Sounds from the Shelter vol.28 - Blast from the Past II
benji
http://soundsfromtheshelter.podomatic.com/entry/2015-11-19T11_53_20-08_00
Second mix of records I used to have. They all left my collection over the years for one reason or the other. Some mighty good tunes there.
The Embers . Where did I go wrong
Jay Bee & Mighty Sensations . Praying for an answer
Anthony & The Aqualads . I remember
Barbara Lynn . I don't want a playboy
Sam Dees . Lonely for you baby
Five Stairsteps . Change of pace
Frankie & The Damons . Man from SOUL
Patti Austin . Take your time
Baby Huey . Just being careful
J.D. Abram . Let me tell you what I want
Billy Gales . I'm hurting
Billy Adams . Go on
Nancy Butts . I want to hold your hand baby
Ohio Players . Love slipped through my fingers
Four Gents . Young girls beware
Boston Hitesmen . Can't let it ride
Erma Franklin . Abracadabra
Eartha Kitt . There comes a time
Ann Heywood . Crook his little finger
The Impalas . Speed up
Bobby Shannon . I get my groove
Amanda Humphrey . Power of love
Lori & Lance . I don't have to worry
Marv Johnson . With all that's in me
James Royal . Call my name
Freddie Houston . If I had known
