Hallo... my name is Mohammad and i come from malaysia. I have a lot of Interest on vespa an i am really surprised, on how good the german people with the vespa modification. definately i cannot find any of those modification on Malaysia.. :) I hope that i can share  some knowledge about vespa in the forum and i really hope that we can be friends since we are also vespa lover.. :)
Ich kann auch auf Deutsch sprechen, aber mein Deutsch ist nicht so gut, also beide Sprache sind auch okay bei mir.. :)
Ich hab Bitubo Stossdämpfer( hinten) für vespa PX150. aber die Dichtungen sind nicht mehr gut und ich will die neu wechseln. Hat jemand Erfahrungen, dieses Stossdämpfer zu reparieren? mein Stossdämpfer hat keinen Luftvenentil. also wie kann ich es die Luft befüllen? danke für eure Antwort.. :)
Thank you very much T5Rainer..  :cheers:
I have read the topic before and have gain some information on the topic thread. And some of the forum member had even gave the link about servicing the absorber on the topic. But the link was already dead. That is why I started a new topic since the thread before is already old and I am afraid that no one would answer my question ton that thread.. So has anyone maybe can help me to get the Service manual?  Thank you very much..  :thumbsup:
yes.. this is it... Thank you very much, T5Rainer!!  :thumbsup: I appreciate it! :-D but i have some more question about filling the air on the Absorber. I have the new Bitubo so it doesnt have air valve to pump the air into the body.. So how to fill up back the air after I repair the absorber? the old one has a proper air valve so that we can pump the air right?
Sorry, but i have to repeat.
Read the linked topic.
There's a link to an Alligator-valve to pimp your new Bitubo.
    • Sind doch eigentlich nur 3 miteinander verschweißte Bandeisen. Leicht nachzubauen.
    • Small Axe auf Arte. Soundtrack mit Trojan.   https://www.arte.tv/de/videos/120058-001-A/small-axe-1-5/?utm_source=android&utm_medium=share&utm_campaign=120058-001-A
    • Geschrieben vor 15 Minuten Hallo Leute, zum Thema DRT super strong Kupplung, das passt vielleicht heriher:   muss hier mal um Mitleid bitten...  nachdem ich ein paar hundert km gefahren bin, mit Zündungsproblemen, musstte ich meine GS auf Höchstdrehezahl halten, um überhaupt ein bisschen Strom zu bekommen zur Zündung, bin noch so grade zum Abend Quartier gekommen, das war voriges WE.   so, heute die Reibn auseinander genommen: Kupplungspilz war deutlich abgeschliffen, von 10 auf 7,5 mm. Kupplung hat nicht mehr getrennt.   Kupplung is eine DRT Sport. diese Klammer hat deutlich Riefen beim inneren Kupplungshebel hinterlassen, ok, ich denke mir, lass ma das mal... beim Zusamenbau ( mit neuem Druckpilz) hats einen Knaks gemacht und der Hebel ging auf einmal ganz leicht !   also wieder auseinader und siehe: der innere kurze Hebel ist wegen der Sollbruchstelle gerissen !!!   die DRT baut ein bisschen höher, 3 mm Spacer is verbaut, aber ich frag mich halt:   muss ich den Druckpilz (und den Hebel) jetzt alle 400km erneuern, das geht doch gar nicht ! ?   bin gespannt auf eure Kommentare!
    • Einen Einzelsitz oder nen Satz heiße Ohren?
    • Im modellbau franst das carbon gerne aus. Schönes loch brauch mindestens klebeband und scharfen bohrer. Je nach qualität von harz und gewebeausrichtung. Mal klein vorbohren... Beim kotflügel würd ich schauen ob das laminat  innen und aussen mit hartholz das mit zwei zwingen zusammengedrückt wird stabilisiert werden kann. Dann versuchen...
