Alle Inhalte von Stein
Das GS160 & SS180 Topic
Help needed on piston to cylinder clearance. *GS160 std cylinder with GOL piston. *SS180 SCK big bore 64.0mm cylinder with 60's Asso piston. What piston to cylinder clearance is correct for these two? Thanks in advance for the replies!
Thanks for the input! The outlet thingie from Grand Sport I have, so then I might try the Polini box. Grusse Stein
Does anyone of you have experience with using the Polini box for PX on GS/SS? Possible to mount? Needs cut and reangle of downpipe? All input appreciated! Thanks!
- Polini 221ccm für Vespa PX200
Seeking advice before converting from old Malossi 210 to Polini 221. Have S&S 62,5mm crank, casings optimised for this crank and Malossi 210. S&S reed inlet. 28mm keihin. Also have available 33mm keihin. Think 28mm is the better to use? Standard Lusso 200 gearing with T5 fourth gear. S&S silent exhaust for Malossi 210. I will optimise casings for Polini 221 cylinder and use a GS piston. Seeking advice on what gaskets to use on top/bottom of cylinder (someone told me a thicker than standard gasket on top is not possible on this kit??) with this setup with 62,5mm crank. Also seeking advice on gearing. I have a cosa style clutch so since the Worb5 ultra long gearing is quite expensive, I am thinking of using a 24t clutch center and 65 or 64t primary gear. Any thoughts about this? Thanks in advance for any input from anyone who have experience with this! Regards from Norway, Stein
Das ULTIMATIVE M.I.S.A. Belgien-Vespa Topic....
Hallo! Ich habe ein MISA GS 160 series 1 und soll das Vespa GS beinschildemblem aus Maskes montieren. Kann jemand mir mit das korrekte plasieurung hilfen? Vielen dank und grusse aus Norwegen!
20th Classic Scooter Run in Norway 1.-3. June 2018
Folks, time to make your booking so you don't miss out! Maximum 200 participants. Book here: https://www.classicscooterrun.no/2018/no/pamelding/
Hi! Do anyone know where I can get floorboard rubber for GS 160 that really fits and looks like original? All I have bought, ariete or others, are of wrong shape.. Thank you! Stein
Due to another big event taking place in the same area the same weekend, for those of you who are not up to sleeping in a tent, hotel room has to be booked at the soonest before every room is taken. Heres a list of hotels close by: -Soria Moria Hotel -Voksenaasen -Scandic Olympiatoppen Sportshotel -Lysebu -Trollvasshytta And then two that is about 5 kms away: Gaustad Hotel and Smestad Hotel. And could be worth checking out Airbnb as well. Greetings from Oslo, Norway Stein Overland
Ok folks, first band now confirmed. They played for us more than 10 years ago, now they are up for it again. If you like The Sonics, you will love to see and hear S T R Y C H N I N E Here's some teasers: https://www.youtube.com/watch?v=pp1XfBu27Y0 https://www.facebook.com/StrychnineSonicsTribute/
Finally, the annual Classic Scooter Run in Norway is back in Oslo 1.-3. June 2018 !!! Prepare for a smaller run than you are used to, but we offer you as always live bands, djs, bar and grill with sensible prices, dyno, ride outs and and and.. Camping on site, and hotel rooms nearby available. Heres the webpage: http://www.classicscooterrun.no/2018/ Facebook page: https://www.facebook.com/events/1953328151583445/ Heres some teasers from previous years: https://www.facebook.com/events/106793586143171/permalink/194069290748933/ https://www.youtube.com/watch?v=Oi470hwIv5w https://www.youtube.com/watch?v=qGHITeVawJY Enter your email at http://www.classicscooterrun.no/2018/ for info about booking etc. Welcome to Oslo!
Das superlow Gabel kürzungs Topic
Danke Kebra für dein antwort! Grusse Stein
Hallo! Mein umbau Cosa gabel in eine GS 150 rahmen hat jetzt zwei verschiedenen Winkeln. Ich denke, dies könnte zu einem nervösen Fahrhaltung und Vibrationen führen. Was denken Sie? Grusse aus Norwegen, Stein
Gearbox filled with petrol
Ok guys, thanks for all the feedback and suggestions! I will put on the original fuel tap, never had a good feeling about the SIP one anyway (have driven thousands of kms for more than 10 years on my 28 hp 210 with standard fuel tap, so should be good enough With a standard one on a mildly tuned T5 too). Will search casings for cracks, check my closing of the premix hole, check the seal surfaces and do a test on the carb needle. I am glad the scoot didnt turn into a burning inferno since I actually drowe it minutes prior to finding all the fuel in the gearbox, and yes, cleanest casings I have ever seen.
Aha, habe en such hier im forum gemacht und habe alles klar was zu machen.
Und wie macht man ein ballontest?
Thank you very much sammba for taking the time to reply to me!! I will take a closer look at the casings just to be sure there are no cracks. Also I did not use any extra sealant, only the paper gasket, but it might have been a too thin version, and also what you write about gasket out of possition makes sense. I will check further. I will also check the float needle in the ways you suggest. Thanks again, Stein
Hello! I just found 1 1/2 litre of petrol in my gearbox..!! Have any of you experienced something like this and know the cure? Here the facts: -Newly rebuild motor. -T5 autolube motor. -T5 original SI carburettor for autolube, but autolube is disconnected and closed by removing small gear by clutch, axle and closing oil tube inside carb housing. Oil channel in carb housing closed With glue. -New float needle. -Original valve inlet. -SIP fastflow fuel tap. Seems to Close/open correctly. Scooter have been hard to start and flows over. Have not managed to drive for more than 5-600 meters before it dies. It smells of petrol and it seems to be overflowing in some way. I first discovered that fuel was leaking out from mixer screw hole on the carb housing and whole top of carb was wet. I changed all gaskets and it seemed to be leaking much less, but strangely it was difficult to remove all leaking. Due to fastflow fuel tap, perhaps? Have tested for leaks with letting fuel tap stay both on and off overnight. Sometimes carb top have been dry, sometimes wet. Fuel have also been dripping from one of the T5 exhaust bolts, and I pressumed fuel was following the fuel line or so, but after checking I saw that connection of fuel tap to tank and fuel hose to fuel tap is tight and dry. It was wet of petrol on top of the gears schalter box, and I was more than supprised when I removed the box and petrol was flowing out. The petrol inside filled up 2 wine bottles! I assumed that it was via a damaged metal oil seal by the crank that the petrol found its way to the gearbox, but to my supprice when separating the motor yesterday, all seals looked to be like they should and I see no cracks in the casings. So, before I start pressure testing or throwing the casings away, I want to ask if anyone of you might know what is happening. Thanks in advance! Regards from Norway, Stein
Aufkleber streifen in gold für PX
Vielen dank für die antworten!!
Hallo leute! Ich suche für meinen braun lackierte P200 aufkleber streifen in gold für backen und kotflügel, aber kann keine die ich haben will am Ebay usw finden. Kennt jemand jemand das solche custom aufklebern machen kann? Vielen dank und grusse, Stein
Scooterist Meltdown 07.-09. Februar 2014
Thanks for the info, fab! I see that stampede have written that you have room for only one more in the bus. We are three, and we also arrive earlier than you on Friday and leave later than you on Sunday. But, if you have room for all three of us, it would be great to hear from you again! Thanks, Stein
Thanks for the info, Mareike! We will sort something out. Best regards Stein
Hi there! We are three guys coming from Norway to the run. Arriving DUS Düsseldorf Airport terminal 3 at 13.05 Friday and departing same airport Sunday at 19.05. If anyone have room for us in a car/bus to/from the run, we would be very thankful. Of course we will pay our share of the transport. Thanks a lot and see you there!!! Best regards from up north, Stein
