Sufficient with SI24 for Polini 218?
Hello!
Was riding last year with a Polini 208 (57) with Pep2 and SI24.
Was really good as long as I didn't stay on full throttle for hours... Then it heat-seized...
Rebuilt this year with 60mm and a PHBH30 as I'm towing a PAV...
but now I think the induction noise is a bit too much. And the response on low rpm's isnt good enough either...
Will it be possible to ride the scooter and Pav proper with a SI24?
-and how should it be jetted?
The inlet is standard, but minor work done with the ports.
Any help is very apreciated!
Thanks!
Øyvind
Roughnecks Scooterclub
What is your actual jetting with SI?
I don't have the carb here, but 130 main jet, and think it was 55/100 pilot jet.
can't remember air-corrector..
Drilled hole in airfilter...
And ignition on 18'
