V5B3T mit ET3 motor brauche hilfe!
Hello,
I have an smallframe VB3T with an ET3 engine. I've been searching everywhere to find a electrical diagram that can help me figure out how to wire my scooter properly.
Right now my scooter is running and all the lights work except the rear-break light when engaging the rear break pedal. Does anyone of you guys have a wiring schema or diagram that could help me?
My scooter does not have a ignition switch. Just a kill switch on the right side and a horn/ Hi Lo on the left. And I do not have turn signals. Also no battery but that can be added if I wanted too.
how about your 1st topic?
the yellow cable from the generator ought to be connectet to black (the frame).
maybe you should merely try a slight approach to instead of engaging on the break-pedal!!!...vespas need a little soft touch u know :inlove:  :-D
just kidding...
judith asked reverend maynard and he spoke as follows:
http://www.scooterhelp.com/electrics/pages/VMB1T.prim.html
http://www.scooterhelp.com/electrics/pages/V5B3T.50special.html
http://www.scooterhelp.com/electrics/70.elec.html
Bearbeitet von vespa-rs
