I have rebuilt my PX125E engine, since then, I have very few power at low rpm...
I have re-wired the stator, I have changed for a new SI24/24, ... nothing... I cannot have it work good at low rpm, it simply lacks power !!
So, I am starting to remember that the crankshaft that I changed was maybe not very well appropriate considering that the admission window on the case was not in excellent shape... On one side, the crank cheek is not striped but it is not clean either, and on the other side, the aluminum crank case admission has one little stripe...
All in all, I think the rotative valve is not working anymore...
So, the plan is to build a very simple reed valve system, like the LML one and to put it just below the carb... Does anyone ever investigate this ? I do not want to machine my engine cases as it is my daily rider, I just want to work out something with the carb and the air box... :-D
Mfg,
KTy
Mfg,
KTy
KTy,
I reckon it is not easy, if anyway, to achieve this without milling/modifying the cases AND not to get your carb up in mountainous regions.
I built an adapter to fit a Malossi reed valve with a Mikuni TMX. I imagine something similar, adapted to the LML reed and SI Carb, might work. It has got a height of 20 mil only. See picture
Edit adds some missing letters, f****g keyboard
Bearbeitet von minikin222
Very nice !
But as my engine is "stock", no high-end performance, I was thinking about something very thin, with one or two horizontal reeds, should be feasable in less than 10mm ! I am not looking for pure performances, I just want a better permitivity for the rotative valve admission system !
I will try to draw something... :-D
Here you go... View from the bottom...
The drawing is far from perfect bu basicaly the idea is that the reed(s) can bend into the existing admission window...
Bearbeitet von KTy
indian 150 ccm engines have such a reed inlet, I recall.
a guy in bremen once did this due to a worn crankshaft surface. just a piece of sheet metal and an old credit card :-D it work well, though.
Yup, that's what I want to do...
This is probably simpler and should do the trick...
Bearbeitet von KTy
@KTy: KIS-principle - good one, though the flow might be a bit crappy - but who bothers? as long as it worx
Exactly ! Check the updated drawing... I have put some angle, it's not much, but it's better than nothing !
Milling on the airbox side is acceptable even though it would be much better to come up with a simpler solution... I'm pretty sure you can fit the reed system in a 5mm-thick spacer...
    • Würde ich am Stück verkaufen. Einzeln kann sein, das du nach Monaten/Jahren immer noch Teile rumliegen hast.
    • Die Orangenhaut-Lackierung sieht für mich original aus auch die abgeklebte Nummer. Luigi hat sich da nie Mühe gegeben. Sieht man ja nicht.......
    • Dann würde ich eh ein anderes Fahrzeug nehmen, und nicht so etwas seltenes.   Ne normale 50 R, 50 N  oder 50 L tuts für Tuning auch. Für mich wäre das so, als wenn man in eine 1947er V98 einen Cosamotor einbauen würde. Läuft dann ja auch schneller.   Duck und weg......
    • Your Scooter is not a 50s ((Smallframe). You have a Largeframe.
    • Hello, I'm looking for a hella taillight like this, maybe if anyone wants to sell I am very interested in buying it. certainly good condition and original. Thanks   Ich bin auf der Suche nach einem hella Rücklicht wie dieses, vielleicht, wenn jemand zu verkaufen, ich bin sehr daran interessiert, es zu kaufen. sicherlich guten Zustand und original. Danke     [Bitte Durchlesen und anschließend den diesen Erklärungstext löschen, wenn ihr eure Verkaufsanzeige fertig habt]   Verbindliche Regeln für den GSF-Marktplatz ab September 2024 Wir bitten wir euch um die Einhaltung der GSF-Marktplatzregeln, insbesondere der P.O.R.N.O.-Regeln: Preis angeben! Inserate mit Auktionscharakter werden ausgeblendet. Ort angeben! (für Verkäufe) Selbst wenn ihr im Profil einen Wohnort stehen habt, der genaue Artikelstandort (gemeint ist die Stadt) ist Pflicht.  Richtig und vollständig beschreiben! Idealerweise mit Bildern, eventuelle Mängel müssen deutlich im Text ausgewiesen werden. Keine Links auf andere Verkaufsplattformen. Nur sachliche Diskussionen! Destruktives Runtersprechen von Anzeigen und Preisvorstellungen, Runterputzen und Stammtischgerede ist nicht erwünscht.   Ohne klare Eigentumsverhältnisse kein Verkauf! Der angebotene Gegenstand muss Eigentum des Topiceröffners oder der Topiceröffner muss durch den Eigentümer beauftragt sein, den Artikel im Auftrag zu verkaufen. Bei Verstoß gegen diese Regeln werden Inserate ohne Vorwarnung ausgeblendet, ebenso unseriöse oder grob unvollständige Inserate! Pro Mitglied und Rubrik (Biete/Suche/Tausche) ist nur ein aktives Inserat im GSF-Marktplatz erlaubt! Ausnahme: Für Artikel über €1.000 (z. B. Komplettmotoren) oder Teilesammlungen darf ein weiteres eigenständiges Topic eröffnet werden. Im Fall von Teilesammlungen jedoch nur, wenn diese ausschließlich en bloc zu einem Paketpreis über €1.000 angeboten werden. Hinweise für Inserierende Das pushen/hochschieben von Inseraten ist nur alle sieben Tage gestattet. Wenn ihr Infos nachtragen möchtet, macht das im Startbeitrag. Hinterlasst nach Abwicklung euer (hoffentlich positives) Feedback. Um Topics schließen zu lassen, ändert ihr den Titel im Startbeitrag auf "ERLEDIGT: alter Topictitel". Damit werden die Moderatoren aufgefordert, das Topic zu schließen. Allgemeine Hinweise Fair use! Wiederholungstäter_innen werden verwarnt bzw. temporär gesperrt. Achtsamkeit ist angebracht! Nicht alle Blechrollerfahrer_innen handeln redlich, anständig, und nach Treu und Glauben (gilt bei Kauf und Verkauf). Lasst euch stets eine verifizierbare Telefonnummer und Anschrift eurer Geschäftspartner geben. Schafft Transparenz, kommuniziert per Privatnachricht! Wann wurde überwiesen? Ist das Geld angekommen? Wann wurde versendet (Link zur Sendungsverfolgung)? Ist alles angekommen und im erwarteten Zustand? Der Betreiber des GSF ist nicht verantwortlich für die Richtigkeit der Angaben über die angebotenen Gegenstände. Wer private Geschäfte über das GSF abwickelt, gewinnt daraus kein Recht, die Plattform GSF für seine privaten Probleme, Strafverfolgung, Zeugenschaften und/oder Meinungsmache gegen Mitglieder oder Shops zu missbrauchen. Grundsätzlich sind dem Betreiber des GSF Realnamen, E-Mail- oder Postadressen nicht bekannt. Mit der Nutzung des GSF-Marktplatzplatz gelten diese Nutzungsvereinbarungen als anerkannt.
