goon326
    8
Leistungen von goon326
newbie
newbie (1/12)
  1. Thanks for your elaborated answer! I also have the PK transmission (4 gears) and the standard V50 (3 gears) transmission. Only I have the selector for the 50s transmission and not the pk or are these the same? When I use the selector of the 50s I have a little difficulties in the neutral. Because the neutral of the 50s gearbox is somewhat wider. I wanted to have the 50s transmission to have low rpm in the fourth gear. My setup is a 70cc cilinder with a SHB 16.16 and standard exhaust. And I want to have a cruising speed around 60-65 km/h. I’m not planning to spindle the case to 54mm what is the advantage of that? So you would recommend using pk instead of 50s gearbox or maybe even the standard gearbox? Or is it both possible? With the 50s I have to alter the case or is that risky anyway?
  2. Hello, (I can read German, but writing German is a bit hard, hope it won't be a problem) I have a Vespa V50 crankcase (around '71 I guess) and want to install a vespa V50s gearbox in it. Only the Nebenwelle won't fit, is this correct? And can I change the crankcase that it will fit or is this not a good idea? Thanks in advance, Teus
  3. Hallo, Had jemand detaillierte Fotos einer original Vespa V50N (V5A1T) 1963-1971? Am besten ein Röte. Und würde jemand vielleicht wissen, ob diese mit einem blauen 'Vespa 50' Emblem geliefert wurde? Vielen dank,
