GRIMECA NT FOR VESPA PK FORK?
HELLO!
This is the first one...
I write from Italy (I live near Maranello where Ferrari is built) and I?m registered on ET3.it forum.
I have 2 vespa: the first is a Vespa 50 L with a 144 Falc?s kit, the other is a Vespa 50 Special with 175 Falc?s kit (I know very well Lauro, a big teacher of 2 stroke engine!!).
Well?I want to ask to german people a question?
In Italy we don?t understand if the new Grimeca Nt kit can be mounted plug and play (without modification,alteration) on a fork of the PK vespa like rush, n, xls?
Some people said that only the Classic Grimeca kit set on the fork of the PK vespa like Rush?in fact some of them tells that after mounting the kit and after completely mount, when they squeeze very well the brake drum this remain braked and so the brake drum don?t rotate freely?
Maybe the problem is the length of the axis that support the brake drum, brake calliper..?
But on the web site of Sip scooter shop there is write that the kit can be mounted with the PK rush fork (PX EFL/T5/PK/XL/2) and the ?only problem? is that the shock absorber seating has to be slightly modified as PK models feature a different hole distance of the shock absorber.
Some of us have mounted the Grimeca Nt kit on a PK Rush fork? Please help Italian people because we don?t understand?the only thing that we certainly know is that the brake kit of the Vespa Millenium 98 (whit five-pointed star at the front) mounted on a Pk rush fork but is not in line (in center) for 3 mm with the axe of the Vespa.
Another question is if someone have mounted (and his opinion) the Malossi rs24 front suspension in his Vespa, and not the classic Bitubo that are to much rigid?
Thank you to all people that want help us!! :-D
Sorry for English!
Hello Italy,
it is possible to mount the new Grimeca NT kit on a PK Fork Rush.....
It is the same procedure like the PX Millenium Kit, including the 3mm displacement (i guess it has been the same with the Grimeca Classic, but you won´t notice).
Also it is possible to mount a RS24. I would recommend the S&S version, because this one is 18mm shorter, I am a link. It is usefull to have the shorter version, because the PK fork is 35mm longer compared to the original fork (dragster look).
Some GSF users tested the RS24 in the european scooter challange and it can be recommended.
Hope i could help :-D
AL
HELLO!
I write from Italy (I live near Maranello where Ferrari is built) and I’m registered on ET3.it forum.
I have 2 vespa: the first is a Vespa 50 L with a 144 Falc’s kit, the other is a Vespa 50 Special with 175 Falc’s kit (I know very well Lauro, a big teacher of 2 stroke engine!!).
Well…I want to ask to german people a question…
In Italy we don’t understand if the new Grimeca Nt kit can be mounted plug and play (without modification,alteration) on a fork of the PK vespa like rush, n, xls…
Some people said that only the Classic Grimeca kit set on the fork of the PK vespa like Rush…in fact some of them tells that after mounting the kit and after completely mount, when they squeeze very well the brake drum this remain braked and so the brake drum don’t rotate freely…
But on the web site of Sip scooter shop there is write that the kit can be mounted with the PK rush fork (PX EFL/T5/PK/XL/2) and the “only problem” is that the shock absorber seating has to be slightly modified as PK models feature a different hole distance of the shock absorber.
Some of us have mounted the Grimeca Nt kit on a PK Rush fork? Please help Italian people because we don’t understand…the only thing that we certainly know is that the brake kit of the Vespa Millenium 98 (whit five-pointed star at the front) mounted on a Pk rush fork but is not in line (in center) for 3 mm with the axe of the Vespa.
Another question is if someone have mounted (and his opinion) the Malossi rs24 front suspension in his Vespa, and not the classic Bitubo that are to much rigid…
Sorry for English!
Bearbeitet von spanier8877
Thank you for the answer!
For that reguard rear suspension Malossi RS 24 in italy we install the one for ZIP sp?we only change the lower fixing?and it?s very confortable!!!!
For that concern the front suspension I see on GSF forum that someone have mounted this suspension on the PK rush fork?because I want mount Malossi RS 24 n: M467900 and SIP in the description mention ?for Quartz,Zip sp and Pk?..
What we said of Bitubo? You use a spring difference from the original and less rigidity?
But isn´t it to rigid?
Yes, we use the RS24 model for Quartz,Sip, PK.
The version i posted is 18mm lower and custom made by "Scooter & Service Hamburg". Due too the lower center of mass it is improving your ride.
Thanks to DUST for using his picture!
Here you can see the shorter version mounted.
Regards AL
wow .. very beautiful Vespa ...
the zip sp is more low 18-mm right?
but there are problems with the fender and the distance Pk hole on the fork?
Bitubo for me are too rigid and there is not 'a spring replacement less hard ...
No, there is a Vespa shop in Hamburg called S&S, specialized in customised scooterparts.
The main porblem is, the PK Rush fork is 35mm to long (compared to a V50 fork), so the guys from S&S developed a kit to lower the Malossi 18mm.
-->PICTURE KLICK<-- and here where you can buy it-->S&S SHOP<--
Yes, you have to modulate the V50 fender and it is a lot of work to get it fixed with the PK fork + RS24. (my opinion)
Hope that´s fine for LENKI that i used his image. :-D
V50 fender fitted, normal length RS 24 mounted.
Greets AL
Ok..thanks to everybody?you are very usefull!!!
So I can mount Grimeca NT kit with no problem (but there are 2 mm on the left side..)..
However there is no problem like someone told (they teel that the brake drum remain braked and so the brake drum don?t rotate freely?)..it?s false?right? If you are sure that mount without problem I will do?
Therefore also on with the Classic Kit there are 3 mm on the left side??? In Italy no one said this..person said that is perfectly in line with the wheel axis? It?s new for me?
However I think I will mount Grimeca NT kit with whoop disc Malossi?someone can tell me if it?s good in braking? Or you uses Braking disc?
Also I will mount Rs 24 suspension...I think it?s better than Bitubo?this one it?s so hard for road way?
But I think I will mount an extension in the rear suspension for balance the 35 mm more long in the front of Vespa?
Bearbeitet von BERGO
What you say about Malossi whoop disc and Braking for Vespa? Wich of this is better?
Can I mount the ZIP Sp brake callipers with 32 mm enlarged brake piston or not??
For that reguard the brake pads..malossi mhr or other??
Thank you!!!
Thank you!!!
ZIP SP calipers can be mounted, BUT you will have to grind some material off the caliper and the bleeder screw will be on the wrong side, so you will have to turn the brake upside down for bleeding...
Regards AL
Frage zwischendurch, was ist das für eine Sitzbank?
Eigenbau?
Do you have a link to the Braking disc? I didn't know yet that they also offer a disc for Vespa...
Unfortunately I only have experience with the original disc. But for this racing season I think I will try the Galfer Wave Disc Link (If the link doesn't work: #101232)
braking is the same of gilera dna rear...
http://www.quartomotoricambi.it/catalog/pr...roducts_id=1019
code GLO1RID....price 30?...
code GLO1RID....price 30€...
The page says 70€ - but this can't be the right disc (240mm diameter). According to the Braking homepage it should be the "PI01FID" disc which costs 54,98€ on the german Braking homepage. Seems like a bargain...
The page says 70? - but this can't be the right disc (240mm diameter). According to the Braking homepage it should be the "PI01FID" disc which costs 54,98? on the german Braking homepage. Seems like a bargain...
SORRY..is PI01FID
see on biolla motors in Italy...30?..
http://www.biollamotors.it/catalog/disco-b...000-p-4856.html
    • Der Malossi 210 hat eine besondere Kolbendachform und dadurch ein leicht negative Quetschspalte. Dies ist aber  bewusst so gewollt. Sie hilft die hochbeanspruchte Ringzone des Kolbens zu kühlen und sorgt so für noch mehr Standfestigkeit des Zylinders.
    • Wenn alle Stricke reißen halt zu MB Design machen lassen, hätte die Bude quasi auch verdient. Gut und der Rest ist ja dann fast schon überschaubar.  Geil ich bin gespannt!
    • Heute kamen wieder 1,2… neue Teile.    Mein Plan war eigentlich, sie in der Farbe wie mein Auto zu lackieren:   Und deshalb habe ich den Lampenring wie folgt machen lassen:     Ja, der ist 24 Karat vergoldet.    Aber irgendwie reden mir echt viele ein, dass ich die Vespa so verzinkt Silber lassen soll    Bin mittlerweile echt hin und hergerissen.   Aber die genaue Oberfläche habt ihr leider noch nicht gesehen, man erkennt ja leider wo ich geschweißt und geschliffen habe    Alles nicht einfach mit diesem Tuuhhning…
    • Was du beschreibst hatte ich bei Erstmontage auch. Hatte den Eindruck das die einzellnen Komponenten sich noch setzen mußten. Nach ein paar tausend Kilometern hatte ich es nochmal zerlegt und da passte danach alles wieder gut zusammen.   Bei der Montage  bin ich anders vorgegangen. Die Drehung der Schwinge findet ausschließlich in der Lagerung im Schweingenrohrauge (also innen) statt. Die Außenlager sind halt da weil sie passen und günstiger sind als irgendwelche gedrehten und vergüteten Spezialteilen (kurzgefasste Aussage des Herstellers bei einem Telefonat). Eine Drehmoment Angabe kann meines Erachtens so nicht gegeben werden. Beim Festziehen wird das ganze "Lagerpaket" zusammengepresst. Die äußeren Lagerringe, die ja etwas Spiel haben können, werden mit den Distanz und Gummiescheiben an die Gabelrohraugenflanken gepresst beim Festziehen der beiden Druckteller. Das kann dann halt so fest sein das die Schwinge schwergängig wird.    Ich habs so gemacht: Der innere Teller (Bremstrommel/Scheibenseitig) mit Loctite "Endgültigfest" fest verschraubt und verklebt. Dann Lager bzw. Pressspiel auf der äußeren Seite einstellen so das die Schwinge Spielfrei aber nicht zu fest beweglich ist. Schraube natürlich vorher mittelfeste Schraubensicherung drauf. Von außen kann man jetzt gelegentlich kontrollieren ob die Schraube noch fest ist bzw. man sieht wenn sich da was löst.  Für die feste Verschraubung Bremsscheibenseitig habe ich mich entschieden da sich dort bei mir mal die Schraube gelöst hatte und es mir nur aufgefallen ist weil sie an der Bremsscheibe geschliffen hat. Bei Scheibenbremse kommt man an den Imbus eh nicht mehr ran im montiertem Zustand.   Hoffe das das Geschreibsel halbwegs verständlich ist.
