eleger91 Geschrieben 26. November 2006 Teilen Geschrieben 26. November 2006 (bearbeitet) hello,I've some questions about px products :- for my px200e (VSX1T) :I wanna buy a good spark plug. Shall I take the Bosch W2CS silver ?Bosch W2CS silver- for my px125e (VNX2T) :I wanna buy a good spark plug cap. Shall I take the Spark plug cap + wire NGKNGK racingThere are so many alternatives !!! Spark plug cap NGK, LB5FNGKSpark plug cap PIAGGIO PXPIAGGIO PXSpark plug cap, 90°, with metal coating, interference suppressedmetal coatingSpark plug cap ARIETE, 90°, silicone, redARIETEI'm looking for a compact foam that protect the PX tank...so a protection which would be around the tankPX tankI'm looking also for the protection thick baseplate (about 10cm) placed on the top of the rear shock absorber to avoid boring sheet...that complete the rubber shock absorber rubber shock absorberWho could help me ? Bearbeitet 26. November 2006 von eleger91 Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
sNoWmaX Geschrieben 26. November 2006 Teilen Geschrieben 26. November 2006 For the PX 200 original Cylinder you have to use a Bosch W5 ! If you order a copper, silver or platin is your decision, but most of us, me concluded, made adequate positive experiences with the normal copper! Your moneybag will thank it to you, too! Bosch W5 CC is your thing! If you have mounted a tuning cylinder you have to use W4, W3 or W2! It depends on the cylinder, compression ratio and so on!The red Spark Plug looks good, but is not necessery. If you like the look, buy it. MaxPS.: What you want to do with the tank, i dont know! Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 26. November 2006 Autor Teilen Geschrieben 26. November 2006 (bearbeitet) tks sNoWmaX, the px200e is wiz the original cylinder.so I've got to buy that spark plug ? spark plug...but for my culture, the W4CS silver was the right one in silver ?for the spak plug cap, same answer...I choose than one I want...the red one (you mean the NGK racing) could be mounted on a px125 ?for the tank, I'm looking for the foam that is around the tank to protect it from the sheet metal of the pxps : wiz which spray paint do u paint your rims ?That one ? Silver sprayregards Bearbeitet 26. November 2006 von eleger91 Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 27. November 2006 Autor Teilen Geschrieben 27. November 2006 up Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
floryam Geschrieben 27. November 2006 Teilen Geschrieben 27. November 2006 tks sNoWmaX, the px200e is wiz the original cylinder.so I've got to buy that spark plug ? spark plug...but for my culture, the W4CS silver was the right one in silver ?for the spak plug cap, same answer...I choose than one I want...the red one (you mean the NGK racing) could be mounted on a px125 ?for the tank, I'm looking for the foam that is around the tank to protect it from the sheet metal of the pxps : wiz which spray paint do u paint your rims ?That one ? Silver sprayregardsoui, cette bougie est correcte...si tu veux tracer les jantes sette painture est ok... Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 27. November 2006 Autor Teilen Geschrieben 27. November 2006 (bearbeitet) oui, cette bougie est correcte...si tu veux tracer les jantes sette painture est ok...danke sehr,du habst das "wir lernen Franzos" gut gelernt. (der genaue Satz war "si tu veux peindre les jantes, cette peinture est ok...)ich habe die Bosch W5 CC gekauft und auch die Sprayfarbe...was denkst du über den Schaum nach ?wer hat bei SIP artikels gekauft ?weil sie sagten, daß nach einem oder über als 500 euros ich werde einen 10% onlinerabatt haben...Ich werde sehen, wenn sie diesen rabatt respektieren Bearbeitet 27. November 2006 von eleger91 Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
sNoWmaX Geschrieben 27. November 2006 Teilen Geschrieben 27. November 2006 (bearbeitet) Servus,Your german seems to be pretty good, so i will answer in german, too! Die W5 CC ist für einen original 200 Motor die richtige Zündkerze! Die Spray-Dose ist auch gut, aber ich denke, dass du für weniger Geld in einem Laden bei dir um die Ecke eine genau so gute Farbe kaufen kannst! Bei den Zündkabeln sind die aus Silikon mit Sicherheit nicht schlechter, eher besser, als die normalen! Aber sein muß es nicht! Ein Motor funktioniert auch gut ohne die Silikon-Kabel! Es liegt halt bei dir, ob du ein par Euro mehr ausgeben möchtest! Max Bearbeitet 27. November 2006 von sNoWmaX Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 27. November 2006 Autor Teilen Geschrieben 27. November 2006 danke sNoWmaXunf fûr dem Schaum (mousse en français) um den Tank ? Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
sNoWmaX Geschrieben 27. November 2006 Teilen Geschrieben 27. November 2006 i never had something like a "mousse" around my tank! Sorry, but i dont know what you mean! Max Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
Calico Jack Geschrieben 27. November 2006 Teilen Geschrieben 27. November 2006 http://www.sip-scootershop.com/pages/detai...b97f4ab707023fd Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 27. November 2006 Autor Teilen Geschrieben 27. November 2006 danke Calico Jack,but it isn't on the top of the tank but glued around the frame, to protect the tank (or to make pretty... )...sorry zu schwer in deutsch Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
Brosi Geschrieben 27. November 2006 Teilen Geschrieben 27. November 2006 The thing Calcio Jack posted is exactly what you want. "Dichtung PIAGGIO Tank" means "PIAGGIO tank gasket"! Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
floryam Geschrieben 28. November 2006 Teilen Geschrieben 28. November 2006 du habst das "wir lernen Franzos" gut gelernt. (der genaue Satz war "si tu veux peindre les jantes, cette peinture est ok...)...naja ein satz mit zwei fehlern ist schon peinlich Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 28. November 2006 Autor Teilen Geschrieben 28. November 2006 ...naja ein satz mit zwei fehlern ist schon peinlich hihihi...wenn sie hilfe in franzos brauchen, können sie mich fragen... Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 28. November 2006 Autor Teilen Geschrieben 28. November 2006 The thing Calcio Jack posted is exactly what you want. "Dichtung PIAGGIO Tank" means "PIAGGIO tank gasket"!Tks broz666, aber es ist nicht was ich suche...ich suche einen Schaum Schutz, der an den "largeframe" geklebt werden konnte Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 28. November 2006 Autor Teilen Geschrieben 28. November 2006 I come back with fotos about the protection thick baseplate on the top of the rear shock absorber to avoid boring sheet...that complete the rubber shock absorber rubber shock absorberoverundersidewer hat dieses produkt ? Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
sNoWmaX Geschrieben 29. November 2006 Teilen Geschrieben 29. November 2006 Sorry, aber so etwas hab ich noch nicht bei einem Roller gesehen! Dieses Teil soll, wenn ich es recht verstanden habe, oben an den hinteren Stoßdämpfer, zwischen Rahmen und dem Gummilager kommen?!? Wenn ja, und du unbedingt so einen Gummi haben möchtest, schneide dir doch einfach selber so etwas aus!Viele Grüße, Max Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 29. November 2006 Autor Teilen Geschrieben 29. November 2006 Hello sNoWmaX, ja, es ist ein aluminium stück, das sich ober das gummipuffer stoßdämpfer stück () setzt, um zu vermeiden, daß das blech sich nicht durchbohrtdanke Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
floryam Geschrieben 29. November 2006 Teilen Geschrieben 29. November 2006 Ich finde dieses Blech, dass der Kollege anscheinend eingebaut hat, recht interessant. Weiss jemand, ob das 'was nützt'?Bzw. hat jemand schonmal von einem Fall gehört, dass der Stossdämpfer durch den Rahmen gestossen ist?Eine Gummimatte zwischen dem ominösen Blech und dem Rahmen würde schon Sinn machen, insofern das Blech (ich nenne es Mal 'Stossdämpferkopfplatte') als solches Sinn macht. Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
sNoWmaX Geschrieben 29. November 2006 Teilen Geschrieben 29. November 2006 (bearbeitet) Naja, Sinn würds schon machen, es würde halt den Druck der verhältnissmäßig kleinen Fläche des normalen Gummidämpfers auf eine größere Fläche verteilen. Aber gesehen hab ich dieses Teil bis jetzt noch nirgendwo! Hab aber auch noch keinen Dämpfer gesehen der einfach mal so in den Tankraum gebrochen wär. Abgesehen von irgendwelchen zusammgefaulten irgendwas Teilen welche die letzten 20 Jahre im Garten gestanden sind! Meiner Meinung nach ist dieses Teil von jemanden selbst angefertigt und dann eingebaut worden. MaxPS.: Größere Reifen würden auch Sinn machen, aber deswegen fahren wir auch nicht gleich mit 18 Zoll sondern immer noch mit 10 Zoll rum Bearbeitet 29. November 2006 von sNoWmaX Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
floryam Geschrieben 30. November 2006 Teilen Geschrieben 30. November 2006 Naja, Sinn würds schon machen, es würde halt den Druck der verhältnissmäßig kleinen Fläche des normalen Gummidämpfers auf eine größere Fläche verteilen. Aber gesehen hab ich dieses Teil bis jetzt noch nirgendwo! Hab aber auch noch keinen Dämpfer gesehen der einfach mal so in den Tankraum gebrochen wär. Abgesehen von irgendwelchen zusammgefaulten irgendwas Teilen welche die letzten 20 Jahre im Garten gestanden sind! Meiner Meinung nach ist dieses Teil von jemanden selbst angefertigt und dann eingebaut worden. MaxPS.: Größere Reifen würden auch Sinn machen, aber deswegen fahren wir auch nicht gleich mit 18 Zoll sondern immer noch mit 10 Zoll rum ...Du stützt meine Vermutung. 18"-Reifen... sehr schön *lach Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 30. November 2006 Autor Teilen Geschrieben 30. November 2006 Ich verstehe nicht alle aber ich glaube, das wesentliche begriffen zu haben. Sagen sie daß ein gummi stück könnte ausreichen ? mmmmm Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
floryam Geschrieben 30. November 2006 Teilen Geschrieben 30. November 2006 Ich verstehe nicht alle aber ich glaube, das wesentliche begriffen zu haben. Sagen sie daß ein gummi stück könnte ausreichen ? mmmmm We think it is a self-made construction resp. metal-piece.The guys who discussed it here have never seen a metal-plate between the rubber-bumper on top of the shock absorber and the frame. Anyway. If it is mounted on your 'bike', a rubber mat between this metal plate and the framecould avoid 'strange noises' caused by extreme loads or forces... Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
eleger91 Geschrieben 30. November 2006 Autor Teilen Geschrieben 30. November 2006 ach...ich weiß es nicht ob dieses stück hand gemacht wurdescootering (www.scooteringfrance.com), ein geschäft in Paris, verkauft ein praktisch identisches produkt, aber an 70 Euro Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
