TravisNJ
    7
Alle Inhalte von TravisNJ
  1. Yeah, the removable stub is definitely thicker than the Malossi stub. It's enough of an issue to warrant a trip to the local machine shop to get the stub milled for the flange. I mean, if you try and it put it on you'll need to take a sledge hammer or a press to get it off. Furthermore, it didn't just happen on one stub. It happened on three different stock Piaggio stubs that were even sanded back down to the metal finish, to 3 of the bigger flanges from 3 different Big Box exhausts. Ask me how I know about the sledgehammer bit, lol.
  2. So double checked three different BGM Big Box exhausts with three different p200 cylinder exhaust stubs, none fit. The flanges fit perfectly onto a Malossi 210 cylinder though. Philippines, I tried to send an email to you but it got labeled "Undelivered".
  3. Anyone else have issues getting the exhaust flange on a stock cylinder exhaust stub? I have no problem with getting it on the Malossi cylinder stub that I have, but there is no way I can get it on any of the stock stubs that I have.
  4. Google Translated: Hat jemand ein Bild von der MMW bremspumpenhalter montiert, um einem alten P-Series? Has anyone installed a MMW disc brake bracket to a Vespa P-Series? If so, does anyone have any pictures? Cheers from USA, Travis
  5. How accurate/responsive is it?
  6. I'm not really interested in going all the way up to 62mm. Just wanted to choose from 57 and 60mm, but I appreciate the input. If you chose from between the two, which would you choose and why?
  7. Original: Hey guys, I'm a new board member from the USA and had a quick question for my upcoming project. I can't decide between a 57mm stroke or a 60mm stroke for my Malossi 210 motor. I was wondering what you guys thought was best for max power. The cylinder will be ported and paired with a Pipe Design Charger 220 exhaust, a MRP reed manifold and a EFL gearbox. Cheers Travis Google Translated: ich bin ein neues Mitglied aus den USA und hatte eine kurze Frage für mein kommendes Projekt. Ich kann nicht zwischen einem 57mm Hub oder 60mm Hub für meinen Malossi 210 Motor entscheiden. Ich frage mich, was euch gedacht, das Beste für maximale Leistung. Der Zylinder wird portiert und mit einem Pipe Design Charger 220 Auspuff, ein MRP Reed vielfältig und einer EFL Getriebe gekoppelt werden. Thanks for all of your comments and suggestions!
