Wiring of SIP Speedo button in SIP conversion light switch
Hi!
Bought a SIP conversion light switch: https://www.sip-scootershop.com/en/products/light+switch+sip+conversion+_60091300 to get rid of the additional button for the sip speedo.
But there is no instruction on how to wire the cable from the button in to the switcn.
Anyone who can tell how to put the wire (the original wire for the sip button consist of two wire...)
Thanks in advance!
Rgrds
Øyvind
@dragonball had the same question - and added the information by SIP:
The white/black cable (I suppose of the speedo) should be connected to ground of the switch.
The black one is without use.
Brilliant!!
Thanks alot!!
Worked perfectly!
