HI to you all:
Here is my problem:
I recently built a new motor thinking of a quick and fun bike, but without seeking the last kilometers per hour, say it did not bother me going over 130 K / h.
The components are as follows: JL RH, Malossi 210, 60 mm crank mushroom type (UNDI from SIP), head 11:1 (gravedigger), reeds MRP (mrpracing) + RD 350 (BGM), Keihin PWK 28, RAMAIR, cases matched, piston machined.
18 º BTDC. Exhaust 186 º - Intake 126 º, 1 mm under the cylinder - 0.5 top of the cylinder, 1.2 squish.
In early tests it was determined that a 48 low jet was the most appropriate and standard needle JJH did well in the stand. Once on the road began testing with a 135 high, but never put the engine at top speed.
The engine feels perfect, sweet, until 4000 RPM, where he finds a wall, starts to vibrate and continuous flat until 5500, after which becames a rocket until I dont know how much (more than 120 km / h in third)
Because I did not have any Keihin needles I changed to a Dellorto 30 PHBH from my Polini engine: the problem persisted. We changed the coil, the same thing. We changed the stator: the same. The flywheel: the same. The reeds:the same.
Faced with such amounts of changes without results we proved a Malossi exhaust and the engine improved somewhat, but not much. We changed the atomicer AV 264 to a AV 262 and it is running better but not perfectly. I tried 16-17-18-19-20 degrees and does not clear the problem: at 4000 RPM begins to vibrate and does not react until after 5500 rpm were it starts to run like a plane.
Is it possibly the crank causing the problem,due the primary compresion being too low? Will that crank work with any exhaust or it will need a special one that will help scavenge?
Aremy timings OK?
Thanks to all.
Saludos desde Sevilla
Bearbeitet von santacama
    • Also ich muss bisschen ausholen    Der Motor wurde vor ca 4 Jahren komplett neu gemacht. Habe damals das Zylinder Kit von Pinasco bestellt 190ccm GT 2kanal mit passender Kurbelwelle. Das war damals ein komplettes Set.  Beim Zündung einstellen im Hochsommer bin ich ne runde gefahren und hatte Zylinderhaube nicht drauf und hab dann einen Klemmer bekommen wo es mich leider auch bös hingelegt hat.  (Vespa neuling, Kupplung vergessen zu ziehen) Ob die Vibrationen damals schon waren kann ich nicht mehr beurteilen.  Nach ein paar Jahren seelischer Pause habe ich mich ran gewagt und hab den Motor an proffesionelle Hände gegeben.  Motor wurde erneut komplett Revisioniert- Kurbelwelle war warhscheinlich verzogen, hatte schleifspuren oben. (siehe bild)  Also:  neue Kurbelwelle:  https://www.sip-scootershop.com/de/product/langhubwelle-mazzucchelli-for-sip-fuer-vespa-125-vnb-gt-gtr-1-super-ts-150-vba-vbb-t4-gl-sprint-v-1-super-1_45135600?usrc=langhubwelle Kurbelwelle war nicht aufm Richtbock wurde einfach eingebaut.  neues Polrad:  https://www.scooter-center.com/polrad-bgm-pro-touring-elektronik-1900g-vespa-largeframe-px200-cosa-lml-125150-starstella-takt-passend-auch-bei-modellen-mit-elestart-mit-diesem-polrad-ist-jedoch-kein-elektrostart-mehr-moeglich/p-18002.html wurde auch nicht gewuchtet.    So Motor kam wieder und habe mich schon gefreut und Motor eingebaut und festgestellt das es noch genauso war. Vielleicht 10% besser, aber immernoch nicht fahrbar mmn:   Folgende Silentgummis waren verbaut    https://www.sip-scootershop.com/de/product/silentgummis-motorschwinge-o-30-40-mm-links-rechts-fuer-vespa-125-vna-ts-150-vbb-super-px80-150-pe-lusso_17472610?usrc=silentgummis   Danach hab ic hden Motor wieder ausgebaut und folgende Silentgummis eingebaut:    https://www.sip-scootershop.com/de/product/silentgummis-motorschwinge-o-30-40mm-oi-14-3-mm-links-rechts-fuer-vespa-125-vna-ts-150-vbb-super-px80-150-pe-lusso_17472630?usrc=silentgummis   wurde auch nicht besser.  Ich kann natürlich jetzt die Bgm einbauen aber ob das was bringt wage ich zu bezweifeln.  das wären dann die hier :  https://www.scooter-center.com/silentblock-set-motor-bgm-pro-vespa-px80-px125-px150-sprint150-vlb1t-ts125-vnl3t-gt125-vnl2t-gtr125-vnl2t-super-gl150-vla1t-vna-vnb-vba-vbb/p-17832.html   Hatte mir auch ein originales Set bestellt von Piaggio wo alles noch einzeln montiert werden muss aber da war der Gummi für die Zylinderseite viel zu groß.    Weiß langsam einfach nicht mehr weiter und will einfach nur fahren. Mir ist mittlerweile Leistung egal, hauptsache das ding fährt einigermaßen ruhig.
    • Da gibt es die sog. Gleitlagerbuchsen mit verschiedensten Materiallegierungen des Rückens, der Beschichtung innen usw. im Ø 16/18 in x12/14/15/18/20/25 bzw. 40 Länge dann in weniger Längenauswahl aber mit 1mm dickem Bund   bei div. Anbietern für ganz kleines Geld zu bekommen. Die wichtigste Frage, kann der Clips mit den derzeitigen Abmessungen in der Drahtdicke den Kobo am rauswandern hindern?   Nur auf den Haken des "G" Clipses allein würd ich mich nicht verlassen
    • Waren gestern fahren,im 4 gang aufgerissen,Polini 221, vmc 252, keine Chance! das Ding dreht von unten raus das ist göttlich ! Mehr braucht man nicht!  Polini Box und 24.24 SI aufgebohrt ist für mich persönlich das beste Setup für den Zylinder
    • Während des Urlaubs in Spanien, in einem spanischen Marktplatz etwas gefunden was ich haben wollte, in der Nähe aber da ich nicht mobil war, gefragt ob er es zu mir schicken kann. Antwort: "Nein, kein Versand". Dann angefragt ob ich es abholen könnte, Antwort: "Ja, ich gebe meine Telefonnummer und Adresse aber nicht an Fremde ". Dann gefragt ob er es vorbeibringen könnte, würde ihm dann bei Übergabe das Geld in bar geben. "Nein, ich treffe mich nicht mit Fremden". Ich hab dann mal gefragt wie er sich vorstellt , unter den Vorraussetzungen etwas zu verkaufen.
