Polini221 vibrates heavily above 7k rpm
Svint1
Hi!
I have a Polini221 engine that rides very smooth. -never had so little vibrations in a Vespa engine...
But that is only as long I don't push it over 7000rpm...
-then it starts to vibrate heavily...
I'm suspecting that the pick-up isn't all good, and can't deliver proper sparks above 7k rpm.
-does that makes sence?
Setup;
PX200 casing matched to sylinder
60mm crank (unknown brand, bought here on GSF)
SI24/24 autolube with nd3,33 and hd128
Standard ignition on 19"
Polini box exhaust.
Rgrds
Ø
Bearbeitet von Svint1
1 hour ago, shamane said:
I think it comes from the Polini Box. I had this, too. With an other Polini Box the vibrations were gone.
Ok, thanks!
Very usefull information!
-I have been thinking of that myself, but wasn't sure...
I might try with a SIP Road to check....
I ve tested the Polini Box since 600km with a bunch of carb. Modifikations but I still have these vibrations.
There could be a relation between the attachment oft the Box and the cylinder, i guess.  I´ll try to put on the viton attachment, to solve this Problem.
:cheers:
