Front Dampers
Hi All, (sorry for the English)
a tech question, has anyone fitted Bitubo"front"dampers to their Lammy yet?
If so,what is the fitting arrangement', the Bitubos only appear to have one Bush fitting, the other (fork-link?) end is open . How do they attach to the fork-link stud?
You need to build your own forklink or make an adapter, because the holes in the dampers are to wide. It should also be a very strong holding device, because it has to sustain the energy of the spring. Do you want to use the original inner springs too? Because I am wondering what might be the best arrangement.
One of the Zottelzossen SA has fitted them to his P-Range with Lamyforks- try to contact him via Zossenwolf, who is member in this network , or via their web-site.
