Some questions about products for px
eleger91
hello,
I've some questions about px products :
- for my px200e (VSX1T) :
I wanna buy a good spark plug. Shall I take the Bosch W2CS silver ?
Bosch W2CS silver
- for my px125e (VNX2T) :
I wanna buy a good spark plug cap. Shall I take the Spark plug cap + wire NGK
NGK racing
There are so many alternatives !!! :-D
Spark plug cap NGK, LB5F
NGK
Spark plug cap PIAGGIO PX
PIAGGIO PX
Spark plug cap, 90°, with metal coating, interference suppressed
metal coating
Spark plug cap ARIETE, 90°, silicone, red
ARIETE
I'm looking for a compact foam that protect the PX tank...so a protection which would be around the tank
PX tank
I'm looking also for the protection thick baseplate (about 10cm) placed on the top of the rear shock absorber to avoid boring sheet...that complete the rubber shock absorber rubber shock absorber
Who could help me ? :-D
Bearbeitet von eleger91
For the PX 200 original Cylinder you have to use a Bosch W5 ! If you order a copper, silver or platin is your decision, but most of us, me concluded, made adequate positive experiences with the normal copper! Your moneybag will thank it to you, too!
Bosch W5 CC is your thing! If you have mounted a tuning cylinder you have to use W4, W3 or W2! It depends on the cylinder, compression ratio and so on!
The red Spark Plug looks good, but is not necessery. If you like the look, buy it.
Max
PS.: What you want to do with the tank, i dont know!
tks sNoWmaX, :-D
the px200e is wiz the original cylinder.
so I've got to buy that spark plug ? spark plug
...but for my culture, the W4CS silver was the right one in silver ?
for the spak plug cap, same answer...I choose than one I want...the red one (you mean the NGK racing) could be mounted on a px125 ?
for the tank, I'm looking for the foam that is around the tank to protect it from the sheet metal of the px
ps : wiz which spray paint do u paint your rims ?
That one ? Silver spray
regards
tks sNoWmaX, :-D
regards
oui, cette bougie est correcte...
si tu veux tracer les jantes sette painture est ok...
danke sehr,
du habst das "wir lernen Franzos" gut gelernt. (der genaue Satz war "si tu veux peindre les jantes, cette peinture est ok...)
ich habe die Bosch W5 CC gekauft und auch die Sprayfarbe...
was denkst du über den Schaum nach ?
wer hat bei SIP artikels gekauft ?
weil sie sagten, daß nach einem oder über als 500 euros ich werde einen 10% onlinerabatt haben...Ich werde sehen, wenn sie diesen rabatt respektieren
Servus,
Your german seems to be pretty good, so i will answer in german, too! :-D
Die W5 CC ist für einen original 200 Motor die richtige Zündkerze! Die Spray-Dose ist auch gut, aber ich denke, dass du für weniger Geld in einem Laden bei dir um die Ecke eine genau so gute Farbe kaufen kannst! Bei den Zündkabeln sind die aus Silikon mit Sicherheit nicht schlechter, eher besser, als die normalen! Aber sein muß es nicht! Ein Motor funktioniert auch gut ohne die Silikon-Kabel! Es liegt halt bei dir, ob du ein par Euro mehr ausgeben möchtest!
Max
Bearbeitet von sNoWmaX
Sorry, aber so etwas hab ich noch nicht bei einem Roller gesehen! Dieses Teil soll, wenn ich es recht verstanden habe, oben an den hinteren Stoßdämpfer, zwischen Rahmen und dem Gummilager kommen?!? Wenn ja, und du unbedingt so einen Gummi haben möchtest, schneide dir doch einfach selber so etwas aus!
Viele Grüße,
Max
Ich finde dieses Blech, dass der Kollege anscheinend eingebaut hat, recht interessant. Weiss jemand, ob das 'was nützt'?
Bzw. hat jemand schonmal von einem Fall gehört, dass der Stossdämpfer durch den Rahmen gestossen ist?
Eine Gummimatte zwischen dem ominösen Blech und dem Rahmen würde schon Sinn machen, insofern das Blech (ich nenne es Mal 'Stossdämpferkopfplatte')
als solches Sinn macht.
Naja, Sinn würds schon machen, es würde halt den Druck der verhältnissmäßig kleinen Fläche des normalen Gummidämpfers auf eine größere Fläche verteilen. Aber gesehen hab ich dieses Teil bis jetzt noch nirgendwo! Hab aber auch noch keinen Dämpfer gesehen der einfach mal so in den Tankraum gebrochen wär. Abgesehen von irgendwelchen zusammgefaulten irgendwas Teilen welche die letzten 20 Jahre im Garten gestanden sind!
Meiner Meinung nach ist dieses Teil von jemanden selbst angefertigt und dann eingebaut worden.
Max
PS.: Größere Reifen würden auch Sinn machen, aber deswegen fahren wir auch nicht gleich mit 18 Zoll sondern immer noch mit 10 Zoll rum :-D
Max
...Du stützt meine Vermutung. 18"-Reifen... sehr schön *lach
Ich verstehe nicht alle aber ich glaube, das wesentliche begriffen zu haben. :-D
Sagen sie daß ein gummi stück könnte ausreichen ? mmmmm :-D
We think it is a self-made construction resp. metal-piece.
The guys who discussed it here have never seen a metal-plate
between the rubber-bumper on top of the shock absorber and the frame.
Anyway. If it is mounted on your 'bike', a rubber mat between this metal plate and the frame
could avoid 'strange noises' caused by extreme loads or forces...
    • Hallo liebe Leidensgenossen! Einige haben es ja schon mitbekommen: Die Online-Nennung für Stockach ist geöffnet! Denkt daran Eure Fahrzeugdaten neu einzugeben. Die neue Startnummer könnt Ihr Euch dann bei der Nennung aussuchen.   Danach bitte zeitnah Euer Strartgeld inkl. Tagesversicherung auf unser Konto zu überweisen (30€ pro Klasse + 9€ Tagesversicherung) überweisen: PayPal: [email protected] oder Überweisung: Marc-Oliver Neumann IBAN DE14 7305 0000 0441 7447 60   Verwendung: DBM Stockach 2024 Kl."x" + Kl."y" + Vers.   Wir freuen uns auf Euch! C U on Track
    • ...ach das war ja so toll früher drieben!
    • Danke alter Kollege für den Link. Ich schau ja immer mal, aber die hatte ich noch nicht gesehen. Ich schau mir das mal genauer an
    • Moinsn,   verkaufe neuwertigen Parma Kopf vom 177 2-Kanal Kit... passt auf Alle Parmas. Guss mit CNC Bearbeitung...   Wenige Km. Mit Zentrierung und 'Standard' Kerzenposition.   Nur hier, nicht woanders oder Egay.. Standort 58313.   Np 79 -  jetzt für 45.   Gruß H   Bilders kommen   Artikel:   https://www.scooter-center.com/de/zylinderkopf-parmakit-177/187-ccm-vespa-px125-px150-gt125-vnl2t-gtr125-vnl2t-ts125-vnl3t-sprint150-vlb1t-gt125-vnl2t-gl150-vla1t-super-vnb-vba-vbb-pk5740104?number=PK5740104
