten originalen PX125 bringen kann. Ich hatte sie eigentlich nur in Hinblick aus zukünftiges 177er Tuning besorgt..
    • Oh man ist das schwer, hier kein doofes Kommentar zu schreiben wie "benutz' mal die Suche", "es gibt ausreichend Topics dazu" usw.. echt schwer.. also wirklich schwer ist das..
    • Ich hab mir nun für unserer Kisten auch ein MTX-L Plus gegönnt und einen passenden Halter mit Magneten sowie 9Ah Batterie mit Koffer zusammengestellt.  Erste Testfahrt ist gemacht und hab mich für AFR Anzeige entschieden. Folgende Werte hat es mir angezeigt: Standgas 12.0 bis 1/2       13.8 1/2-3/4      17,0 Vollgas      13,2 Muss mich aber erstmal noch vertrauter machen, was mir da angezeigt wird.
    • Ich bin eigentlich total zufrieden mit der Egig Kulu, die trennt perfekt und läßt sich auch sauber bedienen. Meine egig Kupplung rutscht aber immer auf den ersten 3-4min (also bei kaltem Motor) durch beim vollen Beschleunigen… Wenn der Motor dann warm ist (also gut Gas annimmt) ist das weg, und die Kupplung funktioniert einwandfrei.   Zug-Einstellung kann ich ausschließen, da der Druckpilz (bei nicht gezogenem Kuluhebel) nicht am Ausrücklager anliegt, sondern sich erst bei ~2-3mm gezogenem Zug am Ausrücklager anlegt.   Habe schon versch. Öle getestet, aber immer das gleiche Problem. Fahre 500ml SAE30 (Runge / SIP / BGM) Getriebeöl. Habe auch schon MTX 75W140 getestet, damit war‘s etwas besser aber auch nicht weg, kann also m.M.n. nur ein mech. Problem sein…    Hat jemand schonmal sowas gehabt?   Alles vom Egig, also komplette Kupplung mit Innenkorb (6 Federn) und den mitgelieferten Kupplungsreibscheiben, und Egig-Primärkorb. Ich denke nicht, dass ich bei meinem Setup (170egig,30er Dello,Falkr Ares) alle 8 Federn brauche, und würde daher ungern die fehlenden 2 Federn dazubauen.
    • Mit der Verköstigung warte ich, bis Vaddern zu Besuch ist die Woche. Der ist der wahre Experte und dank viel Verwandten im Süden der Republik auch bewandert im Thema!
