Elestart flywheel rubbing on Polini208 cylinder
Svint1
Hi,
I've fitted a Polini208 on my PX200GS With elestart...
I've removed some material on the sylinder, as the flywheel rubs on it...
But I haven't removed enough, as it still rubs a little.
-how much can I remove without going through the cylinder?
I Guess the Polini208 should work With elestart flywheel?
Rgrds
Øyvind
Bearbeitet von Svint1
Hi Tobi,
He he, the elestart is not needed
-but highly preferred...
Was jus wondering if there is a risk of going through to the ports if I use the Dremel to remove a mm or two...?
Sent from my iPhone using Tapatalk
9 hours ago, wheelspin said:
Think about to Do it the other way around.
Remove the starter rim from the flywheel and machine the seat for the starter rim at the flywheel  on  a lathe 1 to 1.5 mm deeper.
That will solve your problem.
Sounds like a good sollution, except that I don't have a lathe...
That's why I'm going for the Dremel sollution.
-just a bit afraid of taking too much and going through the metal...
vor 7 Minuten schrieb Svint1:
take a look at timey's stuff though.
his " Doppelzirkelbausatz " will help to go not to crazy with the dremel. Take a look ->
