Beedspeed kolben
palmerindegelves
Hello, I can not speak German, but I wish to ask a question in your forum; Anybody Know the cuality and the result of the new Beedspeed's pistons for PX200?. I'd like to use it with a old ported Autisa.
Take this opportunity to congratulate you on your forum, that I read usually with great difficulty (Google translate). Thanks
Do you still have the original piston? If so, check the piston windows as they are different from standard.
If you`re going to rebore please keep in mind that the Autisa barrel is made of alloy with only a steel liner. I´m not sure if it will take a 70 mm bore without problems. Autisa is/was not known for high quality parts (allignment of ports and steel liner is said to be poor).
I would give the barrel a hone or a rebore and fit the next oversize (standard P 200) piston after a bit of work on the piston windows.
70 mm bore would be my last attempt if there`s no other oversize left.
Regards
Tec
P.S.: I`m looking for an Autisa barrel for a Lambretta 200. Would like to hear from you via PM (personal message) if you know one for sale.
Bearbeitet von Tec
Regards
Tec
I have thought to use the 68 mm because I also think that bore to 70 mm can be too. I know how to make the windows of the
original piston. Thanks
I believe that find the Autisa kit for Lambretta in Spain is more difficult than in England or Germany. But I'll let you know if I find one.
    • Moin,   da Österreich und Belgien (meines Wissens nach) E5-Sprit mittlerweile gekippt haben, der Sprit nach der aktuellen Diskussion auch in D auf der Kippe steht und auch das übrige europäische Ausland zumindest grundsätzlich keinen E5-Sprit mehr vorhalten muss, mache ich mir aktuell etwas Sorgen, was meine 87er PX in Zukunft durch den DR 135 jagen darf. Klar, ich könnte auf Premiumsprit umsteigen, aber dafür wird bei den üblichen Markentankstellen auch Premium kassiert, das steht meiner Ansicht nach in keinem Verhältnis. Die Suchfunktion habe ich schon in Anspruch genommen, aber zu dem Thema keine Diskussion gefunden - nur im Zusammenhang mit Simmerringen wurde E10 kurz gestreift.   Meine Fragen in die Runde:   1. Bin ich richtig informiert, dass die PX in Standardausführung kein E10 verträgt? 2. Muss ich für E10 etwas beim Zweitaktöl beachten? 2. Um die Vespa E10-tauglich zu machen, müsste ich nach allem, was bisher diskutiert wurde, auf jeden Fall die Simmerringe wechseln (die BGM vom SCK werben beispielsweise damit, E10-resistent zu sein). Das bedeutet nach meinem bescheidenen Wissen, den Motor zu spalten, um an alle Ringe ranzukommen - ist zwar Arbeit, aber könnte sich langfristig lohnen. Wäre es mit einem Schwung Dichtringe und Gehäusedichtungen getan (wenn ich schon spalten muss, dürfte es sinnvoll sein, die Gehäusedichtungen gleich mitzumachen, die Kosten sind überschaubar), oder übersehe ich irgendwo weitere Bauteile? Nichts machen und Premiumsprit tanken (meine Haustankstellen hier in der Nähe führen leider nur den besonders teuren Sprit mit 100 oder 102 Oktan) wäre höchstens eine letzte Option, wenn der Aufwand für mich als Hobbyschrauber ohne ernstzunehmende Werkstatt nicht umsetzbar ist.   Ich freue mich auf eure Meinungen und Gedanken!
    • Sorry, dass ich mit so einer billigen Spako-Frage kommen.    Hab einen neuen SHB 19.19 Vergaser mit Original-Luftfilter. Leider waren für die Stehbolzen keine Muttern zur Befestigung im Set. Seltsamerweise passen meine normalen M4-Muttern nicht drauf. Hab verschiedene Altersklassen probiert. Fühlt sich an, als sei die Steigung nicht passend. Kommt da was spezielles drauf?
    • Kannst Du aber sicher auch ablassen und wiederverwenden, falls Einfüllmöglichkeit vorhanden.
    • bin da bezüglich "atmender" welle beim polinizei, kugellager, und gut ist. verstehe daher auch nicht die umrüsterei der malle gehäuse auf das anachronistische t5 lager. beim db patent ging es vermutlich um gleitlager, oder liege ich da falsch?
    • von 11/93, also n ganz junger alter. der bereitet mir ziemliche freude, gutes auto.
