Jump to content
Recommended Posts
Posted
Hi!
Newly built my Polini221 engine...
Setup;
Polini221
60mm crank
Polini box pipe
Ignition 19’
SI24/24 with nd48/160 and hd135
My problem is that it still four-strokes/stutters on low rev and a bit in the lower midle..
-even with a 3,33 slow jet?!?
The ignition is spot on 19 degrees.
Anyone who can help me solve this?
Rgrds
Ø
Sent from my iPhone using Tapatalk
Posted
1 hour ago, Pez said:
Airfilter?
If yes with bores over the main Jet?
or. Venturi?
Original airfilter with drilled holes above main jet and low jet.
PS! I've now running 128Hd and 3,33 on slow jet, but still stutters on low throttle....
Posted
This could also be symptons for a to lean jetting. 48/160 is way to lean, try a 60/160 without a hole over the low jet
Ok, I’ll do!
But CHT is around 90, so might not be lean?
Anyway, I’ll try
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    • No registered users viewing this page.
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue. Privacy Policy
