PX SPECIAL LIP REEDVALVE CRANKSHAFT-JAPAN CONROD
Uploaded with ImageShack.us
HI all!!
i'm selling 2 new crankshaft, special lip for reed valve!
57mm stoke, one for px125 (rod length 105mm) and one for px200(rod length 110mm, but you can use it on px125 case with a 5mm base gasket).
The cranks are made from original old piaggio crank-webs. Only the webs are "old",all the other parts are new. "old" original piaggio crank were made with a good quality steel!!
-conrod are special conrod made for motorcicle (YAMAHA-CAGIVA-KAWASAKI....). "made in Japan". conrod have hole for lubrification and are made with quality material.
-they are finely balanced, and Balance factor is high for good tuning!!
-conrod pin is "high interference" so the crank will not turn with high power engine. each conrod pin is special made for each crank, and all dimension are carefully controlled.
you can use this crank on your PX casing without modification.
PRICE:
-PX200 VERSION 160EURO (INCLUDED SPECIAL PISTON BEARING!)
-PX125 VERSION 170EURO (INCLUDED SPECIAL PISTON BEARING!)
SHIPPING FROM ITALY TO GERMANY WILL COST 30 EURO
see below pictures
-PX 200 VERSION-
http://imageshack.us...4/imgp5205.jpg/
-PX 125 VERSION-
http://imageshack.us.../imgp5194e.jpg/
for any information, plase ask
I CAN ALSO MAKE SPECIAL CRANK FOR YOU, FROM YOUR IDEAS AND DESIRE!!!
if you like this crank shaft we can talk about the price!!!!!!!!!!!!!
